Old 03-08-2016, 08:13 PM   #29
Crazypinoy9
Drives: FR-S TRD RS1#1488
Originally Posted by kbye View Post
maybe so but torque > HP any day. you can't get that on E85 alone
Ya that's very true. And we all know that this car has a huge shortage in that regard lol
Crazypinoy9 is offline   Reply With Quote
Old 03-08-2016, 08:25 PM   #30
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I have yet to see a turbo'd frs that was slower than an n/a frs car...
Also, I will never believe any dyno that shows an n/a frs hitting 220 lol.
Again, can't really compare different dyno numbers and expect any accurate comparison.
Old 03-08-2016, 08:39 PM   #31
Crazypinoy9
I can agree with you that 99.9% of the time a turbo FRS will indeed be faster than an NA. And while your statement is true about different dynos reading differently it doesn't necessarily make the numbers that I posted unbelievable and untrue. A lot of things can be done with a capable tuner. That one was tuned by Church.
Also note that I stated it was on a dynapack. Same as this guy's Works Turbo Car so the numbers are reading high. I find it hard to believe that the margin of difference between these two dynapacks to be THAT drastic to say that the NA car run could be so much lower. Because for all we know the Works Turbo kit could be actually lower as well.
Lastly, if you go back through my posts in this thread I never stated anything about the NA car being faster...I was comparing power outputs and associated cost comparisons.
Old 03-08-2016, 10:22 PM   #32
stevo585
Drives: White 2014 BRZ
Originally Posted by Mr_YUzU_FRS View Post
Still doing research and looking for someone local to work on a flex fuel kit and tune with this turbo kit. All I'm asking for is to stay in the 250-300 whp mark and I'm happy. But like I said, my butt dyno tells me its more than 210 whp. Been in cars around the same power range and doesn't seem as fast or fun to drive.
I know this car is not made for drag racing but I will probably hit the drag strip soon just to see what it can do on 0-60 and 1/4 mile run. There is a drag strip in town and why not, it will be fun. Currently still have the stock rims, with Michelin Pilot Sport AS/3 tires.
Yes the track can give you a mathematical calculation of power using trap speed and weight.
Here: http://www.wallaceracing.com/et-hp-mph.php
I did 13.8 @ 101 (2900 lbs w/me) with the ESC at around 4.5 psi tapering to 1.5 psi.
This calculator says I have 230whp.
NA I ran 14.3 @ 96.5
This calculator says I have 200 whp. Seems like reasonable numbers to me.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 03-08-2016, 11:05 PM   #33
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Wtf is with that torque curve?
Old 03-09-2016, 04:22 AM   #34
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
I was looking at that too, torque maxed out really early then a big drop and up again. Maybe an expert or someone with more knowledge can explain why. Is it the tune or something else?
Mr_YUzU_FRS is offline   Reply With Quote
Old 03-09-2016, 02:07 PM   #35
s2d4
s2d4's Avatar
Dyno Chart. Sorry for double post. 208.2 whp & 198.4 lbft tq
Yeah, I would rip that kit out after seeing that dyno chart.
Old 03-09-2016, 02:12 PM   #36
CSG Mike
CSG Mike's Avatar
The turbo is choking the engine once it is spooled.
The curve is similar to that of a stock STI or Evo.
Old 03-09-2016, 02:40 PM   #37
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
^Yep, Mike beat me to it, typical torque curve for a small-ish turbo. Plus, I think the scaling makes it look really weird compared to a regular "wide" scale, which flattens out the curve. Here's a stock STI for comparison.
Tbh, I really don't understand all this hostility towards WORKS when they are the only ones who stepped up to provide a CARB legal turbo and have been nothing but helpful to their customers...
Old 03-09-2016, 03:52 PM   #38
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
The "hostility" is that I CANNOT justify spending 7K like the OP did and get "208.2 whp & 198.4 lbft tq"
Honestly 208whp? I been seeing threads where people are getting close to those numbers on an NA setup, yeah it's probably not CARB but it just doesn't make sense to me if CARB is a reason and you live in CA there's SC kits out there that are CARB and output MUCH better numbers. JRSC and Edelbrock for example, I just don't understand it from a price perspective.
EDIT
So I looked up how much the CARB Stage 2 kit is
http://store.worksmotorsports.com/WO...p/142.212c.htm
So 5K, and the OP paid 6800 with installation and all that. That's fair, but you can pay that same price for a CARB JRSC or Edelbrock and have better numbers. If the OP is happy then he's happy because now he's turbo'd and has torque now. I still just don't see it from a price perspective.
Alltezza is offline   Reply With Quote
Old 03-09-2016, 04:55 PM   #39
Yoda
Drives: Crystal Black BRZ(Sophia)
EDIT
Good thing it's not your money. Looking at the dyno its what I would expect for a carb turbo kit and that tq looks real nice too. Maybe if they changed the turbo you can get more power but that prob would affect their CARB cert. You have everything you need for a DD.
Yoda is offline   Reply With Quote
Old 03-09-2016, 05:40 PM   #40
continuecrushing
this "208whp" thing is way blown out of proportion.
on that SAME dyno, what would another kit put down for whp? Thats the only way to compare. If the turbo's car put down 208, I guarantee that n/a cars are putting down low 120/130/140's probably.
hp/tq #'s are way too important on this forum(probably because they're low haha...gotta make ourselves feel better) but GAINS before/after tuning/mods/turbos/superchargers etc are the only accurate way to see exactly that, GAINS.
Buying this car and making it "fast" isn't smart from a money perspective.
Plus, this is the ONLY carb legal turbo kit out...CARB cert. is where all the money is going lol
Old 03-09-2016, 06:04 PM   #41
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes changing the blower would require re-certification. Compare Jackson Racing's two kits and the C38 has a different CARB EO# than the C30 (D-700-5 vs D-700-2).
Since Works is sitting a few hundred yards away from Sonoma Speedway I bet they tried a few different turbo sizings. With the centrifugal systems emphasizing power late in the rev range and the positive displacement blowers working best in the middle, it makes sense for Works to develop a small turbo system that delivers fat torque comparatively early in the powerband instead of trying to beat the already established superchargers by making a kit with pretty dyno numbers and sacrificing the driving experience by introducing a noticeable amount of turbo lag, it's an 86, not a 930 or a Supra. They'd end up with dynos that look nice for the benchracers and a bunch of reviews saying "but dat turbo lag".
Surely someone determined to prove a point will show that the Works kit makes more torque at 3k-4k rpm than any other CARB kit and stays competitive until the Rotrex kits come on at >5k rpm. Hell their peak wheel torque is shown as being ~20 ft-lbs over the Edelbrock kit, and arriving ~1k rpm sooner.
If you want that early wave of turbo torque in DD-able, reliable, and street legal trim looks like Works has your answer.
ineedyourdiddly
Old 03-09-2016, 06:31 PM   #42
s2d4
s2d4's Avatar
Personal preference and that's what I would do, sorry if that is wrong in your book.
WORKS Stage 2 Turbo Kit - Now CARB Compliant/SMOG Legal WORKS Forced Induction 415 10-16-2021 05:55 PM
Works Axle Back Muffler Review (Works ABM) ButeraFRS Engine, Exhaust, Transmission 16 03-15-2018 06:23 PM
WORKS Stage 2 Turbo Kit - Official Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 89 01-13-2017 04:41 PM
CARB Compliant WORKS Turbo Kits - Now Available! 50-State Smog Legal! WORKS Forced Induction 47 01-13-2017 04:40 PM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
