Old 03-04-2016, 11:52 PM   #1
illmatic_frs
illmatic_frs's Avatar
Drives: n/a
Phantom ESC vs. Sprintex/Innovate
Hi all,
I thought I was set on waiting for a Phantom ESC (w/procede) - but recently the Sprintex/Innovate was put on my radar. They are different in approach (belt vs. battery) but seem deliver almost the same performance results.
These are the comparison points guiding my decision (in no particular order):
- under $2.5k
- can bolt it on myself in half a day (i.e. no intercooler hassle)
- can tune it with OFT
- goal of 200 whp and smooth torque throughout
- low/no maintenance
- holds resale value, as I'll sell when my lease is done in 2 years
As per my 'quick compare' analysis they both seem to line up well against the above criteria. So how to decide? Any suggestions on how to tip the scales in favor of one or the other...?
cheers.
illmatic_frs is offline   Reply With Quote
The Following User Says Thank You to illmatic_frs For This Useful Post:
DAEMANO (03-05-2016)
Old 03-05-2016, 12:45 AM   #2
stevo585
Drives: White 2014 BRZ
The ESC is ok, I have one (no procede, used kit). Its basically NA plus some more pull. Mostly alot more midrange torque. If you look at HP calculators (mathematically) they range from 215-230whp if you input my 1/4 mile of 13.8 @ 101 weight of 2900lb.
One big advantage its alot cheaper and simpler than the basic sprintex kit. It installs in less than 2 hours going very slow. Disadvantage would be it has no upgrade path. My tuner did compare it to the sprintex actually in "street feel" as we did pulls and tuned on the street. He has tuned many sprintex kits and only my ESC.
You can hit 200whp NA you know. Less torque though of course.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo585 For This Useful Post:
DAEMANO (03-05-2016), illmatic_frs (03-05-2016)
Old 03-05-2016, 01:07 AM   #3
swarb
Where did you find the sprintex for 2500?
Old 03-05-2016, 07:53 AM   #4
WNDSRFR
Drives: FR-S,GTI
A big advantage of the Sprintex is you can get one tomorrow. You're looking at a two year wait for the Phantom if you order it today. Your lease will be up before you ever see the ESC.
The Following 4 Users Say Thank You to WNDSRFR For This Useful Post:
DAEMANO (03-05-2016), illmatic_frs (03-05-2016), raven1231 (03-06-2016), zc06_kisstherain (03-05-2016)
Old 03-05-2016, 11:47 AM   #5
illmatic_frs
Drives: n/a
In the classifieds
Two recently were up
Sent from my HTC One M9 using Tapatalk
Old 03-05-2016, 12:08 PM   #6
DAEMANO
Time Traveller
Or @illmatic_frs could buy @Lord09 's Phantom ESC right now in the classified section for $1850 OBO (w/ PROcede controller - $2250 OBO).
http://www.ft86club.com/forums/showthread.php?t=100623
@illmatic_frs
@stevo585 basically has it nailed here. The Phantom ESC is cheaper, probably more reliable, has a better torque curve, and is easier to tune with a pretty well dialed in off-the-shelf Open Flash Tablet tune. I'd highly recommend getting the PROcede as it upgrades the pedal switch and refines the whole package making it into full time F.I.
As far as power output goes, here's my Phantom ESC car dyno'd and compared to 10 other cars on the same dyno and on the same day (some F.I., and many N.A.). There were no Innovate kitted cars that day. Anecdotally, 2 people that I discussed F.I. with that day seriously panned the Innovate kit on reliability. It was a hot and very humid day so all cars were slightly down on power (about 5-8% from what others reported). The 2 Phantom ESC equipped cars absolutely killed it that day on torque and price/performance ratio.
http://1drv.ms/1ExGyBX - Full spreadsheet (the detail tab (second tab) has nearly everyone's mods).
http://www.ft86club.com/forums/showt...t=93180&page=5 - Dyno sheets to compare torque curves, plenty of pics and vidz.
The Following 3 Users Say Thank You to DAEMANO For This Useful Post:
illmatic_frs (03-05-2016), Lord09 (03-05-2016), Teseo (03-06-2016)
Old 03-05-2016, 12:57 PM   #7
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by illmatic_frs View Post
Hi all,
- under $2.5k
cheers.
Im a perfect candidate to weigh in on this, I've had the ESC and I currently have the sprintex kit.
