| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: MDX, Camry
Which oil filter to pair with mobil 1 extended performance engine oil?
I am going to use the Mobil 1 Extended Performance 0w-20 oil (those in the golden jugs). It says on the jugs that it is good for 15k miles. But I am not sure whether it is too risky to stretch oci to 15k. Maybe 12k?
But even with 12k, if I use this oil and oem filter, should i replace the filter once? Or, I should get the matching m1 extended performance filter from the get-go? Thanks for your ideas. |
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#3 |
Use the Mobil 1 filter
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#4 |
Drives: Toyobaruion
I just use the OEM filters and I change oil every 5k just because that's what I'm used to.
#5 |
Drives: 2014 BRZ SCCA STU endurance car
OEM or Denso filters over here.
#6 |
Drives: 2013 Brz C38 (bought not built :P)
| The Following User Says Thank You to fumanchu1 For This Useful Post: | go_a_way1 (03-10-2016) |
#7 |
Drives: 2013 WRB BRZ
I use the purolator Classic that you find at Walmart. Cheap decent filters. I change it every 3k miles. Also read somewhere that the standard Mobil 1 Advanced Full Synthetic offers the better protection over the Advanced Economy and Extended Performance.
#8 |
Subaru filter
#9 |
Drives: 2013 Firestorm FR-S AT
I use the FRAM Ultra Synthetic Oil Filter, XG9688 with Mobil 1 Extended Performance 0W-20 Full Synthetic Motor Oil. This filter is supposed to be good up to 15K miles with this oil but I change it and the oil at 10K.
http://www.walmart.com/ip/FRAM-XG968...ilter/16879132 |
#10 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
TRD filter!!
#11 | |
#12 |
Drives: 2013 Ultramarine Scion FRS MT
OEM and change it halfway through whatever you decide you change interval (I'm thinking 15k since that what you mentioned). The FA20 recommended oil change interval is 7500 miles, therefore the filter should be good for at least that interval. That being said, 7500 miles has never sat well with me. I usually like to go around 5000 miles before my oil changed. Could be lack of understanding of engines and the wear they experience....
#13 |
When to change your your oil and filter is a highly debated topic.
From my FR-S Owner's and Maintenance manuals: Normal driving: Change oil and filter every 7,500 miles or seven and a half months, whichever comes first. Severe driving: Change oil and filter every every 3,750 or 3 ¾ months, whichever comes first. If one or more of the severe operating conditions outlined below better describes how you typically operate your vehicle, you will need to perform some maintenance services more often, follow the severe recommendations. > Repeated short distance driving. > Driving on rough and/or muddy roads. > Driving in high humidity areas or in mountainous areas. > Driving in dusty conditions. > Driving in extremely cold weather. > Driving in areas where road salts or other corrosive materials are used. > Living in coastal areas. NOTE: You should perform these additional maintenance services if you drive primarily under any of the severe operating conditions indicated. If you drive only occasionally under these conditions, it is not necessary to perform the additional services. Oil grade 0w-20: (I'm assuming they are referring to conventional oil not synthetic) ILSAC GF-4 ILSAC GF-4 is similar to the API SM service category, but it requires an additional sequence VIB Fuel Economy Test (ASTM D6837). ILSAC GF-5 Introduced in October 2010 for 2011 and older vehicles, designed to provide improved high temperature deposit protection for pistons and turbochargers, more stringent sludge control, improved fuel economy, enhanced emission control system compatibility, seal compatibility, and protection of engines operating on ethanol-containing fuels up to E85. API classification SM or SN with the words “ENERGY CONSERVING” or “RESOURCE CONSERVING” With a synthetic oil, IMO, you can extend the Normal driving change intervals to at least 10,000 miles. |
| The Following User Says Thank You to RickyBobby For This Useful Post: | Clipdat (03-11-2016) |
#14 | |
Posts in the nude
Drives: 2016 WRB BRZ
![]() EDIT: Typo: Mobil 1 Extended Performance filter with Amsoil Signature Series oil. I was sleepy.
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography "Lesbian trees have no wood." - Scoobs McGee Last edited by mixtape; 03-14-2016 at 01:40 PM. |
| The Following User Says Thank You to mixtape For This Useful Post: | stevesnj (03-14-2016) |
| Where to buy K&N performance air filter? | 147kW | AFRICA | 22 | 09-13-2015 12:44 PM |
| Performance air filter? | trexx0411 | Arizona | 0 | 08-03-2015 07:58 PM |
| OEM Subaru engine air filter + cabin air filter | autobrz | Mechanical Maintenance and Tools | 6 | 03-09-2014 09:28 PM |
| Clogged Engine Intake Filter | kndonlee | Issues | Warranty | Recalls / TSB | 18 | 09-09-2012 10:47 PM |
