Old 06-13-2012, 02:07 PM   #141
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Originally Posted by DantKR View Post
Mine sat here after 30min drive and was idle for about 2 min:
So if I understand things correctly now this is what it should NOT do? My FRS seems to sit at 500-750 RPM a decent amount of the time and otherwise near 1000 RPM.
Should I be worried? Honestly, it hasn't made any bad sounds like the engine is struggling or tended to stall whilst idling in nuetral or with the clutch pedal pressed in.
EDIT: In any case, it doesn't seem to bounce around or "dip" uncontrollably
Re~Mix is offline   Reply With Quote
Old 06-13-2012, 02:12 PM   #142
DantKR
Drives: Subaru BRZ LT
No, this is where it should be. That's pretty much a perfect idle. 1,000 RPMs should only be for the first 2-3 minutes of operation and then it'll go down by about 100-200 and then finally settle at about 600-700. The engine will probably never sound like it's struggling unless it starts to hit 300 or below. Then that is an issue.
DantKR is offline   Reply With Quote
The Following User Says Thank You to DantKR For This Useful Post:
Re~Mix (06-13-2012)
Old 06-13-2012, 02:15 PM   #143
otoz
Drives: 2013 Whiteout FR-S
Does yours dip after you give it a little gas and let off the accelerator like in my video?
otoz is offline   Reply With Quote
Old 06-13-2012, 02:24 PM   #144
yayforaddison
yayforaddison's Avatar
Drives: Whiteout FR-S
The car isn't idling low all the time. If it sat for 2 mins at the same rpm then it's fine, but ours seems to do it when slowing down. As far as I know, it's not normal to stall when coming to a light, or even drop low enough in idle to nearly stall and shake.
yayforaddison is offline   Reply With Quote
Old 06-13-2012, 02:26 PM   #145
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
When my engine is cold, it idles at ~1500rpms for a few minutes. Not sure if thats normal or not though. All of my previous cars would idle at 1k while cold then drop down to 750-800rpms.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-13-2012, 02:26 PM   #146
DantKR
That what you describe is not normal and def not what was in the vid. This sounds like a fuel line/pump issue and I would defiantly have it looked at if you can reproduce.
Old 06-13-2012, 02:28 PM   #147
DantKR
1000-1200 is fairly normal. 1500 isn't out of the question.
civicdrivr (06-13-2012)
Old 06-13-2012, 02:29 PM   #148
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
Originally Posted by Rabble View Post
You guys should post the section of your vin that says which number it was off the factory line. It would be interesting to see if there is a pattern of a specific batch of cars having this issue or if it is random.
I was thinking the same thing. Maybe the OP can edit the 1st post, listing username, last 5 of VIN #, production date and delivery area. My frs mt is running fine so far @ 500 + miles.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Old 06-13-2012, 02:41 PM   #149
davisk6
What you are describing sounds like a vacuum leak or a MAF problem. MAF turbo cars with BOV's have this same problem if the BOV is set too "soft", ie, the system doesn't close. Either way, I'd have it checked out by a dealer. Chances are some of the intake routing hoses are loose or cracked.
davisk6 is offline   Reply With Quote
Old 06-13-2012, 02:46 PM   #150
Re~Mix
Re~Mix's Avatar
I haven't noticed it yet, but I will be on the lookout. Approx 750 miles on my MT FRS
Old 06-13-2012, 03:03 PM   #151
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
My s2000 did this sometimes after a big change in weather. Example: Seattle has a very temperate climate and doesn't see anything "warm" until July then bam: 85 degree days. The S2000 would have to "re-learn" the ambient air, would stumble a bit at idle, "pop up" then come back down and it's all good. It might do this a couple times after the start of the warm season.
Ok, but this is of now value to those where the CEL's were coming on or the car was dying... That's a bigger problem I suspect and if it happens to me when I buy mine I will be back in the dealership IMMEDIATELY.
Old 06-13-2012, 03:08 PM   #152
motofan
Drives: 10 VW GTI
I once drove a modified S2000 with turbo. If I quickly release the gas when the car in station, the RPM can drop to very low, the higher I rev it, and release quickly, the lower it drops and can stall very easily. However, it I release gently, there is much less chance for RPM to drop lower than it should be at idle.
So, can you guys with MT FR-S try to see if you gently release the gas, coasting rpm back to about 800, is the problem is still there?
motofan is offline   Reply With Quote
Old 06-13-2012, 03:12 PM   #153
motofan
Drives: 10 VW GTI
That should be normal. Every car does it so it can warm up quicker. Don't sit and wait the car to warm up, drive it. This warms the engine up quicker. Sitting there does more harm to the engine and is bad to the environment.
Old 06-13-2012, 03:24 PM   #154
cdrsfrg
Drives: 2013 Asphalt FR-S 6 Speed Stock
The manufacturers warning on two-way radio instillation indicates to me that the ECU may be sensitive to RFI (Radio Frequency Interference). When you have an RPM fluctuation, take notice of your location and other vehicles around you that may have a transmitter of some sort. (i.e. airports, radio towers, TV transmitters, trucks, and other government vehicles that would have two-way radios)
Hopefully the ECU is not that sensitive, but who knows.
At the present time I have not noticed such a fluctuation and have only put on a few hundred miles.
cdrsfrg is offline   Reply With Quote
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2012 11:38 PM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 01:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 12:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 12:58 AM
