Old 03-10-2016, 09:04 AM   #295
GT86_PRAGUE
Drives: GT86
Originally Posted by Toyota86.ir View Post
there is no self-contradictory.
My english writing is not good but maybe i could teach you about subjective vs objective review.
i audio reviewing and some other reviewing we could analyse the system in two way.
http://nwavguy.blogspot.ae/2011/05/s...ve-debate.html
https://en.wikipedia.org/wiki/Audio_equipment_testing
Are you happy with your 4.88 E85 combo and what tires are you running?
Do you have lighter driveshaft or considering it?
My subjective review is that 4.88 feels much faster than oem for the driver, but difference between cars on street is very small, 4.88 is only slightly faster but that feeling inside car is very different and worth it. So maybe this is what could I expect from CF driveshaft? Before anyone suggest byuing it to test it, CF DSS MT costs $1300 in my country.
Does any of you engineers actually have this on car?
GT86_PRAGUE is offline   Reply With Quote
Old 03-10-2016, 10:23 AM   #296
churchx
churchx's Avatar
Drives: 2014 GT86
People actually cut down their 0-60 times, people are able to keep up with more powerful cars. Different FD is good NA mod, that really works. Even better on AT. Close gear set (or in addition to FD) might be better on track, but also costs more and is more difficult to install unlike FD.
CF shaft will do very little .. certainly not enough for what it costs. Simply because shaft is small diameter, hence it doesn't store as much rotational energy, be it lighter or heavier. Lighter flywheel and much more so lighter wheels (not just large diameter rotational, but also unsprung mass) will help more then shaft, if going that route.
The Following 3 Users Say Thank You to churchx For This Useful Post:
avishenoy1 (03-10-2016), GT86_PRAGUE (03-10-2016), Toyota86.ir (03-10-2016)
Old 03-10-2016, 10:28 AM   #297
GT86_PRAGUE
Drives: GT86
Thanks, I would like to have 16" TWS wheels, but I didnt find suitable BBK for it. Close gears would solve my extremely short 1st gear, but I could get 4 TWS wheels for the same price with more value.
Old 03-10-2016, 10:43 AM   #298
FRS Justin
Drives: 2013 Asphalt FRS
Please tell me how to go faster during a drag race Mr. Wizard.....
I have seen so much crap in this post I can't believe it smh.......
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
cdrazic93 (03-10-2016), kritch (05-30-2016)
Old 03-10-2016, 11:07 AM   #299
GT86_PRAGUE
Drives: GT86
Are you an engineer too?
Old 03-10-2016, 11:25 AM   #300
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
I use fd4.88 and i am happy with that. I use oem michelline tire 215/45r17
Very minor changes under 5% more acceleration in 0-176km/h but the car react better than fd4.1
I use no aftermarket driveshaft .
Toyota86.ir is offline   Reply With Quote
Old 03-10-2016, 01:07 PM   #301
FRS Justin
No I am not, I am a realist, And their is so much BS in this post I don't even know where to start. Gears making it feel faster but not being faster, Driveshafts creating hp and not creating hp. And its all basic science.. What is not stated here is every mod made has to match and compliment the total package or you will not see the gains that the mods are capable.
Example: Gearing for the 1/4 mile,
Tire size, RPM, weight of vehicle, TQ/Hp, Tranmission gearing, distance covered, all has to be put in the equation to select proper final drive ratio.
Or you get what you have, feels faster but is slower in the 1/4 mile.
Why because you selected the wrong raito, everything you gained you just shit away because now your shifting into 5th gear to make it thru the lights......The gearing could have picked up .5 to 1 second of time but shifting to another gear cost you that time. You can't tune for TQ then gear the hell out of it and expect it to fly you would need high rpm to maintain the gear. 4.88's require power to 8200rpm to get max gain so when you add a set of Crawford power blocks and lose 1000 rpm off the top you totally screwed yourself.
Driveshafts, same thing applies yes you could make gains but if your car is heavy you will lose those gains and hurt performance. Personally I would not waste the money on a driveshaft for my application. I tried one a aluminum DSS drive shaft it was the biggest piece of shit I have ever bought. First they welded the flange on it crooked then after having them attempt to fix it still shook the car so bad it felt like my fillings would rattle out of my teeth. No gains to be made because my car has full interior and its heavy.
Now put it on a gutted light weight car and I'm sure you would find a decent gain.
So in closing you don't need to be a engineer, because this isn't rocket science. Just use good solid common sense and basic math and science and you can easily make power and gains. When in doubt ask someone who knows.
EDIT: One more thing to consider going to a on piece driveshaft is pinion angle. Pinion angle can cause a loss of traction and power transfer not to mention a whole bunch of other problems...
I'm not directing anything at anyone but come on guys cover the basics before you have a knock down drag out.
710whp
GT86_PRAGUE (03-14-2016), TRAKRAVN (03-10-2016)
Old 03-10-2016, 02:33 PM   #302
celek
Resident Gear Head
celek's Avatar
Why does this feel like a Advertisement?
celek is offline   Reply With Quote
Old 03-10-2016, 02:57 PM   #303
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
why is this thread still alive. Let it die already.
The Following User Says Thank You to cdrazic93 For This Useful Post:
kritch (05-30-2016)
Old 03-10-2016, 07:33 PM   #304
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
But why kill it when I could instead kill my entire Thursday at work reading this, since it was bumped back to the top, and laughing to myself at times as I made it through the end from post #1!
I must say, I had to learn the hard way about driveshaft and pinion angles after drastically changing suspension geometry on another car (lowered it 7" lol) and I can associate with certain experiences about putting a load on a 2 peice vs 1 peice ds. I have also learned some new stuff today so thx for the very entertaining read...
Toyarzee is offline   Reply With Quote
The Following 3 Users Say Thank You to Toyarzee For This Useful Post:
cdrazic93 (03-10-2016), justatroll (03-11-2016), kritch (05-30-2016)
Old 05-31-2016, 10:23 AM   #305
kritch
kritch's Avatar
Drives: 2017 BRZ Limited PP
Ill tell you one thing. Im not going to buy an aluminum driveshaft now. No, not because of all the 'science' but, because I want to totally forget I wasted the few minutes I did reading this ridiculous thread. You are all wrong and to quote the principal from Billy madison:
Mr. Madison, what you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
kritch is offline   Reply With Quote
The Following User Says Thank You to kritch For This Useful Post:
Strife26 (04-17-2017)
Old 06-01-2016, 04:17 AM   #306
GT86_PRAGUE
Drives: GT86
Yeah, you wished this thread die, but you put it on top again
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
kritch (06-01-2016)
Old 06-01-2016, 12:28 PM   #307
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I love this thread. This thread loves me. That's why this thread has been very successful. Everybody loves this thread. People from this thread love me. And you know what, I have been very successful in this thread.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post:
cdrazic93 (06-02-2016), chaoskaze (06-05-2016), kritch (06-01-2016)
Old 06-02-2016, 08:04 PM   #308
Subaru86
Drives: subaru brz limited
Hahahaha
Subaru86 is offline   Reply With Quote
Lightweight aluminum drive shaft installed. stockysnail Northwest 18 02-05-2020 12:18 AM
Driveshaft Shop Aluminum Drive Shaft. FT-86 SpeedFactory Engine, Exhaust, Transmission 40 10-15-2015 10:11 PM
Invidia N1 interference with Driveshaft Shop aluminum shaft. xkalelx Engine, Exhaust, Transmission 6 03-03-2015 10:43 AM
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock Anthony@RWHP Transmission and Driveline 4 12-25-2013 09:09 PM
