Old 02-29-2016, 05:43 PM   #1989
cjd
cjd's Avatar
Drives: 2017 BRZ
What spring rates are you guys running? Still very unsure about adding a front swaybar...
The Following User Says Thank You to cjd For This Useful Post:
strat61caster (02-29-2016)
Old 02-29-2016, 05:44 PM   #1990
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Recommended....7/6
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 02-29-2016, 06:45 PM   #1991
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'm 60/70 (N/mm) front/rear. No autocross events on it yet though, so only backroads "testing"...
Old 02-29-2016, 07:01 PM   #1992
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Agreed, the amount of stiffening off the shelf setups are doing to the front doesn't make sense to me either. About to commit to a setup that isn't that...
ineedyourdiddly
Old 02-29-2016, 07:07 PM   #1993
RTR
Drives: monogram raven
6k/7k rs-r sports i coilovers, 20 mm whiteline front bar. Front bar makes a huge difference. Highly recommend it
Sent from my XT1585 using Tapatalk
RTR is offline   Reply With Quote
The Following 2 Users Say Thank You to RTR For This Useful Post:
DocWalt (03-01-2016), jbailey8748 (03-01-2016)
Old 03-01-2016, 09:49 AM   #1994
Thorpedo
The SquadWhisperer
I have the stock 7k/6k Feal 441s... I would recommend going the other way around. (6k/7k)
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 03-01-2016, 11:00 AM   #1995
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
So, even with stiffer springs you find a bigger front bar necessary? I find that interesting since you'd think the stiffer spring rate on the coilovers would negate the need for a bigger sway bar.
smg1138 is offline   Reply With Quote
Old 03-01-2016, 11:12 AM   #1996
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Based on how my car feels with 6k/7k (close enough) I can see the desire for a front bar.
Old 03-01-2016, 11:36 AM   #1997
RTR
Yes
Old 03-01-2016, 02:26 PM   #1998
xwd
It doesn't. It's just the nature of the mcstrut front suspension on the car. You could run some really high spring rates and lower the car but then you are probably causing other issues harder to fix. At least when you are talking autocross lots that aren't very smooth.
The Following User Says Thank You to xwd For This Useful Post:
e1_griego (03-01-2016)
Old 03-01-2016, 02:57 PM   #1999
smg1138
smg1138's Avatar
That's good to know. I'm currently running RCE T2's with 400lb springs and stock sway bars. The AutoX season here starts pretty soon, so I'm curious to see if I'll need more front bar.
Old 03-01-2016, 03:43 PM   #2000
xwd
Well I shouldn't say stiffer springs and shocks do not help, they definitely make a big difference, but the swaybar will help quite a bit on its own.
These cars have been around for a few years and obviously have done well in STX, the recipe for that has included a bigger front bar. Rear bar is something some change and others do not depending on how they drive the car and how they like the feel of it.
Old 03-02-2016, 02:03 AM   #2001
RTR
Has anyone here gone through the process of getting permission and an insurance policy naming the scca to be able to fly a drone at an event? I'm really curious what an insurance policy like that would cost. Think the rule book says $10 million?
Old 03-02-2016, 08:22 AM   #2002
cjd
cjd's Avatar
Drives: 2017 BRZ
Unless you can get that as a private pilot, you'll have more than SCCA to worry about. That assumes you already have registered with both the FAA and AMA. Perhaps you can - I'd be curious too, though I'm still training reflexes (orientation still eludes me. Car is fine, but the quad I struggle with...)
Probably also not an STX topic
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
