#57 | |
Killed Scion
Drives: 2013 FR-S Whiteout
also gorilla makes some inexpensive closed lugs and I hear mcgard is also really good and have great lockers.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following User Says Thank You to MisterSheep For This Useful Post: | go_a_way1 (02-25-2016) |
#58 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Thanks! |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | MisterSheep (02-25-2016) |
#59 |
Killed Scion
K&N Drop-In Air Filter 3/1/16
Just got a K&N drop-in filter installed on the FR-S. Super easy install.. Just undo the clips and take out the old filter. Put in the new K&N filter and make sure the letters are facing up. Not much else to it
probably the easiest install I've done.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque Last edited by MisterSheep; 03-02-2016 at 01:07 PM. |
| The Following User Says Thank You to MisterSheep For This Useful Post: | Drakiv (03-02-2016) |
#60 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
I was thinking of doing this as well while I'm waiting to do my motor and turbo.
#61 |
Killed Scion
HIC Window Visors
I purchased a set of HIC Window Visors off of ebay and got them in the mail yesterday. So, I went outside and slapped them on. They did not come with any templates nor any instructions but it seemed pretty self explanatory, take of the 3m film to expose the tape and stick it to your car. I lined it up where I wanted it on the passenger side making sure that the window did not hit it when you opened the door and then stuck it down. I then measured where I placed it so I can place it in the same exact spot next time.
Overall I like these, they're a cosmetic only item but I like the way they look especially with my vinyl wrapped roof. ![]()
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque Last edited by MisterSheep; 04-20-2016 at 11:25 AM. |
| The Following User Says Thank You to MisterSheep For This Useful Post: | Drakiv (04-16-2016) |
#62 |
Killed Scion
^ here's a quick little video a friend of mine @PMok put together. If any of you wondered what my exhaust setup sounds like, well here you go! J2 engineering catback (2.75in) with an Agency Power front pipe/ over pipe combo (2.5in).
#63 |
Killed Scion
4/19/16 More SPC camber bolts and alignment
Yesterday I had the guys over at elite performance install some SPC camber bolts on the bottom which were paired with my already installed whiteline camber bolts up top. Gary said I could easily reach -3 degrees of camber with this setup but I had him decide what was best for my needs. He ended up trying to make the camber as squared as he could on all 4 corners. Probably next would to get some LCA's to be able to adjust camber in the rear but I am happy with the -2.4 all around.
#64 | |
Site Moderator
Drives: ichi 86 Project
#65 |
Killed Scion
Unfortunately I do not know for certain but if it helps at all I did see them have a guy get in and out of the car while they were performing the alignment while it was up on the racks..
#66 | |
Site Moderator
Also I was looking at your build... it's kinda funny that, most of the mods you did, they all were in my build list #3... I decided to go different route and currently on built list #5 lol |
#67 | |
Killed Scion
#68 |
Drives: 2014 Subaru BRZ
That J2 Exhaust looks Mean!
| The Following User Says Thank You to VIP BRZ For This Useful Post: | MisterSheep (04-20-2016) |
#69 | |
Site Moderator
Exterior: TRD shark fin ITEC 3rd brake light BeatSonic roof spoiler TRD/ZELE fender extension TRD Aero stabilizing cover TRD duckbill JUN side skirt ChargeSpeed rear bottom line STI front lip Chassis: TRD door stabilizer TRD strut tower bar STI V bar Cusco rear chassis brace Carbing Frame brace Interior: Diode Dynamics LED lights Toyota "86" Airbag cover TRD steer wheel TRD push start button Suspension: ARP studs Cusco LCA TRD sway bars RS-R sports-i coils Wilwood 6/4 bbk Winmax w2 brake pads Whiteline camber bolts Rays 57xtremes (F/R:18x8.5 +33) Michelin PSS (F/R:245/35-18) Engine: ...somehow that part was missing in my google sheet info |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | MisterSheep (04-20-2016) |
#70 |
Killed Scion
Haha nice! Yeah you're right that it is very close.
| VuDism's WHITEOUT FRS 6MT Daily Driver Journal | VuDism | Member's Car Journals | 44 | 03-28-2017 07:13 PM |
| My Journal | Weasel Soup | Member's Car Journals | 27 | 10-03-2016 05:07 PM |
| < RYO > Car Journal | RYO | Member's Car Journals | 3 | 04-16-2015 01:48 PM |
| Suaveflooder's Whiteout FRS Journal | suaveflooder | Member's Car Journals | 139 | 07-19-2014 12:04 AM |
| Going S1DEWAYS Whiteout Journal | jinberry | Member's Car Journals | 8 | 12-03-2013 06:40 PM |
