Old 01-22-2016, 04:13 PM   #225
georgiafrsguy
Drives: white 2013 frs
Originally Posted by Scott@HKSUSA View Post
Glad to hear you'll be going with our kit! Make sure you send me pictures of the build! We leave the 4th slot open to allow our Pro Dealers to write a custom tune based on the other modifications you have on the car. They also have the ability to edit the other two slots in the flash editor. It says you are in Atlanta which is close to one of our Pro Dealers, Top Speed Motorsports. They will be able to adjust the tune for you if need be. Good luck and let me know if you need any help!
awesome!!!thanks, just what I was hoping to hear. i know exactly where they are. ill def take pictures and let you know how it goes.
georgiafrsguy is offline   Reply With Quote
The Following User Says Thank You to georgiafrsguy For This Useful Post:
CxG (01-22-2016)
Old 01-25-2016, 07:16 PM   #226
Koj
Koj's Avatar
Drives: Toyota GT86
Hi guyz.
I think I m going to install an Oil Catch Can.
Some of you already installed one ?
Is it really interesting ?
I saw the Mishimoto Kit : http://www.mishimoto.co.uk/subaru-br...-can-2013.html
Is there an HKS Kit ?
See you...
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 02-24-2016, 11:00 PM   #227
zeal86
zeal86's Avatar
Drives:
Ok...My HKS v3 will arrive really soon...I am looking for a configuration that will yield me a nice tone with minimal if any drone or rasp in my exhaust system. I am thinking about the following configurations for my exhaust system:
**Not interested in any brand not mentioned below
- HKS EL Exhaust Manifold + Stock Over Pipe + HKS Front Pipe + Ark Performance Grip Exhaust
- HKS EL Exhaust Manifold + Tomei Joint Pipe + HKS Front Pipe + Ark Performance Grip Exhaust
- HKS EL Exhaust Manifold + Stock Over Pipe + Ark Performance Test Pipe + Ark Performance Grip Exhaust
- HKS EL Exhaust Manifold + Tomei Joint Pipe + Ark Performance Test Pipe + Ark Performance Grip Exhaust
- Tomei EL Exhaust Manifold + Tomei Joint Pipe + Tomei Straight Pipe + Ark Performance Grip Exhaust
- Tomei EL Exhaust Manifold + Tomei Joint Pipe + Ark Performance Test Pipe + Ark Performance Grip Exhaust
- Beatrush EL Exhaust Manifold + Beatrush Support Pipe + HKS Front Pipe + Ark Performance Grip Exhaust
- Beatrush EL Exhaust Manifold + Beatrush Support Pipe + Ark Performance Test Pipe + Ark Performance Grip Exhaust
If anyone is running any of these configurations or close to any of these, please comment on the tone, drone, rasp, and power made. My biggest concerns being great sound and safe power.
Thanks in advance
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
CxG (02-24-2016)
Old 02-25-2016, 05:33 AM   #228
86Tony
Drives: 2015 AOZORA EDITION
any update on your blower for the original thread poster??
86Tony is offline   Reply With Quote
Old 02-25-2016, 09:27 AM   #229
wbradley
Sarcastic SOB
wbradley's Avatar
Yes, I did finally receive my replacement last month. Installed it and am happy to say it's running fine. The car is stored during winter but I did take it out for several runs since the roads were dry and it was above freezing outside for weeks. Initially the unit gives off a bit of whine but that might be attributed to cold temps and using the higher viscosity traction fluid. It seems to eventually tone down after warmup.
The car is definitely much more zippy once the revs are in the 4000 RPM range and up. Of course the rear wheels break loose in 1, 2 and 3rd gear with ease. Its tempting to go with wider wheels and tires but the PSS 215's on stock wheels were new last spring and have no miles so might hold off until new tires are actually needed or look into a local trade if possible.
