Old 03-05-2016, 11:59 AM   #1
Cole
Not a troll
Cole's Avatar
Project Kics 3mm Spacers
Tried searching, couldn't find much info.
So, some quick backstory here, I recently purchased 17x9+35 wheels and 245/40 tires. They fit really well, apart from some slight rubbing on the front spring.
My suspension set-up: Stock struts with Tein S-Tech springs, SPC LCAs and camber bolts and SilverProject top hats. I currently have camber right around -2.5 up front and -2 in the rear.
Ideally, I don't want to have to get another alignment if I can get away with using a 3mm slip on spacer. What I want to know is, has anyone used a small spacer before and had any ill effects? With the price of the spacer, it's a lot less than getting an alignment, but if it's going to be detrimental, I'll do the alignment.
I guess the other option is to dial back the camber a bit, but again, rather not do that if I don't have to
Cole is offline   Reply With Quote
Old 03-05-2016, 05:07 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
You should be totally fine with a 3mm spacer. You'll only run into problems if you use gigantic spacers... but that's another story.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Cole (03-05-2016)
Old 03-05-2016, 09:19 PM   #3
CSG Mike
CSG Mike's Avatar
PM @CounterSpace Garage for spacers.
Old 03-05-2016, 10:00 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Been using these in front for a few years with no issues:
http://www.amazon.com/5x100-Hubcentr...7233220&sr=8-2
Originally Posted by humfrz
I'm old and lazy
Cole (03-05-2016)
Old 03-05-2016, 11:29 PM   #5
Cole
Not a troll
Cole's Avatar
Ended up going with the Kics.
@CSG Mike couldn't justify buying from an American company when I found what I wanted from a Canadian company at an extremely competitive price. Plus this way I know that I won't get hit with extra fees on delivery
Old 03-06-2016, 11:03 AM   #6
wparsons
wparsons's Avatar
If you ever need spacers again, look up Novustech. They're a local company (based out of the Kitchener area).
You'll be fine with a 3mm spacer, the only other option would be to back off the camber at the knuckle and add more at the top mount.
flickr
Cole (03-06-2016)
Old 03-06-2016, 01:18 PM   #7
Cole
Not a troll
Cole's Avatar
Top mount is maxed out, same with the camber bolt. Depending on clearance with the spacer, I may just go back to the OEM bolt instead of the camber bolt.
Just checked out Novustech real quick, they only go down to 5mm. I probably could have went with something custom from them, but I'd like for it to not start costing a lot of money
The Following User Says Thank You to Cole For This Useful Post:
wparsons (03-06-2016)
Project kics conversion spacers Kwise1 Scion FR-S / Toyota 86 GT86 General Forum 3 08-25-2014 12:17 AM
Project Kics 5x100 to 5x114.3 Conversion Spacers 11mm smellslikecurry Brakes, Suspension, Chassis 0 08-22-2014 02:34 PM
FS project kics 11mm wheel adapters/spacers mikey_BRZ Wheels and Tires 4 02-12-2014 10:59 AM
Discover over 50% in savings on these two Project Kics Spacers (Sold in Pairs) FRSport.com Announcements, Contests, Giveaways 2 01-16-2014 04:16 AM
Wheels Spacers: Ichiba / Kics Project / FIC / H&R / Altrac Touge Factory Wheels and Tires 6 11-20-2012 12:37 PM
