#43 |
Drives: 2014 BRZ
| The Following User Says Thank You to Sleepless For This Useful Post: | DocWalt (02-24-2016) |
#44 | |
Drives: '22 BRZ
I think I'll pick up one of the Lisle spreaders
#45 |
Drives: '13 FRS - STX
This works well on the OE, the foot nestles into the piston nicely and spins freely so you're not scratching anything up. Not sure on the AP piston size, may make for an awkward fit but could always use a piece of wood like above.
http://www.harborfreight.com/disc-br...sor-68973.html |
#46 |
Drives: ...Cars...
I just ordered in the Lisle quad piston one....i love my AP Brakes...i hate installing new or close to new thickness pads...a 15 minutes job takes an hour ...hopefully the Lisle spreader works well...will find out next week
i will spend the $225 in a heartbeat if it saves me 30 minutes of my life each time i do pads (i do them frequently between track and street)...we will see how the lisle one does first |
#47 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
These are my thoughts as well. It was easy enough to use a clamp and block the first time. But i also was only needing to move back the pistons about 2 mils. I imagine it will be quite different when i am i changing pads that are almost toast. If the pistons had been out anymore, my clamp likely wouldnt have cleared. So at the very least i need a different shaped clamp.
But these tools look good. I guess my caliper kit is obsolete, since it mainly worked with OEM slider bolt calipers. Quote:
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#48 |
Chin Track Event Manager
Drives: 15 Series Blue
[ame="http://www.amazon.com/gp/product/B005GLQCKA?psc=1&redirect=true&ref_=oh_aui_detailp age_o02_s00I"]Amazon.com: Lisle 29100 Quick Quad Pad Spreader: Automotive[/ame]
I have also used a modified C clamp. Cut the fixed end off and weld on a flat piece. Works great. A little tricky on the back side because of the banjo bolt.
Jim Pomroy Chin Track Days Event Manager.
15 Series Blue in white 18 Golf R 09 Comp Yellow NC 20 Gladiator tow vehicle. |
#49 |
Here's a pic of the homemade tool.
#50 |
Drives: 2013 BRZ Limited
At 4000+ ft elevation in Utah we have much less cooling capacity for the engine and the brakes. My pads last about 8 time attack competition days with the AP kit which is twice as long as the stock, but nowhere near what you're seeing. The rotors have not cracked to the edge yet though. Despite the abbreviated pad life, pedal feel and consistency are amazing.
Likewise, the brake fluid (even RT700) needs to be bled about every 8 days, sometimes sooner, due to the reduced capacity for cooling up here.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#51 |
Drives: White BRZ
I'm curious about why pads would last longer with these calipers and discs.
With the same engine and tires, the energy going into the system should be about the same. The discs aren't heavier than OE, so they don't have more heat capacity. I guess it's all about airflow through the disc keeping the pads and discs cooler. Any other ideas? |
#52 |
Drives: '22 BRZ
Pads are thicker too, so there's more mass to absorb the heat.
The BBK is a system, you have larger swept area (bigger pads and bigger rotors) meaning you get more torque from the pads which means they don't have to work as hard, there's a lot more airflow through the rotors, the pads are thicker, the calipers are bigger. Everything leads to a lot higher heat capacity meaning you're not at the ragged edge of durability like you are with the factory calipers/rotors. |
#53 | |
Drives: WRB BRZ
So the actual rings are thicker and heavier than the OEM part of the disks. You are right about the Airflow. |
| The Following User Says Thank You to Falcon For This Useful Post: | Chris S (08-18-2017) |
#54 |
Drives: 2013 Subaru BRZ Limited (WRB)
Does anyone know if the AP kit will clear Enkei RPF1 17x7.5 wheels?
#55 | |
Drives: 2012 BRZ Premium WRB 6MT
Here are all of the Enkei RPF1 fitments that our customers have told us will clear our Sprint Kit without a wheel spacer:
Thanks! |
#56 |
Thanks
I have that Lisle caliper tool and it doesn't do jack shit on my AP kit. Works a treat on OEM sliding caliper. Doesn't budge the 4 piston AP.
I use a worn out pad, read old baxking plate. Stick it in the caliper and use a small pry bar to depress 2 pistons. Stick in the pad and thenn deprrws other side. Works flawless Lisle is a decent product but not at all strong enough for the AP kit. Of it works for you i'd ask for advice and please post a video of you using it.
| The Following User Says Thank You to ZionsWrath For This Useful Post: | Tristor (05-05-2018) |
| What does it cost you to race? (Cost of racing) | rice_classic | Tracking / Autocross / HPDE / Drifting | 63 | 12-27-2013 09:54 AM |
| Benefit BBQ 11/16 12-3pm for our FOOD DRIVE. | VTR Performance | Northwest | 0 | 11-13-2013 05:11 PM |
| Benefit of dark wax? | Barbarian | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 07-18-2013 05:31 PM |
| 2014 WRX benefit the 86? | SanDiegoFRS | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 02-18-2013 09:50 PM |
