Old 03-04-2016, 08:47 AM   #925
Sargy
Long Distance Driver
Sargy's Avatar
Special thanks to @CSG Mike for all the help again!
Looking foward to see how this will do on a 4.8 Final drive. Some fun times will happen this year. Plan is to get Hydra EMS tuned on E85 from @Element Tuning
Sargy is offline   Reply With Quote
The Following 4 Users Say Thank You to Sargy For This Useful Post:
CSG Mike (03-04-2016), Nitro22 (03-04-2016), NotSoJDM (03-04-2016), Uplink (03-04-2016)
Old 03-04-2016, 01:00 PM   #926
kch
Senior Misanthrope
kch's Avatar
Fancy. Aside from the advantage of real-time tune adjustment, why would one go with a standalone ECU? I'm just trying to learn as much as I can.
Old 03-04-2016, 02:59 PM   #927
Uplink
Uplink's Avatar
Drives: anything you let me
You're gonna want to see if Tire Rack will let you run a tab.
Uplink is offline   Reply With Quote
The Following 2 Users Say Thank You to Uplink For This Useful Post:
CSG Mike (03-04-2016), Sargy (03-04-2016)
Old 03-04-2016, 03:56 PM   #928
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
So, does anyone have a stock 86 with the supercharger and have been to the track. How was the experience? Did you notice any concerns with handling on the stock tires? Did the back end breakaway easier or was it progressive still?
I would be very interested in any comments you may have...positive or negative.
Cheers!
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 03-04-2016, 04:17 PM   #929
CSG Mike
CSG Mike's Avatar
Cheers!
Thats a function of your tires and suspension, not the supercharger.
Old 03-04-2016, 05:49 PM   #930
toast
Drives: 14 BSP Edelbrock BRZ
If you are a meathead with the throttle it can be a function of the SC since a stock car doesnt have the nuts to break traction even when sideways at the limit
Sent from my Nexus 6 using Tapatalk
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
paiceyfan (03-04-2016)
Old 03-04-2016, 06:04 PM   #931
paiceyfan
paiceyfan's Avatar
Sorry...not explaining myself very well...does the extra power and how it is delivered alter the way the car handles. Surely, if the power comes in quicker, then the quicker the tires can break away and alter the whole reaction time element or am I wrong on this?
Sent from my XT1031 using Tapatalk
Old 03-04-2016, 06:12 PM   #932
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
The power is pretty linear, strong of course but linear ! With stock shitty michelin primacy it's hard to handle the car with stock power so with 300hp and 310nm, damn it will be hard ! The handling of the car is better for me cause you don't have the great canyon torque dip so no surprise when power and torque comes. There power and torque are everywhere !
Better handling 100% !
Paulo86 is offline   Reply With Quote
The Following User Says Thank You to Paulo86 For This Useful Post:
Old 03-04-2016, 07:06 PM   #933
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
^This. The nice thing about this kit (actually, most SC kits) is the power is linear (unlike a turbo), so it is very similar to stock, except you have more. As Paulo pointed out, having the extra power does give you the ability to better control yaw since now you can control the rear with the throttle. This is where suspension and tires come in, where the transition from gripping to sliding can be gradual (good) or an on-off switch (bad/porsche 911)
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 03-04-2016, 07:26 PM   #934
CSG Mike
CSG Mike's Avatar
The behavior of the car will not change, but it'll become much easier to spin the rear tires with too much throttle application.
However, because this is a supecharger, you can basically think of it has having a V6 in your car; you can control the rear with your right foot
Old 03-04-2016, 07:40 PM   #935
86fun
Drives: 2013 FRS
When I first got this car I absolutely loved the handling (I traded my E92 M3 in for it for just this alone!), but I was always bummed that I could not power steer out of turns like I could in my previous higher powered cars.
I haven't had a chance to go test the twisties out yet with the SC but I can imagine it's really going to fill this gap in nicely. There is ample torque for sure.
To me, the car seems to have ok turn-in stock, but could use some more (less understeer). It's fantastic through the middle of a turn, perfectly neutral. Now with the SC the power out the exit should be up to par with the other areas. The perfect car! What more could you want!!!... ok, one thing, I'll be upgrading the tires to 225's when the stocks are shot!
86fun is offline   Reply With Quote
The Following 2 Users Say Thank You to 86fun For This Useful Post:
BigFatFlip (03-04-2016), paiceyfan (03-04-2016)
Old 03-04-2016, 07:58 PM   #936
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
V6 in your car
This^^^
This is exactly what I tell people when trying to explain the power. It's like adding a larger motor to the car, but with the same light, free revving feeling of the FA20. With positive displacement blowers like this, I find that you don't have to go WOT as often to be rewarded, but then winding it out is still a ton of fun!
The Racers Line is offline   Reply With Quote
The Following 2 Users Say Thank You to The Racers Line For This Useful Post:
paiceyfan (03-04-2016), Uplink (03-04-2016)
Old 03-04-2016, 08:05 PM   #937
paiceyfan
paiceyfan's Avatar
I should be getting MPSSs later this year, so that should help
Old 03-04-2016, 08:08 PM   #938
paiceyfan
paiceyfan's Avatar
Even stock, I get it to rotate quite well on the tight corners at ORP, so everything I am hearing from you guys is encouraging!
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