OP, the ESC will be exactly what you need. It is PERFECT for daily/canyon stuff. Every one of your "requirements" are checked off by the esc. I had v1 of the phantom kit for about 6ish months?(maybe longer lol, can't remember) and it worked flawlessly. Once installed, there is no maintenance, its easy to install, provides very smooth power-and will hands down be faster than any n/a frs/brz.
The sprintex kit will give you more power, and pull much harder up top, but is much more expensive. Also, you need to keep an eye on the belt+oil for the supercharger-so maintenance is required(albeit not terribly often). Plus, even if you find a sprintex kit for 2500, you still need an ecutek tune.
Go with the ESC, if you change your mind after buying it, sell it. But, it will definitely put a smile on your face, and pretty much solves the this car is so slow problem!
Only reason I got rid of my esc was because I thought I might sell the car. I ended up not haha.
With that said, supercharger whine sure is nice...
[ame="https://www.youtube.com/watch?v=6PrOSM0ZpcA"]FRS Innovate Sprintex Supercharger Whine Drive By - YouTube[/ame]
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
DAEMANO (03-05-2016), raven1231 (03-06-2016), Teseo (03-06-2016)
Old 03-05-2016, 01:36 PM   #8
kev60625
Drives: 2013 WRB Subaru BRZ
How much more power would a esc with full bolt ons make? I make 35whp over stock, would I see a really nice gain with the esc? Thanks
kev60625 is offline   Reply With Quote
Old 03-05-2016, 01:59 PM   #9
continuecrushing
lets try not to thread derail, but this thread has cars, mods and how much power they make in a pretty table.
But put bluntly, a fully stock car with OFT+ESC would blow your car away. Even if redline numbers were close(between the esc car and your bolt on car), the 2.5k-5.5k powerband of the ESC car makes quickly leave you in the dust.
http://www.ft86club.com/forums/showthread.php?t=66862
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
DAEMANO (03-05-2016), Teseo (03-06-2016)
Old 03-05-2016, 02:12 PM   #10
kev60625
For sure, sorry! Thanks for the info
Old 03-05-2016, 02:19 PM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Where do you even get the sprintex now? Everywhere says discontinued or out of stock
Old 03-05-2016, 02:24 PM   #12
juliog
juliog's Avatar
Drives: 86
Doesn't the ESC run out of juice in less than 20 sec at WOT?
juliog is offline   Reply With Quote
Old 03-05-2016, 02:56 PM   #13
continuecrushing
What? No. like 120ish seconds. With the regular charger/controller, you probably won't ever run out of power, and with the aux charger added on, you'll never* run out of power for the ESC. Driving on the street/canyon/autox, you won't run out of power with the ESC (unless you're doing some a-hole thing and doing top speed runs on the freeway repetitively).
Plus, 20 seconds on WOT in the frs/brz would be hitting like 55 maybe even 60mph. JK.
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 03-05-2016, 05:52 PM   #14
DAEMANO
Time Traveller
@Shutter
Yep, exactly. I still have yet to find the boost "limit" on my car, but can say with confidence that it's clearly not 20 seconds.
@juliog
Even if it is/was just 20 seconds, think about it this way. The couple of Phantom ESC owners that have posted drag slips averaged 13.85 seconds @ 102.5 MPH in 1/4 mi. Keeping foot to floor for 20 seconds would probably put someone in the range of 145-150 MPH at somewhere in the 3/4mi - 1mi mark. The only place where this could be accomplished or tested safely in the real world (on a non-public road) is likely a banked speedway like Autoclub in Fontana.
At the kind of closed circuit tracks and autocross courses we have in SoCal, there are mostly periods of WOT, that last 0-8ish seconds (at the most) followed by heavy braking. WOT, Brake, WOT, Brake, repeat. The ESC recharges itself during braking, reaching 75-80% capacity ~27 volts range quickly (and even faster with an Aux charger accessory). Ready, as it should, to provide more boost when the driver gives more throttle.
What I'm getting at is that there is still some old or bad info out there regarding the current version of the Phantom ESC. Really there are very few disadvantages a 4.5-5 psi Phantom ESC kit w/PROcede controller has to a ~7 psi conventional SC or turbo kit on public roads and during some pretty aggressive driving.
The Following User Says Thank You to DAEMANO For This Useful Post:
continuecrushing (03-05-2016)
Trying to find the Intercooler Kit for a Sprintex 210 or Innovate Kit. Cross Forced Induction 9 06-11-2015 10:04 PM
Innovate/Sprintex Supercharger erbaker67 Engine, Exhaust, Bolt-Ons 6 05-27-2015 07:54 PM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