Also, got a check engine light a few times, indicating rich condition or sensor malfunction. Erased each time and didnt return last 1 or 2 times out. Initially thought it was a dirty MAF but now thinking ECU sensed difference from driving without the blower installed with the SC tune and then restoring it. Anyway it appears (hopefully) that the ECU has relearned and is OK.
Funny thing, immediately after installing, took the car for a run and heard a POP! , followed by stalled engine. Luckily was able to roll into a gas station lot. Tried to start the engine and it did run, but rough. Opened the hood to discover I didnt tighten an inlet pipe clamp and the pressure popped it open. Used a lucky dime from my 8 year old to tighten down the screw and all was well. That was a scare I could do without!
The Following 4 Users Say Thank You to wbradley For This Useful Post:
Cole (02-25-2016), CxG (02-25-2016), go_a_way1 (03-01-2016), Yobiwan (02-27-2016)
Old 02-25-2016, 09:34 AM   #230
Cole
Not a troll
Cole's Avatar
Lol, the headaches never end eh?
Cole is offline   Reply With Quote
Old 02-25-2016, 10:14 AM   #231
JadeBRZ
#ProjectBRZ
JadeBRZ's Avatar
Drives: SWP BRZ
I just got my V3 kit installed. Running the 91 tune now. Need to send the flash editor to HKS to get the 93 tune. So far it feels great, cant wait for that extra 20 more HP.
Fuck HKS
JadeBRZ is offline   Reply With Quote
Old 02-25-2016, 11:04 AM   #232
wbradley
Sarcastic SOB
wbradley's Avatar
No, I am quite sure the headaches are over.
The ECU seems to have resolved, the whine is definitely due to temperature. There are 2 different viscosities of traction fluid and I purchased the higher one as the car isn't supposed to be winter driven and will definitely be run in high heat conditions.
The story about the "pop" was just sort of funny after tall the BS I went through and it nearly gave me a heart attack but turned out to be nothing.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
Old 02-29-2016, 06:39 PM   #233
86Tony
i recently just purchase my kit and im curious if this kit can make 350whp? do you think its possible i know i would need to build my motor just want to find out if this blower can make that much power.
Old 02-29-2016, 07:18 PM   #234
wbradley
Sarcastic SOB
wbradley's Avatar
I think the blower itself is capable of 400 HP. With fuel pump, injectors, a Supra sized intercooler and the smallest pulley you might just make 350 WHP. That means spinning the supercharger to the max. Personally, I wouldnt feel comfortable maxing out the unit.
I have a smaller pulley and 700cc Deatchwerks injectors but dont plan to use them presently. My intercooler looks to be somewhat bigger than the V3 unit and I am sure all I would need is a drop in fuel pump for 350 BHP.
Old 03-01-2016, 09:24 AM   #235
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
I think wbradley gave you a good answer on this. 350 whp would be about the maximum power you could do, and that would take some modifications (like a smaller pulley). However, that would be pushing the supercharger to its limits and it is possible you could wear it out quicker.
Torry@HKSUSA is offline   Reply With Quote
Old 03-01-2016, 03:45 PM   #236
86Tony
will you guys be making bigger blower to upgrade for the guys that want more power in the future?
The Following User Says Thank You to 86Tony For This Useful Post:
CxG (03-02-2016)
Old 03-01-2016, 03:48 PM   #237
Torry@HKSUSA
Drives: HKS
As of right now, nothing is in the works that we know about, but that doesn't mean it's not a possibility in the future. HKS is always working on developing new products.
The Following User Says Thank You to Torry@HKSUSA For This Useful Post:
CxG (03-02-2016)
Old 03-01-2016, 10:50 PM   #238
86Tony
are you running oem injectors as of now? and do you think i need to upgrade from stock injectors? im only lookin to make 280whp give or take as of this season. also are you on stock clutch if so hownis it holding up as my car will be seeing lot of track time. so trying to see if i should upgrade all at once before installing the kit and getting it tuned
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
