Old 03-04-2016, 01:49 PM   #1
iNcontroL
Drives: 2014 Scion FR-S Monogram (Whiteout)
Changing fluids for the first time
Hey guys,
I wanna change my car's fluids myself for the first time. I plan on going with Motul but I don't know exactly what I need. I haven't changed fluids in the 18 months that I've owned the car beyond what they've done at Service and it's at around 14,000 miles.
Could anyone tell me which Motul to use for which fluid change and how much I'd need to buy if I want to drain the fluids and replace it completely? Thanks!
iNcontroL is offline   Reply With Quote
The Following User Says Thank You to iNcontroL For This Useful Post:
johnowow (01-16-2024)
Old 03-04-2016, 01:52 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by iNcontroL View Post
Hey guys,
well what exactly are you going to be changing?
Engine oil?
Trans fluid?
Diff fluid?
Brake/master cylinder fluid?
Instagram: trevor.parque
Old 03-04-2016, 02:19 PM   #3
MT or AT ..... ??
PS - I believe your owners manual will give you the information on fluid capacities (p. 340+).
Old 03-04-2016, 02:27 PM   #4
iNcontroL
MT and I planned to do Engine, Differential, and Transmission. Unless you guys think it's a good idea to do break fluid as well?
Old 03-04-2016, 02:28 PM   #5
MisterSheep
Killed Scion
do the brake fluid just to better performing fluid. Might as well do SS brake lines and pads as well while ur at it.
Old 03-04-2016, 04:48 PM   #6
iNcontroL
So which Motul products will I need to change the fluids on those?
Old 03-04-2016, 06:48 PM   #7
_gt86_user
Inactive
Drives: .
Gear300 for the diff and trans and just pick your favorite for the engine, you need about 4qts to do the trans and diff.
_gt86_user is offline   Reply With Quote
Old 03-04-2016, 10:18 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Search. Use it, love it, die by it.
Old 03-05-2016, 12:06 PM   #9
menikmati
Drives: 2015 BRZ, 2005 STI
Check out the DIY section of the forum for all the procedures and recommendations.
menikmati is offline   Reply With Quote
Old 03-12-2016, 01:54 AM   #10
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
SS brake lines are pretty pointless.
Otherwise, I use Amsoil. Any good oil will work fine though.
First time changing oil Jonathanlim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 01-23-2016 05:38 PM
Motul fluids Filipino Royale Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 88 04-20-2014 10:36 PM
Mixing Transmission Fluids? l0aded Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 06-27-2013 02:45 PM
How often are you changing fluids? smbstyle Tracking / Autocross / HPDE / Drifting 2 06-07-2013 11:56 AM
When to replace the following fluids in the BRZ? chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 05-12-2013 01:17 PM
