Old 02-23-2016, 02:48 PM   #1975
RTR
Drives: monogram raven
Is e85 legal in CSP? And is it really possible to compete with the miatas in CSP?
Sent from my XT1585 using Tapatalk
RTR is offline   Reply With Quote
Old 02-23-2016, 02:51 PM   #1976
e1_griego
e1_griego's Avatar
Drives: Many
Yes and probably not.
e1_griego is offline   Reply With Quote
The Following 2 Users Say Thank You to e1_griego For This Useful Post:
RTR (02-23-2016), Silver Ignition (02-23-2016)
Old 02-26-2016, 07:05 AM   #1977
RedBRZ80
Drives: 2013 Red BRZ
You can't get a 86 light enough to run with a CSP Miata at full nationals prep.
RedBRZ80 is offline   Reply With Quote
The Following User Says Thank You to RedBRZ80 For This Useful Post:
drewbot (02-26-2016)
Old 02-28-2016, 09:01 PM   #1978
xwd
What are guys running for tire pressures on the RE71s? I have been running 30/28 for the most part, they don't quite roll over to the arrows. Pretty standard setup with MCS coilovers (7K F/R) and WL 20mm front bar, not on the stiffest setting. I was dealing with a bit of corner exit oversteer and instability in slaloms today's event, although at the T&T yesterday it was pretty good. Or my driving was just bad.
Old 02-28-2016, 10:15 PM   #1979
RTR
Get mine tmrw but the one local in an 86 on re-71r is running 25/27.
Old 02-28-2016, 10:49 PM   #1980
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
That's about what I'm on in rivals
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 02-29-2016, 02:42 PM   #1981
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Originally Posted by BlaineWasHere View Post
There aren't any really fast STX or CS twins without a front bar. It's not that the car can't be balanced or quick without it. But it's faster with it.
Maybe. It really depends on where the car is. Where is it pushing in the corner or over steering in the corner.
I like to get the car doing what I want first with out the bars. And if I need that little bit of help.. then do the bars.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 02-29-2016, 03:14 PM   #1982
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
After driving my car hard over the weekend I can see why people want the front bar so badly. The car feels like it's "rolling over" on the front end. Kinda strange. I'm going to do a few events on it and see how it feels on less hilly surfaces but I'm expecting to have a 20mm Whiteline bar before the season is out.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
Racecomp Engineering (02-29-2016), Shark_Bait88 (02-29-2016)
Old 02-29-2016, 03:20 PM   #1983
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Test fit my new wheels (17x8 RS-Watanabe F8s) and tires (ZII Star Spes) this weekend, and noticed the same thing. I'm thinking a 20mm Whiteline bar isn't too far off in my future either.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
DocWalt (02-29-2016)
Old 02-29-2016, 05:05 PM   #1984
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I have the Perrin 22mm in the front and it's night and day in the slaloms.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
jbailey8748 (02-29-2016)
Old 02-29-2016, 05:07 PM   #1985
jbailey8748
I have the whitelines 22. We just had a test and tune and I was able to take a little over a second off my time ,on a 30second course, just by moving to the hard setting. Turn in was way faster so the first few runs after I made the change was like driving a different car.
Old 02-29-2016, 05:35 PM   #1986
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Do you guys have steady state understeer with those front bars? Adding understeer on track is something I very much do NOT want to do.
Old 02-29-2016, 05:41 PM   #1987
jbailey8748
No undesteer. I almost have it completley dialed out with negative camber and 22mm bar. It seems backwards to put a big bar on the front to gain traction up front but the way a macpherson suspension works your making it harder to gain positive camber under compression which results in more contact patch on the ground for longer in a turn
The Following 3 Users Say Thank You to jbailey8748 For This Useful Post:
DocWalt (02-29-2016), RTR (02-29-2016), Silver Ignition (03-01-2016)
Old 02-29-2016, 06:01 PM   #1988
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I understand that concept. I'm just too used to FWD where a big front bar kills you, you can't put power down in corners because it lifts the inside front. The hot setup there is stiffer springs and less bar. I've gotta wrap my head around the front wheels just sorta hanging out
The Following User Says Thank You to DocWalt For This Useful Post:
strat61caster (02-29-2016)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
