Old 03-09-2016, 07:19 AM   #1
S84kam
S84kam's Avatar
Drives: FBRZS
Engine not starting
This morning I had a starting issue. I tried roughly 10x and the engine wouldn't turn over. I could hear the starter motor cranking the engine but it wouldn't turn over. Damn it was embarrassing.
I don't think it's a battery issue because I just replaced it with an optima battery.
I finally got the engine to start by turning the key and pressing the gas pedal.
On a side note. Now that this has happened. I'm listening to the engine and it sounds like faint pop corn noises.
EDIT
just got the car back, dealership can't replicate the problem WTF!?
S84kam is offline   Reply With Quote
Old 03-09-2016, 07:20 AM   #2
BRZnut
Drives: BRZ DGM Limited
sorry to hear. Any codes? Can you record the "pop corn" noise for us to hear?
Old 03-09-2016, 08:06 AM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Possibility of a misfire
Old 03-09-2016, 08:21 AM   #4
S84kam
S84kam's Avatar
Drives: FBRZS
no codes and the pop corn sound went away. I just dropped it off at the dealer and i'll be getting it this afternoon
not a missfire, did not throw a code
Old 03-09-2016, 09:04 AM   #5
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
On a barely related note, my 2013 FR-S cranks much slower than any other car I've owned, and always has. Starts no problem, even in subzero (F) temps, but it's weird hearing it go "vra..vra..vra...vra...vroooooom" instead of "vra.vra.vra.vra.voooom", if that makes sense. Anyone else notice the same thing?
Barry
MuseChaser is offline   Reply With Quote
Old 03-09-2016, 09:08 AM   #6
jasonojordan
Drives: 2013 satin white brz limited
your list of mods if any would help with a diagnosis.
jasonojordan is offline   Reply With Quote
Old 03-09-2016, 09:19 AM   #7
S84kam
S84kam's Avatar
Drives: FBRZS
Mods - stock
edit -
ok dealership calls me, tells me nothing is wrong with the car and they couldn't replicate the issue.... I'm really starting to doubt the reliability of this engine
Old 03-09-2016, 02:49 PM   #8
EDIT
I'm sort of confused. You said you "heard the starter motor cranking but the engine wouldn't turn over". If the starter motor is cranking but the engine wouldn't turn over, that would indicate that the starter is not engaging the flywheel or the flywheel has a tooth missing.
Did you mean that the engine would crank over but not fire .. ??
Even though your battery is new, maybe it isn't getting re-charged by the alternator....?? Here is a simple test:
http://www.aa1car.com/library/battery_runs_down.htm
Old 03-09-2016, 03:27 PM   #9
Elkton86er
Elkton86er's Avatar
Drives: 2014 Subaru BRZ Limited WRB AT
EDIT
Sounds like the engine was "flooded" - or whatever the equivalent for fuel injected cars is. Classically, the solution for starting a flooded engine (with a carburetor) was to crank it with the gas pedal held to the floor - seems counter-intuitive, but it works by holding the throttle air intake wide open. Symptom and solution both match.
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips
Elkton86er is offline   Reply With Quote
Old 03-09-2016, 03:30 PM   #10
S84kam
S84kam's Avatar
Drives: FBRZS
what could cause our cars cylinders to be flooded?
OK i meant to say it cranked and cranked but didn't fire up
Old 03-09-2016, 03:49 PM   #11
"Flooding" is usually caused by too much fuel and not enough air. Or, the plugs don't fire.
OK, cranked but didn't fire. I'd give it a second chance ...... maybe the ECU was having a bad day .....
Old 03-09-2016, 04:04 PM   #12
S84kam
S84kam's Avatar
Drives: FBRZS
that doesn't damage our spark plugs right? because everyone knows how much of a pain in the ass they are
Old 03-09-2016, 04:10 PM   #13
jasonojordan
If enough fuel was able to enter it could foul the plugs yes. I find this highly unlikely to be whats going on though.
Old 03-09-2016, 07:24 PM   #14
I don't see much mystery here. Circumstantial yes but may be something as simple as a not quite tight enough cable or slightly dirty connection.
starting out dmitri93 Scion FR-S / Toyota 86 GT86 General Forum 30 07-11-2014 12:06 AM
Rev when starting ? (Possible and why ?) Simon99 Software Tuning 11 05-22-2014 04:12 AM
just starting out mortachi Cosmetic Modification (Interior/Exterior/Lighting) 3 10-06-2013 10:23 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Starting it off e10rice Mid-Atlantic 93 03-26-2012 03:16 PM
