Old 03-01-2016, 05:43 PM   #1
lugao
Drives: 2015 Subaru BRZ Series.Blue
2015 BRZ Shark Fin Removal
Hello, I just would like to know how to remove the BRZ shark fin antenna. Has anyone done this? The reason I am asking is that I want to get my roof wrapped. I have tried looking and I saw the regular antenna removal and not the shark fin one. Thanks in advance!
lugao is offline   Reply With Quote
Old 03-01-2016, 05:44 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I would assume with a plastic blade or fishing line to get the glue off. Kind of like taking a badge off
Old 03-01-2016, 05:51 PM   #3
lugao
That is what I thought too but it seems like there is already a gap in between the antenna the roof. So that is why I want to know if anyone has a personal experience with this.
Old 03-01-2016, 05:55 PM   #4
White64Goat
It is bolted from the inside. You have to remove the plastic window trim at the back of the headliner. Then you can either A. remove the side trim plastic and then pull down the headliner or B. carefully pull down the headliner and access the underside of the antenna. It will bend the headliner a little but not so much that I notice it. There are some how-to's on the forums to do this. Do a search in the audio section I believe.
The Following User Says Thank You to White64Goat For This Useful Post:
go_a_way1 (03-01-2016)
Old 03-01-2016, 05:59 PM   #5
lugao
So it is just like the regular antenna removal and there is no adhesive holding on to the antenna itself?
Old 03-01-2016, 06:02 PM   #6
White64Goat
http://www.ft86club.com/forums/showt...ht=white64goat
It has a rubber o-ring type deal on the antenna base and there is a big nut that holds it to the roof which I loosened with vise grips. Just don't over-tighten it when you reinstall it. Above thread will tell you all you need to do it. The center plastic clip is deceiving in looks and you will try to pry the whole clip, when actually it is a 2 piece clip, just a little different than the usual ones they use. It does have a split, it's just hard to see. Use your fingernail to find the split in it.
Old 03-01-2016, 06:14 PM   #7
lugao
Cool, that is very helpful. I wanted to know first on how to remove it so that I can remove it before getting my roof wrapped. Thanks again!
86EXPO 2015 Beers & Boxers August 14th, 2015 Events@Ptuning Mid-Atlantic 24 07-26-2016 11:18 AM
Aside from 2015 Acura NSX and Toyota Supra, what else in 2015? stockysnail Northwest 7 01-13-2015 02:30 AM
Official: 2015 Scion FR-S Gets Shark-Fin Antenna, Minor Suspension, Cosmetic Updates vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 178 09-10-2014 09:10 PM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
Toyota Improves 2015 GT86's Dynamics, Adds Shark-Fin Antenna in Europe vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 93 04-26-2014 03:31 PM
