Old 02-27-2016, 04:22 PM   #1681
slow15frs
slow15frs's Avatar
Drives: 15 scion frs
Size:  105.8 KB 17x9 2554017 on trd springs
Sent from my SM-G928V using Tapatalk
2015 Scion FR-S-hot lava 6MT Perrin cai magnaflow cbe EFI LOGICS tuned 193whp
slow15frs is offline   Reply With Quote
The Following User Says Thank You to slow15frs For This Useful Post:
Hicklinc (02-25-2018)
Old 02-28-2016, 07:46 PM   #1682
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i've seen some one try to put 18x9.5 +40 on stock struts with a 245 tire. needed a 5mm spacer just to not rub on the inside with almost no camber because couldn't run more than 1-ish due to clearance. it also poked like crazy...
you can potentially fit it by going to a top hat and pulling max camber at the top hat, but still i don't think it will be enough clearance. just doesn't make sense. you can run a 9 all around though and a 245 all around! thats plenty of tire for a street car and even for modest track use!
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
Hicklinc (02-25-2018), texasbound972 (02-28-2016)
Old 03-01-2016, 12:58 AM   #1683
cammyT
Drives: 2015 Scion FR-S
So you dont think a 18x9.5 +35 with 265 will work up front?
cammyT is offline   Reply With Quote
Old 03-02-2016, 01:45 PM   #1684
Jive Turkey
the tuna, no crust.
with a stock strut setup?
absolutely not. will poke and probably rub inside.
Old 03-02-2016, 02:25 PM   #1685
cammyT
Yep on stock struts.
Im okay with the poke (for now). I just dont inside tire rub.
Im thinking with that offset I may get away with it. After test fitting the rims there was an additional few mm of clearance for the tires.
Old 03-02-2016, 02:44 PM   #1686
CrispyCheddar
CrispyCheddar's Avatar
Drives: the white one
Currently on 18x9 +30 with 255/35. No rubbing anywhere. I have about a fingers distance from the end of the wheel barrel/tire to the stock spring. (Still stock spring and struts)
Coils are going on in the next few weeks. Should be better
Sent from my SM-G920V using Tapatalk
If you can't win a race, beat the person in front of you
CrispyCheddar is offline   Reply With Quote
Old 03-05-2016, 07:22 AM   #1687
ClintimusPrime
Tennis Pro
Drives: '13 DGM BRZ. '07 600RR
I will never understand why people will drop money on wheels and be on stock suspension. Spend that on a decent suspension setup then worry about wheels...
Cool shot bro. Hit it again.
ClintimusPrime is offline   Reply With Quote
Old 03-05-2016, 07:30 AM   #1688
CrispyCheddar
Because people who own FRS/BRZs spend FRS/BRZ money. It's not like they [we] have ///M3 money to blow
Old 03-05-2016, 08:33 AM   #1689
churchx
churchx's Avatar
Drives: 2014 GT86
Stock suspension with proper alignment is really not THAT bad. Also if owner spent money on wheels mostly for looks, there is less motivation to spend on suspension, as "you don't see it" .
Old 03-05-2016, 11:11 AM   #1690
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
The stock suspension is a freaking masterclass, that's why people do wheels first. The car is very nicely damped from the factory and having 255 track rubber on stock suspension was a dream to drive even though all the kids said my "stance" was wrong.
- The Ancient BRZ Sacrament
by Zaku
The Following 5 Users Say Thank You to Guff For This Useful Post:
ajaxthebetter (03-05-2016), drew_kar (03-06-2016), Hicklinc (02-25-2018), Jive Turkey (03-11-2016), texasbound972 (03-05-2016)
Old 03-05-2016, 09:01 PM   #1691
PeterFRS
PeterFRS's Avatar
Drives: FRS
not my picture, from SpeedHunters,
we need moar meaty pictures in this thread.. I'm dying to get mine to meaty status
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 03-05-2016, 09:53 PM   #1692
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I only have 275's □'d
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
The Following 2 Users Say Thank You to texasbound972 For This Useful Post:
DustinS (03-07-2016), Hicklinc (02-25-2018)
Old 03-07-2016, 09:25 PM   #1693
Apex-Apex
Apex-Apex's Avatar
255/35/18 on 18x10 +40
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following User Says Thank You to Apex-Apex For This Useful Post:
Old 03-08-2016, 07:56 AM   #1694
Mil_Gates
@PeterFRS can you post a link to where you found this?! I don't remember seeing this car on SH.
Mil_Gates is offline   Reply With Quote
The Following User Says Thank You to Mil_Gates For This Useful Post:
PeterFRS (03-11-2016)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
