01-22-2016, 03:13 PM | #225 | |
Drives: white 2013 frs
The Following User Says Thank You to georgiafrsguy For This Useful Post: | CxG (01-22-2016) |
01-25-2016, 06:16 PM | #226 |
Drives: Toyota GT86
Hi guyz.
I think I m going to install an Oil Catch Can. Some of you already installed one ? Is it really interesting ? I saw the Mishimoto Kit : http://www.mishimoto.co.uk/subaru-br...-can-2013.html Is there an HKS Kit ? See you...
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more... My Journal/Garage |
02-24-2016, 10:00 PM | #227 |
Drives:
Ok...My HKS v3 will arrive really soon...I am looking for a configuration that will yield me a nice tone with minimal if any drone or rasp in my exhaust system. I am thinking about the following configurations for my exhaust system:
**Not interested in any brand not mentioned below - HKS EL Exhaust Manifold + Stock Over Pipe + HKS Front Pipe + Ark Performance Grip Exhaust - HKS EL Exhaust Manifold + Tomei Joint Pipe + HKS Front Pipe + Ark Performance Grip Exhaust - HKS EL Exhaust Manifold + Stock Over Pipe + Ark Performance Test Pipe + Ark Performance Grip Exhaust - HKS EL Exhaust Manifold + Tomei Joint Pipe + Ark Performance Test Pipe + Ark Performance Grip Exhaust - Tomei EL Exhaust Manifold + Tomei Joint Pipe + Tomei Straight Pipe + Ark Performance Grip Exhaust - Tomei EL Exhaust Manifold + Tomei Joint Pipe + Ark Performance Test Pipe + Ark Performance Grip Exhaust - Beatrush EL Exhaust Manifold + Beatrush Support Pipe + HKS Front Pipe + Ark Performance Grip Exhaust - Beatrush EL Exhaust Manifold + Beatrush Support Pipe + Ark Performance Test Pipe + Ark Performance Grip Exhaust If anyone is running any of these configurations or close to any of these, please comment on the tone, drone, rasp, and power made. My biggest concerns being great sound and safe power. Thanks in advance |
The Following User Says Thank You to zeal86 For This Useful Post: | CxG (02-24-2016) |
02-25-2016, 04:33 AM | #228 |
Drives: 2015 AOZORA EDITION
any update on your blower for the original thread poster??
02-25-2016, 08:27 AM | #229 |
Sarcastic SOB
Yes, I did finally receive my replacement last month. Installed it and am happy to say it's running fine. The car is stored during winter but I did take it out for several runs since the roads were dry and it was above freezing outside for weeks. Initially the unit gives off a bit of whine but that might be attributed to cold temps and using the higher viscosity traction fluid. It seems to eventually tone down after warmup.
The car is definitely much more zippy once the revs are in the 4000 RPM range and up. Of course the rear wheels break loose in 1, 2 and 3rd gear with ease. Its tempting to go with wider wheels and tires but the PSS 215's on stock wheels were new last spring and have no miles so might hold off until new tires are actually needed or look into a local trade if possible. Also, got a check engine light a few times, indicating rich condition or sensor malfunction. Erased each time and didnt return last 1 or 2 times out. Initially thought it was a dirty MAF but now thinking ECU sensed difference from driving without the blower installed with the SC tune and then restoring it. Anyway it appears (hopefully) that the ECU has relearned and is OK. Funny thing, immediately after installing, took the car for a run and heard a POP! , followed by stalled engine. Luckily was able to roll into a gas station lot. Tried to start the engine and it did run, but rough. Opened the hood to discover I didnt tighten an inlet pipe clamp and the pressure popped it open. Used a lucky dime from my 8 year old to tighten down the screw and all was well. That was a scare I could do without!
02-25-2016, 08:34 AM | #230 | |
Not a troll
02-25-2016, 09:14 AM | #231 |
#ProjectBRZ
Drives: SWP BRZ
I just got my V3 kit installed. Running the 91 tune now. Need to send the flash editor to HKS to get the 93 tune. So far it feels great, cant wait for that extra 20 more HP.
Fuck HKS
02-25-2016, 10:04 AM | #232 |
Sarcastic SOB
No, I am quite sure the headaches are over.
The ECU seems to have resolved, the whine is definitely due to temperature. There are 2 different viscosities of traction fluid and I purchased the higher one as the car isn't supposed to be winter driven and will definitely be run in high heat conditions. The story about the "pop" was just sort of funny after tall the BS I went through and it nearly gave me a heart attack but turned out to be nothing.
02-29-2016, 05:39 PM | #233 | |
02-29-2016, 06:18 PM | #234 | |
Sarcastic SOB
I have a smaller pulley and 700cc Deatchwerks injectors but dont plan to use them presently. My intercooler looks to be somewhat bigger than the V3 unit and I am sure all I would need is a drop in fuel pump for 350 BHP.
03-01-2016, 08:24 AM | #235 |
Drives: HKS
I think wbradley gave you a good answer on this. 350 whp would be about the maximum power you could do, and that would take some modifications (like a smaller pulley). However, that would be pushing the supercharger to its limits and it is possible you could wear it out quicker.
03-01-2016, 02:45 PM | #236 | |
The Following User Says Thank You to 86Tony For This Useful Post: | CxG (03-02-2016) |
03-01-2016, 02:48 PM | #237 |
Drives: HKS
As of right now, nothing is in the works that we know about, but that doesn't mean it's not a possibility in the future. HKS is always working on developing new products.
The Following User Says Thank You to Torry@HKSUSA For This Useful Post: | CxG (03-02-2016) |
03-01-2016, 09:50 PM | #238 | |
Similar Threads | ||||
Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4308 | 08-21-2024 03:12 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
Five Axis Edition FR-S Owners Thread | digital_assassin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 563 | 07-08-2015 09:22 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
Supra Owners Build Thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 164 | 03-12-2012 09:37 AM |
