Old 03-04-2016, 02:29 AM   #575
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Happen to have any more pics of the sard wing with the TRD lip??
There's some in this post if you missed it and here's a few more:
Old 03-09-2016, 02:11 AM   #576
Bluebatmobile
Drives: 1997 Acura NSX
nice pics!
B@t™
Bluebatmobile is offline   Reply With Quote
The Following User Says Thank You to Bluebatmobile For This Useful Post:
switchlanez (03-09-2016)
Old 04-22-2016, 02:11 PM   #577
DSOmegaX
DSOmegaX's Avatar
Seems like so long ago (actually it was)
No more twinsies
@dsomegax.cars
Old 04-23-2016, 02:42 AM   #578
switchlanez
Originally Posted by DSOmegaX View Post
No more twinsies
Different indeed but still on for our tandem photoshoot, maybe this summer
Old 05-07-2016, 03:31 PM   #579
xj8954
Drives: 2013 Subaru BRZ
How did you get the reflective tape to wrap around the corner? Or I should ask which tape did you use? I bought one and it's pretty stiff hence can't wrap around the corner nicely like yours
xj8954 is offline   Reply With Quote
Old 05-10-2016, 01:29 AM   #580
switchlanez
I used this one: [ame="http://www.amazon.com/3M-Scotchlite-Reflective-Striping-50-Foot/dp/B00063XGFM?ie=UTF8&psc=1&redirect=true&ref_=oh_aui _search_detailpage"]Amazon.com: 3M Scotchlite Reflective Striping Tape, Red, 1/2-Inch by 50-Foot: Home Improvement[/ame]
When I came to the round corners of the black plastic exhaust surround, I'd incrementally press a 1 or 2 cm of tape down, rotate, press another cm or 2 down, rotate, etc. til I fully rounded the corner. Throughout that I also kept the tape pulled tense (almost stretching it but not quite) to prevent wrinkling. Lastly, this tape has a clear protective layer for packaging. That clear part wrinkles easily and also has some bubbling imperfections (it's just protective packaging, after all). After you finish applying the whole length, carefully pick at an edge with your fingernail or something very thin til you get an edge of the clear layer to catch and separate, then pull it completely off. That should rid of any wrinkling or bubbles you may see (it did for me).
Old 05-30-2016, 03:05 AM   #581
switchlanez
Considering OEM Brembos when they come out in 2017:
In the meantime I've added TRD Front Fender Aero Fins alongside satin black wrap stripes.
The Following User Says Thank You to switchlanez For This Useful Post:
SuperDave (05-30-2016)
Old 05-30-2016, 06:07 PM   #582
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Those brembos would look amazing!
SuperDave is offline   Reply With Quote
Old 06-19-2016, 04:34 AM   #583
switchlanez
Night shots!
The Following 4 Users Say Thank You to switchlanez For This Useful Post:
chanomatik (06-19-2016), mmmcambelsoup (01-11-2017), SkAsphalt (01-10-2017), SuperDave (08-21-2016)
Old 08-13-2016, 09:55 AM   #584
xj8954
Thanks for the reply!
I definitely got the wrong reflective tape at first.
I was doing yellow reflective tape on red BRZ.. Looks nowhere near as good as red on WRB so I took it off..
Old 08-20-2016, 02:48 AM   #585
Bluebatmobile
Originally Posted by switchlanez View Post
Night shots!
Great pics!
B@t™
switchlanez (08-21-2016)
Old 11-16-2016, 04:00 AM   #586
switchlanez
Phases montage:
Latest updates:
TRD Side Stabilizing Covers
TRD Front Fender Aero Fin (pre-painted D4S black)
TRD Aero Turbulators
Reverted to Cusco Short antenna to match above black pieces
Reverted to stock exhaust with JDM tips to match exhaust used in Edelbrock's smog tune (low end responds better than w/ GReddy exhaust)
Brembo GT BBK (326x30 4-pot front/316x20 2-pot rear, slotted rotors, SS brake lines)
Larger view TRD side aero stuff:
Old 11-18-2016, 03:20 AM   #587
switchlanez
How to kouki
Inspiration credz: http://www.subaru.com/2017-brz.html
2point0 (11-19-2016), Guff (11-18-2016), SuperDave (01-09-2017), Vin (11-18-2016)
Old 01-09-2017, 02:08 AM   #588
switchlanez
Decided to use Black Friday specials to switch out my ST coilovers for Bilstein B8/TRD springs because I miss progressive springs and was indecisively adjusting coilover height every other month. Since I was going to work down there with car on jack stands, I also snagged a USDM TRD quickshifter (bracket that installs down in the transmission tunnel to complement my STI short shift lever and make throws doubly short) and TRD sway bars. Discovered my stock front sway bar had white stress marks maybe due to when my ST coilovers sagged way down to around 50mm a couple months after setting them to a conservative 35mm. So this was a worthwhile mod.
Feels like a new car with a much more composed, quality suspension. The rubber insulators under the top hats do wonders to silence spring bind. Some suspension folks I consulted despise progressive springs for their lack of feedback and I'd agree if I always took it to the track. But I went against their advice because I enjoy street driving without driving 10/10ths and being able to soak up its variety of terrains. Shifter throw feels right now. The shortened STI lever alone was an improvement but didn't feel precise enough for my liking. Also my 255 wide front tires occasionally rubbed my inner fender plastics so I decided to stagger with 18x8.5 235/40 front and 18x9.5 265/35 rear. Problem with the narrower front was my Brembos didn't clear which I learned the hard way after Discount Tire mounted my tires and brakes scored into my new wheels' spokes:
Their insurance fully reimbursed me and I ordered another pair plus Adaptec Speedware 3mm spacers to clear the Brembos but thin enough for wheels to still mount hubcentrically. Was expecting to feel horrible understeer from the stagger but it actually feels easier to turn and holds the turn better. Maybe due the FR-S tuned TRD springs/sways. And it's nice to have a tighter turn radius again.
This weekend I installed the OEM Subaru footwell blue illumination kit. Pleasantly surprised by the factory quality of the installation despite the mod having a ricer-esque vibe.
Got some other ricer OEM mods coming that I've been on the fence about for years but will augment my exterior theme. Since I'm reaching the end of ideas to mod I might as well lol. Also been considering OEM Audio Plus for a couple years but a business course I recently took made me realize and appreciate OEM Audio Plus' marketing tactics. So before I buy into their hype, might be more sensible to try Subaru's OEM Kicker sub first which is on order. And I'll post an update on these but for now some random parked cars I saw over the holidays:
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
August 1st Charity Lapping Day - Subaru Canada - Davenport Subaru - SPDA - TSC wparsons CANADA 10 07-22-2015 01:24 PM
Subaru Cross Sport Design Concept = Subaru BRZ Shooting Brake Hachiroku BRZ First-Gen (2012+) — General Topics 91 04-01-2014 06:53 PM
Subaru LIBIRD Supercar Concept & BRZ (April Fools) switchlanez BRZ First-Gen (2012+) — General Topics 18 04-15-2013 02:20 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
