Old 02-26-2016, 05:14 PM   #841
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Silverfox View Post
Install the mishimoto oil cooler yet?
I believe that was @EJ. who was going to install the mishimoto. If I recall, I believe @MicheleAbbate has the same set-up on her racecar
Originally Posted by clayrush View Post
Ill upload the dyno graph when I get home
But it made 295hp, from 187. And 213 Tq from 146.
Both numbers were on e85. Full catless exaust and Borla uel header.
The car is having some stalling issues when it comes to a stop. They are going to look into it next weekend.
I am going up after work to pick her up.
Wow, went straight to the E85 eh? You guys aren't messing around lol. Are you running Delicious FnG or custom tune?
Originally Posted by Sargy View Post
Already posted in the FB Group, but just an FYI for those with a Nameless EL Header.
The provided intake box will not clear with this header in the way. Even with modification to move it around, there is a very high risk of melting something. Currently looking at ACE for a new header.
Happy Friday!
Is there enough clearance for maybe a section of heat wrap or heat shield? Eitherway, I guess its not ideal to have so much heat so close to the intake.
Old 02-26-2016, 05:20 PM   #842
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
We have been running the delicious tuning flex fuel kit for about a year now. And now this is one of their flash and go tunes. I'm supposed to meet up with him weekend after this to figure out my stalling issue. There's a thought It might have to do with our lightweight flywheel.
My friends at the shop that installed it said it rips pretty hard and that even under half throttle the rear likes to break loose. I already have wider tires I guess I might have to look into going even larger :-)
clayrush is offline   Reply With Quote
Old 02-26-2016, 05:40 PM   #843
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
I believe that was @EJ. who was going to install the mishimoto. If I recall, I believe @MicheleAbbate has the same set-up on her racecar .
yep! We run the Mishimoto oil cooler! No issues here with temps - it's still be relatively cool out since installed the Eforce kit though!
Also, remember, use my coupon code: ABBATE30 at www.Mishimoto.com for instant savings
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
Old 02-26-2016, 05:54 PM   #844
BigFatFlip
BigFatFlip's Avatar
I'd be curious to ride your (your lady's?) car sometime at one of the meets. I've been on the fence with the flex fuel, mostly because come smog time, I'd have to swap back and forth. I just try to tell myself that I'm happy with the power (which I am, but MOAR is always better right?!)
Old 02-26-2016, 06:10 PM   #845
clayrush
Haha yeah it's the woman's. And I have a feeling I am about to be all kinds of jelly. But definitely down to give a ride.
Switch the frs to a somg setup is no big deal compared to my celica. I got to remove my blower, injectors computer and put exaust back every other year.
Old 02-26-2016, 11:01 PM   #846
CSG Mike
CSG Mike's Avatar
You want it. It's too easy and cheap to get that extra power safely.
Old 02-26-2016, 11:01 PM   #847
CSG Mike
CSG Mike's Avatar
Light flywheels have a tendency to do that, especially if you have a super light one.
Old 02-27-2016, 12:06 AM   #848
Uplink
Uplink's Avatar
Drives: anything you let me
Lightweight setups like a SPEC clutch/fw combo can cause decel stalling on these cars? Is it more prevalent in SC applications?
Uplink is offline   Reply With Quote
Old 02-27-2016, 12:12 AM   #849
BigFatFlip
BigFatFlip's Avatar
Originally Posted by NotSoJDM View Post
Thanks those are E85 numbers.
To those running Flexfuel, would you recommend upgrading the clutch or can the stock still hold up to it? I've gone with aftermarket clutches in the previous cars and I am yet to find one that drove better than the stock.
Old 02-27-2016, 12:17 AM   #850
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I went with an upgraded clutch when I was still on 93. The old clutch, which had 70k on it, still looked brand new with no signs of slipping. On the other hand, I have replaced slipping clutches in more than a few turbo 86s with less power/tq than what I am making now. Some of it may be driving style, but I would say you'll need one sooner rather than later if you go flex fuel.
NotSoJDM is offline   Reply With Quote
Old 02-27-2016, 12:32 AM   #851
clayrush
I actually ordered the heavier one with the act from you guys.
Old 02-27-2016, 12:37 AM   #852
Sargy
Long Distance Driver
Sargy's Avatar
Nope. Not ideal.
Sargy is offline   Reply With Quote
Old 02-27-2016, 12:54 AM   #853
clayrush
Yes definitely. But i would have upgraded even with the carb tune because how hard we are on it. She also had about 50k on the stock.
Old 02-27-2016, 01:51 AM   #854
CSG Mike
CSG Mike's Avatar
Sounds like your throttle may still be learning then.
In the initial learning stages, you can actually stall the car by stepping on the throttle *just the right amount* (although I don't know very many people who actually use this part of the throttle range).
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
