Old 03-09-2016, 06:18 PM   #3557
ka-t_240
Originally Posted by ajc209 View Post
Thanks for your responses guys.
I usually go through a tank in the am session and refill at lunch before using another tank in the pm session. It looks like a 25l fuel container for trackdays might be a good idea so I can keep it topped up.
I ussually have about 20 gallons + a full tank when going to track days/weekends. But e85 is inconsistent and not available in close proximity to many tracks.
ka-t_240 is offline   Reply With Quote
Old 03-09-2016, 06:22 PM   #3558
ajc209
Drives: GT86 Cosworth
they have fuel at most tracks. either ron101 race fuel or ron97-99 but its over priced and im a cheapskate. Its all about shell V power nitro
ajc209 is offline   Reply With Quote
Old 03-09-2016, 10:18 PM   #3559
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Sounds like very generic information. Bleeding is completely dependent on each individual person's use. Rotor wear is the same.
The only thing you'd hurt by going to the XP12, is possibly overbraking yourself, but it's better to have too much pad, than not enough, as you've already learned.
With an advanced driver, you can still not have enough pad with the XP12. If you find yourself at that point, the real solution is a BBK.
The RE71R is a really, REALLY sticky tire, so it's easy to overheat the brakes, as you're stopping harder and faster with those tires.
Makes sense, thanks.
Apex_BRZ is offline   Reply With Quote
Old 03-09-2016, 10:35 PM   #3560
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Mike, considering I killed half of my XP10s in 4 hours of track time and destroyed the stock caliper dust boots and I was on stock tires...
I'm assuming you're going to strongly suggest a BBK since I have RE-71Rs and a proper alignment now (no more grating understeer that prevents me from getting on the power early) I did add the GT3 brake air guide things, but I doubt they're going to be anywhere near effective enough.
I was debating XP12s with Ti shims to protect the calipers because I don't really want to spend the money on a BBK this year, but I'm worried that'll be nowhere near good enough. I still have the stock wheels/tires I can use for track days and might do that anyway. I have ~20 hours of track time planned this year (split up between Shenandoah, Putnam Park & VIR) and a bunch of autocross.
The AP kit would set me back ~$2600 or so all said and done, or an RR kit for about half that (one piece rotors) but I don't know anybody REALLY fast that's using them besides Element Tuning.
Guess I'm just asking for confirmation that I should man up and get a BBK like you said here: http://www.ft86club.com/forums/showp...postcount=3167
Old 03-09-2016, 11:36 PM   #3561
CSG Mike
CSG Mike's Avatar
Try the XP12 first. 4 hours on XP10 for half the pad is actually not bad in terms of wear.
Shipping should be free if you order front/rear XP12 off of the CSG website.
Just take the outer dust boots out, and don't use the shims.
Old 03-10-2016, 09:41 AM   #3562
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Ok, that sounds like it'll work. If the XP12s don't work well enough next time I'm on Shenandoah I have time before I do Putnam Park (not too worried about there though, doesn't seem braking heavy) and plenty of time before VIR or back to Shenandoah.
I do really want a BBK though
Old 03-11-2016, 02:55 AM   #3563
ZionsWrath
Thanks
ZionsWrath's Avatar
I need a new battery. Should I just get a replacement or go for a lightweight one.
I usually just weekend drive my car so it sits 4-5 days at s time and parked maybe 4 months over winter.
I don't mind to buy a tender and remove the battery over winter. But i dont want to have to every week.
Old 03-11-2016, 10:24 AM   #3564
ja1217
Drives: 2004 Toyota RAV-4 5M
Seat Mounts
I'm taking the plunge and going full race car with my FR-S, but I've run into a small issue. I got a new Sparco Circuit II seat and with the supplied Sparco floor mounts the seat is too high up and I am going to have clearance issues, especially with a helmet and a roll cage.
I've seen some people go with Buddy Club seat rails to lower the seat, but I'm not sure they are up to the task of doing wheel to wheel racing safety wise. I know some people have them re-welded to make them stronger, which is an option I'm considering, but I'm wondering if there is a better option out there for something to lower the seat while being strong enough to rely on in wheel to wheel racing.
Thanks!
ja1217 is offline   Reply With Quote
Old 03-11-2016, 10:54 AM   #3565
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
I would go for the light one. If you drive every weekend it gonna be fine. With a tender it's just perfect.
I have been using them for a few years now, works fine. (Odissey)
I'll try a low cost Lithium one with the 86.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 03-11-2016, 10:57 AM   #3566
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Please post your results in your build thread. A buddy and I have been going back and forth about lightweight batteries lately. Buddy wants to get something different than Odyssey this time around and they only other experience I have is with AntiGravity.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 03-11-2016, 10:59 AM   #3567
MaximeT
MaximeT's Avatar
Yep sure. I'll probably try Shido. We find it locally on Amazon.
Old 03-11-2016, 11:10 AM   #3568
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Thanks for the tip. I had never heard of Shido. Time to do some research
Old 03-11-2016, 11:14 AM   #3569
MaximeT
MaximeT's Avatar
In the US Braille is the way to go I guess. Anthony is very happy with his 3lbs battery.
Old 03-11-2016, 11:18 AM   #3570
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
I've used Braille in my Honda days with good results as well.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
