Old 06-13-2012, 12:25 PM   #29
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Originally Posted by smbrm View Post
I don't think sport mode in manual/paddle shift did anything in particular when I tried. For the AT I found the paddle shifters to be the most engaging mode, both for upshifting and downshifting. What is interesting though is being able to switch modes. So you can cruise on the highway in D and let the brain take care of highway shifts for hills & valleys and then switch over to paddles when you get to ramps and places where you want more control of shifting. Having been a manual driver since forever though it is still tough to get my head around switching. Rowing six gears with MT in the same space that I am used to five, and the lower FE of the manual just feels like a conundrum that doesn't quite add up.
Sport mode in Manual shift mode makes a HUGE difference when driving in anger. Upshifts are much quicker, and the downshifts are also fantastic, and ti even blips the throttle to rev match. It also allows you to downshift into some pretty high RPMs for engine braking.
Boosted2.0 is offline   Reply With Quote
Old 06-13-2012, 12:38 PM   #30
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
OK cool.
Sport mode does shut off when you engage cruise control, I did notice that.
But why would you need engine braking? Brakes are for braking!
smbrm is offline   Reply With Quote
Old 06-13-2012, 01:12 PM   #31
...But why would you need engine braking? Brakes are for braking!
Engine braking is very important in certain scenarios. Easiest example is downhill decents on a long grade. If you depend on brakes alone, there's a good chance they will not be there when you need them the most. They will fade as they heat up.
Old 06-13-2012, 01:21 PM   #32
smbrm
smbrm's Avatar
I agree with you on that one Dadhawk, but I doubt you need sport mode to get that to work!
I am assuming you are still liking your AT? You've had another week or so to play around with its many control options.
Old 06-13-2012, 02:41 PM   #33
True, I assumed the question was about it in general. You do need to be in manual to have it "stick". You can do it in full auto, but it will switch back on you after some time.
Yes, I'm still very satisfied with it, particularly now that I have some time with it and have learned my left/downshift from my right/upshift and don't have to think about it. I use it all the time these days.
Old 06-13-2012, 04:14 PM   #34
Boosted2.0
Boosted2.0's Avatar
OK cool.
Engine braking helps keep the vehicle ballanced and controlled when braking heavily. It also reduces the load on the mechanical brakes slightly.
To those of you test driving AT... DantKR Scion FR-S / Toyota 86 GT86 General Forum 25 06-05-2012 12:08 PM
dealership 4 hours away, bad for engine break in? Mykflo BRZ First-Gen (2012+) — General Topics 27 05-23-2012 07:57 PM
Few Hours w/ an Ultramarine Guaruja FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 04-07-2012 04:42 AM
Tips, tricks, techniques to improve driving? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 15 08-01-2011 04:17 PM
