| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#30 |
Drives: GT 86
#31 |
Not a troll
#32 |
Drives: FR-S Whiteout
That's not bad at all! With dual valves too. Where do they have wheel weights posted? I'd rock those GTFO wheels. lol
Edit: NVM 15.5 for the 17x8's... not too shabby. seems like the price is right too.
Intent > Content
cowardice is the mother of cruelty. |
#33 |
Drives: GT 86
#34 |
Not a troll
#35 |
Drives: BRZ limited GBS
i had to buy my wheels through a distributor in canada, then shipped to california.
#36 | |
Drives: '13 FR-S w/ P&L turbo
Does it look like you'd be able to run 255/40-17's? What camber specs are you at? Do you think there's clearance for STI brembo calipers? what vendor did u go through to get your wheels and how long did you have to wait? I was thinking about seeing if I could get them through 1010tires.com but maybe there's a forum sponsor that would be better to buy from? Thanks for the info |
#37 | |
Not a troll
I could run 255/40's probably, but there might be rubbing issues. Right now, I'm at -2.5F and -2R for camber. I have a slight rub in the front (tire on spring) so I ordered some 3mm spacers to fix that. If they end up rubbing on the fender after spacers, I'll dial some camber out, and run -2F and -1.5R. I've heard that these will clear the STi Brembo's, but don't have first hand experience. Bought the wheels through a local shop who only carries DAI wheels. I waited almost 2 months for them to come in. 1010Tires is a good option if tney have them in stock. I don't think many vendors carry these in the US, might be forced to order from a Canadian shop. |
| The Following User Says Thank You to Cole For This Useful Post: | Dylan0123 (03-07-2016) |
#38 | |
Drives: 14 FRS Whiteout
#39 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
What were your alignment settings in these photos?
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
#40 | |
Drives: 2013 frs; 1988 porsche 944s - > 948
quick question on your wheels
my big question is how much is your ride dropped? i am only ever looking to go to an eibach lowering springs which varies from .8" to 1" and then some SPC camber bolts up front and SPC LCA's for the back. my car is a daily driver even through winter so not looking to slam it, just combat the 5mm or so of baja lift and close a little wheel gap. let me know if i am a little loonie for trying to go to 255/40 with stock coils.
#41 |
Drives: 2014 Subaru BRZ LTD 6MT
| The Following User Says Thank You to ajaxthebetter For This Useful Post: | Keenercarguy (07-23-2016) |
#42 | |
Not a troll
I'm on Tein S-Tech springs, so I think it's 1.2" front and 1.4" rear, but I could be wrong. 255 should fit, but you won't be able to run as aggressive of an alignment. |
| 720Form GTF2 18x9 +35 | Canehda | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 07-18-2016 01:25 PM |
| 720Form GTF1 17x8.0 +35 | Talus1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 01-02-2016 01:28 PM |
| WTB: 720Form GTF1 or GTF2 wheels | sachu | Want-To-Buy Requests | 1 | 02-27-2015 12:49 PM |
| WTB: 720Form GTF1 or GTF2 or Rota Titan | sachu | Want-To-Buy Requests | 0 | 02-26-2015 08:11 PM |
| 17x9 +35 720Form GTF1 installed! | BRZZZZZZZZZZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 06-27-2014 07:12 PM |
