Old 02-19-2016, 06:19 PM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Exclamation What oil weight are you running in your supercharged FR-SÉ
And why do we not have a sticky for this?
Please state the conditions you typically drive in and climate etc
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 02-19-2016, 09:02 PM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
Mobil 1 0W40. Rarely driven in winter, except a few local pleasure drives when its mild and dry. Have an oil cooler, non thermostatic. HKS recommends an oil cooler and minimum 40 weight in the supercharger install manual. Actually, they recommend 42 weight or similar but I think that is a typo.
Got a deal on the Mobil 1 from a guy off Kijiji. I know, the Subaru turbo guys from NASIOC says its the devil's nectar for the EJ engines, but the FA doesn't seem to burn it.
I plan to track the car a few times this year.
Old 02-19-2016, 11:47 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I run Mobil 1 5w-30 oil since I'm supercharged
MS, CSCS, TSAC-F, CPT
Old 02-21-2016, 02:14 AM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
0w20 most temps go from 50-110F
Old 02-21-2016, 05:40 PM   #5
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Motul 5w-40 or Eneos 0w-50. My car is stored in the winter and sees only limited street use. I also have a non thermostatic oil cooler as well, I'm not supercharged but I would use the same if I was. 5w-20 is really just for fuel economy and emissions not for beating on it.
TRAKRAVN is offline   Reply With Quote
Old 02-22-2016, 06:48 PM   #6
empower-auto
Kouki-Monster
Originally Posted by Infamous Performance View Post
We generally recommend 5W40 for force inducted BRZ/FRS. We use Motul 8100 X-cess 5W40 at the shop. We have used this with great results under every driving condition we can find in So Cal.
bingo bango bongo.
Just ordered a bunch of this. Exactly what I was thinking. I ran 0W-40 Mobil last year but for the use it's seeing this year ... 5W40 Motul + RS*R Ran Up
Rich Anderson
EMPOWER AUTO
Old 02-25-2016, 01:04 AM   #7
Ndrew
Ndrew's Avatar
Drives: Scion FR-S Kraftwerks
0w20 ENEOS for me, I would try 0w30 soon
Ndrew is offline   Reply With Quote
Old 02-25-2016, 05:38 AM   #8
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
we are using the HKS HR 0W42
ST-A is offline   Reply With Quote
Old 02-25-2016, 08:31 AM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
I thought the 42 was a typo. Guess not.
Old 02-25-2016, 10:02 AM   #10
ST-A
Master Tuner
no it is specifically tested on the HKS boosted FA20 platform, also the MX-5 uses this oil.
This is ester based oil so you can make any oil inbetween the normal grades.
oil pressure is much more stable and oil temp keeps very constant.
Old 02-25-2016, 10:13 AM   #11
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
I run 5w30 Mobil 1 (High Mileage Oil) car has 10kmiles on it.
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 02-25-2016, 10:13 AM   #12
wbradley
Sarcastic SOB
wbradley's Avatar
Mobil 1 0W40 is also a true ester based oil (one of very few widely available in most stores) and is probably A LOT less expensive than HKS. I think it is the German spec oil.
The Following User Says Thank You to wbradley For This Useful Post:
ST-A (02-26-2016)
Old 03-15-2016, 11:29 PM   #13
Xiao Li
Xiao Li's Avatar
Drives: '14 BRZ, '01 S2K
I've been running Castrol Edge 0w30 for the last 20k miles supercharged. I posted all my UOAs in another thread if you want to check it out.
http://www.ft86club.com/forums/showt...=13286&page=21
Xiao Li is offline   Reply With Quote
The Following 2 Users Say Thank You to Xiao Li For This Useful Post:
hmong337 (03-15-2016), Jmonty (03-22-2016)
Old 03-16-2016, 07:37 PM   #14
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Eneos 5W-30.
Luftwaffel is offline   Reply With Quote
What header are you running/ supercharged fa20's only Epic_integra Engine, Exhaust, Transmission 15 03-30-2019 01:57 AM
Weight distribution after supercharged BRZ? Drakelee117 Forced Induction 8 02-08-2015 02:51 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
my supercharged brz zenny Member's Car Journals 17 04-29-2014 08:46 AM
My Supercharged GTS Aussie Willy Member's Car Journals 23 07-12-2013 06:06 PM
