Old 03-04-2016, 04:17 PM   #253
Andew727
Drives: Scion FR-S
Originally Posted by wbradley View Post
I don't think it's that much smaller than stock. I think last summer I had calculated it was good for maybe another 1 -1.5 PSI. I'll double check it this weekend but probably not what you're after.
stock v1 size was 110mm i believe. The V2-V3 are 100mm and the smallest being 90 making 17 psi
Andew727 is offline   Reply With Quote
Old 03-04-2016, 04:19 PM   #254
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
V3 stock pulley is 110mm. The pulley upgrade is 100mm.
Torry@HKSUSA is offline   Reply With Quote
The Following User Says Thank You to Torry@HKSUSA For This Useful Post:
CxG (03-05-2016)
Old 03-04-2016, 04:23 PM   #255
wbradley
Sarcastic SOB
wbradley's Avatar
Pretty sure the V1 stock pulley is 100mm and mine makes ~8.5 PSI.
There's NO CHANCE a 90 mm makes 17 PSI!! Maybe it adds 11% to the 100 mm.
Old 03-04-2016, 04:28 PM   #256
Andew727
Drives: Scion FR-S
says 17 psi on my box for the 90mm this all depends on pressure drop and efficient pipe bends so on... the smallest is 80mm, i just checked. i need that. and stock V1 is 100mm, v2-v3 are 110
Old 03-04-2016, 04:52 PM   #257
wbradley
Sarcastic SOB
wbradley's Avatar
Maybe up to 17 PSI with the largest HKS supercharger.
So what is the stock boost for V1, V2 or V3 then? I am positive they are under 10 PSI, and most likely 8.5 PSI which is the peak I am seeing. That is pretty much the safety zone without fuel upgrades. or E85.
Using C= 2Pi*r, there's no way reducing diameter by 10% doubles RPMs. Boost should be directly proportional to C.
So, @ 100 mm, C=2*3.14*50mm, C=314mm
then @ 80mm, C=2*3.14*40mm, C= 251.2
Then 251.2/314=0.8, which is 25% smaller circumference of 100 mm.
If boost @ 100 mm is 8.5 lbs, then 80 mm should blow 8.5 * 1.25= 10.625
So, we might be pretty close to 350 on E85 as previously stated by Torry.
Keep in mind this is without considering things like pipe diameter resistance, etc, just a basic estimation.
Old 03-05-2016, 06:00 PM   #258
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Originally Posted by zeal86 View Post
If anyone is running any of these configurations or close to any of these, please comment on the tone, drone, rasp, and power made. My biggest concerns being great sound and safe power.
Thanks in advance
Im running a HKS EL Exhaust Manifold + Tomei Joint Pipe + HKS Front Pipe + HKS Hi Power rear exhaust.
Basically its the Super Exhaust system and I added the Tomei pipe. The headers are heat wrapped and the car is NA. Mulling s/c options and want the HKSv3 but availability in NZ is tough.
Sounds like a tractor below 2k rpm
Some drone at 3K rpm
After 4K rpm the tone is deep and quite enjoyable to say the least
Some pops and bangs coming off throttle lower down the rev range
Over 6K rpm it just howls with a little bit of rasp coming off throttle
Ive not put a tune on it yet. Torque wise there is definitely more pick up mid range. The dip definitely still there but its smaller for sure. After 4k rpm its pulling harder but I couldnt quantify it beyond my finely tuned butt dyno
I love it. Its a classy piece of kit.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
The Following User Says Thank You to Metabrz For This Useful Post:
zeal86 (03-17-2016)
Old 03-06-2016, 12:50 AM   #259
zeal86
zeal86's Avatar
Drives:
Which sealed intake systems (if any) are confirmed to fit with the HKS v3 supercharger kit?
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 03-07-2016, 08:34 AM   #260
Andew727
Drives: Scion FR-S
i reach 9.5 psi indicated w/ the stock setup and restrictor plate in.
our goal is over 350 whp im using a vertical 600 hp intercooler (low pressure drop) no restrictor, and e85. i was hoping to see 400on the smallest pulley , but probably not with the pipe layout i have.
Old 03-07-2016, 08:49 AM   #261
wbradley
Sarcastic SOB
wbradley's Avatar
Up on observation, my V1 seems to max out at 9 PSI with restrictor plate deleted and stock 100 mm pulley.
I wonder how much more PSI (if any) you could max out without the restrictor on the current set up?
I am guessing based on my calculation that the restrictor deleted will result in 10 PSI max. And also, I am guessing an 80 mm pulley will result in 11.25 PSI without the restrictor.
A blower that produces 17 PSI with an 80 mm pulley would roughly produce 13.4 PSI with a 100 mm pulley. That might be the HKS supercharger model 8555. It's good for 300-550 HP.
The Following User Says Thank You to wbradley For This Useful Post:
CxG (03-07-2016)
Old 03-07-2016, 02:47 PM   #262
Andew727
Drives: Scion FR-S
i guess we will have to wait and see. evasive tuned a V1 car with a 90mm pulley and they got 13-14 psi i was told. i would think 20mm has to do much more than 1 psi. has nobody else used different pulleys in here with knowledge?
Old 03-07-2016, 03:21 PM   #263
wbradley
Sarcastic SOB
wbradley's Avatar
The math is pretty simple if I am correct that boost increases directly proportional to pulley speed. A pulley that is 20% smaller circumference needs to spin 125% the speed of the larger pulley at a given engine RPM. So that means 25% more boost.
Therefore, if my 100 mm blows 9 PSI and is functioning normally then an 80mm blows 11.25 PSI without a restrictor.
The only other possibility is if there is a leak in my intercooler or charge pipes, in which case I would probably have other issues and hear it hissing.
Old 03-08-2016, 08:33 AM   #264
Andew727
Drives: Scion FR-S
i just cant believe that nobody has a small pulleyother than us without numbers haha ... boost pressure has many variables though. the compressor might move 25% more air through it, but that doesnt mean it generates that amount of boost pressure. we will have to wait and see what i get i guess. i wanted at least 12 psi. or im selling this compressor haha
Old 03-08-2016, 05:43 PM   #265
86Tony
Drives: 2015 AOZORA EDITION
whats the pulley option for the kit, i see a 80 70 and a 60mm will those work with the blower? also is there any way possible to fit the gts8550 blower on the v3 kit?
86Tony is offline   Reply With Quote
Old 03-08-2016, 05:59 PM   #266
wbradley
Sarcastic SOB
wbradley's Avatar
I think other than the stock 110 mm pulley with the V3, you can get 100, 95, 90, 85 and 80 mm pulleys. It is on the HKS website.
The bigger blower is sold as a stand alone generic unit if you want to fab your own kit. That requires you configure the mounting plate, select and configure pulleys, piping, etc.
There are shops that could do it if you can pay but that's an awful big supercharger for this motor on a 12:1 CR. You probably need to change the bottom end, and go to 10.5:1 CR, as well as fueling, clutch, etc etc. In Canada I am guessing it will cost $20K easily. At that point I'd be more inclined to just get a big turbo and call it a day.
My 215 PSS are having a tough time getting traction as it is!
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
