Old 02-26-2016, 08:23 AM   #15
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
This is probably the least snarky and most informative thread that's been posted here for a while. Good info and good going guys.
"No matter where you go, there you are" - Buckaroo Banzai
wireman957 is offline   Reply With Quote
Old 02-26-2016, 08:57 AM   #16
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by RichardsFRS View Post
The bolt on looks pretty simple, aside from the 02 sensors. I keep seeing on youtube where folks are having a helluva time getting them out and even breaking or stripping them. Better get spares!
Hit them in PB Blaster once a day for three days prior to trying to get them out. If they don't come out easy, apply heat with a pencil torch. Then make sure to use anti-seize on the threads on the replacement. Many O2 sensors either come with a little tube of anti-seize or have it on the threads already.
Originally Posted by Impureclient View Post
$90 low profile floor jack + $50 4 jack stands + $50 worth of a couple hand tools x 20% off coupons from harbor freight would be about the same as the labor from a shop.
Where are you planning to get a low profile floor jack for $90? The smaller low profile jack at HF is $140, and you can't use the 20% coupon on jacks. The labor to install these things really shouldn't run more than about $150, so he'd be spending another $80 to $100 on equipment he isn't going to use.
Old 02-26-2016, 09:12 AM   #17
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I charged the guy who bought my exhaust 60 dollars to install. Took me 30 minutes with a jack and two stands. and he was on his way.
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following 2 Users Say Thank You to nickmerronesucks For This Useful Post:
MGPAX (12-21-2018), wireman957 (02-26-2016)
Old 02-26-2016, 11:39 AM   #18
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
priceless for self labor
Old 02-26-2016, 12:27 PM   #19
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Assuming your time is worthless to you and you have all the tools :p
Old 02-26-2016, 12:29 PM   #20
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Nah, your time is always valuable, it's just that you get far more than simply a finished product from a job well done by yourself. Knowledge is power, and learning, sense of accomplishment, pride in your own handiwork, etc. should not be undercut.
BUT, as mentioned earlier, safety and being able to come out in one peice and drive away is also key lol
Toyarzee is offline   Reply With Quote
The Following 2 Users Say Thank You to Toyarzee For This Useful Post:
MGPAX (12-21-2018), NyC Zn6 (02-26-2016)
Old 02-26-2016, 12:43 PM   #21
D88
D88's Avatar
Drives: 2014 Scion FRS
Originally Posted by Toyarzee View Post
Did you spend all your money on the exhaust parts and run out of cash for some basic tools and a floor jack lol...? Paying for labor on bolt on exhaust install pains me to think about, unless there's no where that allows you to work on your own car?
It's not always that simple. As has been said already, if he lives in an apartment where he can't work on his car, then having the tools doesn't help. The alternative is maybe you have a friend who has the space to let you do it but that's not a guarantee.
There's also the issue if this is your only vehicle. I'm personally not one to want to take the risk of possibly disabling my own car. Better to have it at a shop if something goes wrong.
I also learned the hard way that sometimes it's just way easier to pay someone to do it. I tried to remove my muffler and it was so rusted and seized, I couldn't get it off with the tools I had. I ended up stripping a bolt and said fuck it and took it to a shop. Cost me $50 and I wished I had just done that from the start.
If you have the money to buy a full exhaust in one go, then you can probably afford the couple hundred it costs to have someone else install it. There's no shame in that.
D88 is offline   Reply With Quote
The Following User Says Thank You to D88 For This Useful Post:
Th3rdSun (02-27-2016)
Old 02-26-2016, 01:28 PM   #22
Impureclient
Drives: 2015 FR-S
It's $89.99 on their site, Item#62160. The same 1.5 ton one I have in my garage. I used the 20% off coupon too when I bought it. I read the "no floor jacks" on the coupon just now.
I used it when I bought mine or they had it on sale cheaper than that $90 because I am positive I aid around $70ish for it. I guess they weren't paying attention if it was the coupon?
I also bought my compressor with the coupon and it says no compressors either.
Old 02-26-2016, 01:37 PM   #23
Toyarzee
Shibby!
Toyarzee's Avatar
Umm, echo... echo.... echo....
Also, if you find a way to disable your vehicle beyond drivability when unscrewing some nuts off some bolts, then perhaps there is a greater issue at hand. Anyway, of course it's always going to be easier to have someone else work on your car. That wasn't the point though... we all are pitching in with opinions so he can weigh his options and possibly save a few bucks if that becomes more important
The Following User Says Thank You to Toyarzee For This Useful Post:
Cole (02-27-2016)
Old 02-26-2016, 02:10 PM   #24
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by NahumCC View Post
Plus pizza and beer.
quoted for truth. always required payment
Old 02-26-2016, 04:27 PM   #25
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
there's a special wrench that you can get at hobo freight for like 7 bucks to get o2 sensors out. then you shouldn't have to worry about the spares. I definitely agree with some of the guys that are suggesting buying the tools and doing it yourself. it's also a good reason to drink a few beers.
cdq85 is offline   Reply With Quote
Old 02-26-2016, 04:36 PM   #26
Toyarzee
Shibby!
Toyarzee's Avatar
Originally Posted by cdq85 View Post
hobo freight
Old 02-26-2016, 04:55 PM   #27
_brandon_mc_
Drives: 2016 Scion FRS
Dont let anyone tell you otherwise OP, do you.
_brandon_mc_ is offline   Reply With Quote
Old 02-26-2016, 05:24 PM   #28
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Time is money. Knowledge is money.
What one wants to do with their time and money varies from person to person. To say that $200 worth of tools versus $200 of labor install is the same thing takes away from the fact that some people just do not want to work on their own cars.
Nothing is undercut. $200 labor and $200 tools both have their merits in the long run.
-alex
full exhaust install help? mamamiaellis Engine, Exhaust, Transmission 5 06-03-2014 05:43 PM
Average price for Opti-coat / full detail? amilleri Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 05-17-2014 09:56 AM
Average price paid for fr-s? FriedRicr Scion FR-S / Toyota 86 GT86 General Forum 24 03-29-2013 01:14 AM
Best full exhaust system for the price Tyson Engine, Exhaust, Transmission 22 02-20-2013 06:35 PM
Whats your average MPG now in the winteRnHow far are you going on a full tank of gas? NickFRS Northwest 17 12-21-2012 11:59 PM
