Old 08-05-2015, 01:44 PM   #15
fixit
Drives: 2014 Camry SE 2.5L
Thanks for all of this information. I see cables now that come with updated FW Ver 2.0.4 which is later than the 1.4.1 this procedure was originally written for. An example of this updated cable is seen here:
http://www.aliexpress.com/item/Origi...462046940.html
The software is also a later version. It is V10.00.028. I don’t know if the driver has changed or not.
I’d like to buy an updated cable but I don’t know if I can apply Jhood’s instructions to the updated cable. Davesrave used the updated software and found that the reg hack is no longer needed but I don’t know if his FW or driver are the same or if it makes a difference.
• Does anyone know what changes might be needed to the procedure to get it to work with the updated cable I linked to?
• Has anyone followed the procedure using a cable with FW Ver 2.0.4? If so, can you report results?
Thanks.
fixit is offline   Reply With Quote
Old 08-07-2015, 05:04 AM   #16
diodelphi
diodelphi's Avatar
Drives: 86
Thanks so
diodelphi is offline   Reply With Quote
Old 08-15-2015, 09:40 AM   #17
jms87
Drives: 2014 4Runner SR5 4x4
A few questions here for you guys:
1) Will this cable and software work on some or all of the new toyotas, like a 2014 4runner?
2) Does anyone have a full list of things you can change with the software?
The back of my owners manual has a short list of "dealer customizable options" I'll try to attach a pdf here: Custom Options copy.pdf It has things like stopping the annoying seatbelt reminder beeping. So I actually took my toyota into the dealership and had them change a few of these options for me, and I got to watch the guy do it with his lap top. He just asked me what stuff I wanted to change and then had to navigate through some categories to get there. I noticed that he had way more categories and options than what I had on my list of dealer customizable options. For example his laptop had a category for "climate control" or something, which is not on the list I had. Also I noticed that my owners manual has "seat belt reminder" ON or OFF, but his lap top had the ability to turn the seatbelt ON/OFF for the drivers seat and passenger seat separately.
So now I'm wondering if those are super secret options that toyota doesn't want you to know about, or maybe those options were simply for a different model toyota, or maybe some other explanation... What do you guys think?
jms87 is offline   Reply With Quote
Old 12-09-2015, 04:54 PM   #18
HyperTech
HyperTech's Avatar
Drives: Mazda3 2013 / Scion FR-S 2015
can we program ourself a set of tpms into the car computer with this tool and cable?
HyperTech is offline   Reply With Quote
Old 01-11-2016, 04:12 AM   #19
Liliflower
Drives: 2008 FT86 GTS
yes, it should work. Where can i get the firmware mvci 2.0.4, i have only the firmware 1.4.8, the seller say it is the latest version.
http://www.obdii365.com/wholesale/mv...t-version.html
Liliflower is offline   Reply With Quote
Old 01-16-2016, 02:23 PM   #20
HyperTech
HyperTech's Avatar
i have no idea, i did not even received my cable from china since 7 december 2015
Old 02-24-2016, 05:05 PM   #21
BabaYaga
BabaYaga's Avatar
Drives: FRawSome Hot Lava
Does anyone in Sacramento North CA area or Bay Aria have TechStream? I just need to silence the passenger seat belt buzzer. Can anyone help? Let me know, please!
BabaYaga is offline   Reply With Quote
Old 04-07-2016, 01:11 PM   #22
n1trox
Drives: na
Originally Posted by Shinobu's Smile View Post
I could only get the software/drivers to work on an old XP laptop I had. I tried, 2 windows 7, 1 Vista, 2 Windows 8 and had no luck. So you might want to try it on something old.
The cable's driver is just a USB to Serial interface.
Techstream use the mvci.dll to communicate with the USB com port.
So just install the USB to Serial Port driver, then you can use Techstream on any version of Windows.
My OS is Windows 10 64bit, the cable's USB to Serial chip is ft232, so I download the driver on http://www.ftdichip.com/FTDrivers.htm and simply extract it, right click the .inf file then click install.
Now you can use Techstream!
n1trox is offline   Reply With Quote
The Following User Says Thank You to n1trox For This Useful Post:
Shinobu's Smile (04-11-2016)
Old 12-18-2016, 01:47 PM   #23
nathanrobo
Drives: Landcruiser Amazon - 50th Anniversa
Guys... looking for a bit of help. I generally use OSX but bought a microsoft machine for setting up the AHC suspension on my 100 series Landcruiser. I have Techstream running using the files mentioned above. Problem is that the Toughbook that I bought for the job has a licensed version of XP pro and it turns out that this is NTFS rather than 32 bit or FAT32.
So Techstream seems to install ok, and sees the Mini VCI lead (which lights up green), but when I try to connect to the car I get an error saying "cannot connect to VIM"
Are there any work arounds for NT?
nathanrobo is offline   Reply With Quote
Old 04-06-2017, 11:23 PM   #24
Chasen
Drives: toyota camry
Hi ,guy. MINI VCI FOR TOYOTA TIS Techstream have updated to v12.00.127
TOYOTA TIS Techstream v12.00.127
Chasen is offline   Reply With Quote
Old 04-07-2017, 08:30 PM   #25
TheRatsWon
Drives: 2017 Subaru BRZ Limited,Mazda Miata
See http://www.ft86club.com/forums/showt...=35530&page=15 post #197 for comments and file download link. This is not an endorsement, I haven't tried it yet.
TheRatsWon is offline   Reply With Quote
Old 09-18-2017, 08:58 PM   #26
Liliflower
New techstream V12.20.024 released (Sep. 2017)
tested working on Windows 7 32-bit
Free crack from google (with video guide)
if works, don't forget Thanks
Old 11-03-2017, 10:10 PM   #27
ruggb
Drives: toy rav4
I have everything installed - v12.20.024, ftdi driver 2.12.28 on both the port and the converter entry, mcvi for toyota, reg tweaked. The app is registered, the device plugged in but I can't connect to VIM.
There is also a WinDriver installed for a Denso VIM device 9.0.1.0 - i guess that is for the Toy VIM.
The firmware update tool will not connect.
The device is a Mini-VCI J2534
W10 x64
I have reinstalled it 3 time then again on another computer. Same thing.
What do I need to do?
tks
bill
ruggb is offline   Reply With Quote
Old 03-21-2018, 06:30 AM   #28
Aviator6
Drives: 2017 Tacoma DCOR
Jhood, great, detailed, write up on getting Techstream running on a 64 bit OS. I had purchased the Mini VCI J2534 V12.10.019, sold by Yueku on Amazon. They clearly state that this cable is designed for 32 bit systems, but that there is a work around. And they do provide customer service that "probably" would have got it working for me, but your method seemed so detailed that I just had to try it. Worked great!! By the way, I installed Techstream 12.20.024, using your instructions - just substituted the newer files where needed. Thanks again for sharing.
Aviator6 is offline   Reply With Quote
obd2, obdii, techstream, tis, vci
BRZ/FR-S Coilover Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 64 02-21-2020 05:30 PM
eibach sportlines springs installation guide? juanam0909 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-15-2013 05:53 PM
Anyone in the Bay Area have a Techstream cable and software tonylop33 Northern California 6 10-05-2013 11:16 PM
[StreetFX] 86 GT HID upgrade kit with DIY GUIDE! (including parking lights) WTF Australia Classifieds 12 08-14-2012 03:10 AM
