Old 02-04-2016, 06:53 PM   #519
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Stop now, just take my money
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline
Old 02-05-2016, 12:08 AM   #520
G-awesome
Drives: 2015 Firestorm Scion FRS
I want a front splitter buuuut I probably damage the front splitter and endplate by accidently pulling too close to the curb on the first week...😂
My velox front wheel wind deflectors took a beating and snapped off so many times after I dropped my car an inch. I don't even know how the top corner at the outer edge on the drivers side got mangled so awkwardly. Need to take it off and bash the metal flat again. At least it's durable!
G-awesome is offline
Old 02-08-2016, 01:38 PM   #521
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Splitter is fairly durable, especially with the race upgrade. The sheetmetal bottom brace takes a lot of the toll. I have accidentally hit curbs at a few MPH , nice jarring stop. Besides a few scratches on the sheet metal, it's all good haha.
Endplates are in, double checking everything and then they'll be available at FT86 SpeedFactory. Informative post coming in the next few days.
VerusEric is offline
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
G-awesome (02-08-2016), johan (02-09-2016)
Old 02-08-2016, 06:34 PM   #522
Bramick
Bramick's Avatar
Same here. If you hit a parking block at slow roll you'll instantly stop (with race upgrade). I've even stood on the splitter.
Bramick is offline
The Following 3 Users Say Thank You to Bramick For This Useful Post:
bumppinKota (02-08-2016), G-awesome (02-08-2016), VerusEric (02-08-2016)
Old 02-08-2016, 10:41 PM   #523
Nab33
Drives: 2018 BRZ tS
Is it bad that I want everthing you guys make?...
Nab33 is offline
The Following User Says Thank You to Nab33 For This Useful Post:
VerusEric (02-14-2016)
Old 02-15-2016, 09:51 AM   #524
VerusEric
VerusEric's Avatar
Data/photos/CFD pictures are located here for the endplates: http://www.ft86club.com/forums/showthread.php?t=101577
Old 02-25-2016, 09:47 PM   #525
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Happy with the front end aero. I added the endplates and front wheel air deflectors Monday, to bring my splitter up to "current spec". Haven't had a lot of time driving but my initial impressions are positive. Can feel the aero balance shift forward, and front end grip is definitely increased. I also moved the plastic from the fender liner to between the CF and fender, was concerned it could pull over the BHCS/washers.
Kwaziekeller is offline
The Following User Says Thank You to Kwaziekeller For This Useful Post:
VerusEric (02-26-2016)
Old 02-25-2016, 11:00 PM   #526
Crashdummy
too much is never enough.
Crashdummy's Avatar
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
Has this setup been test fitted or installed on an RS1.0 yet?
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon
Nanako's Mod Thread
Crashdummy is offline
Old 02-26-2016, 11:39 AM   #527
VerusEric
VerusEric's Avatar
To my knowledge, no. It could potentially go together with some longer hardware but I do not know for sure.
The Following User Says Thank You to VerusEric For This Useful Post:
Crashdummy (02-26-2016)
Old 02-26-2016, 11:50 AM   #528
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
When I got my splitter we put it underneath my friends TRD lip as he was curious if this would work. We discovered a few things - the splitter doesnt stick nearly that far out in the front so you honestly may not even really notice it, this also causes issues with where the front rods would connect.
BDotG is offline
The Following User Says Thank You to BDotG For This Useful Post:
Old 02-26-2016, 02:49 PM   #529
Crashdummy
Crashdummy's Avatar
Thanks! that's what I figured, it IS possible though. good. One would have to tweak the mounting forward a few inches or if they could make one a few inches larger in the front to accommodate the rods.
How was the side to side width?
Nanako's Mod Thread
Old 02-26-2016, 03:23 PM   #530
BDotG
BDotG's Avatar
Wasn't super amazing either. I can't remember how much farther down the trd lip makes the bumper but I would have some concerns about it all being super low + splitter not sitting flush to bottom of the bumper (might be fine if you had longer bolts + spacers when needed). Maybe velox can cut you a splitter that sticks out a little farther
BDotG is offline
Old 02-26-2016, 04:56 PM   #531
Crashdummy
Crashdummy's Avatar
Roger. I did a quick look under there and the its about a inch or so from the bottom of the lip to the bottom of the bumper cover. I will have to get in touch with velox and see what they have to say.
thanks much!
Nanako's Mod Thread
Old 03-03-2016, 12:17 PM   #532
Crashdummy
Crashdummy's Avatar
Are there any plans to produce one for the RS1.0 front end?
Nanako's Mod Thread
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
What front splitter? Takumi788 Cosmetic Modification (Interior/Exterior/Lighting) 7 04-30-2014 06:20 PM
Perrin Oil Cooler - Impressions, Pics, and Data swift996 Engine, Exhaust, Transmission 36 04-29-2014 09:03 AM
BRZ Front Splitter Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 43 01-26-2014 03:29 PM
Front Air Splitter sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-17-2013 05:41 PM
