Old 02-21-2016, 10:44 AM   #1
MG86
Drives: 2016 Asphalt FR-S
anyone able to confirm if these will fit?
got my heart set on a set of 18.9 +25mm 5x100 there MR7's
plan on getting 225 40 for tires
im on stock suspension and unsure if i will rub any information or suggestions would be greatly appreciated!
MG86 is offline   Reply With Quote
Old 02-21-2016, 10:53 AM   #2
Createddeleted
Drives: 2014 BRZ - 2004 GLI
http://autotk.com/tuning/subaru/brz/6352/
Don't know about inner clearance however. You're probably going to want to drop the car and add some camber because at stock height it's going to look funky.
Createddeleted is offline   Reply With Quote
Old 02-21-2016, 11:01 AM   #3
MG86
i do plan on doing that almost immediately after but for the time being
thanks for the link helped out a bit
Old 02-21-2016, 11:52 PM   #4
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
It will fit
tyler_win_photo is offline   Reply With Quote
Old 02-22-2016, 11:19 AM   #5
8R6
8R6's Avatar
Drives: FRS
itll fit easy. the wheel will poke out for sure, and on stock suspension with stretched tires, itll look... ummm... yeah.
8R6 is offline   Reply With Quote
Old 02-22-2016, 11:38 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Poking out and stretched quite a bit, probably best to find a proper fitting setup.
Old 02-22-2016, 12:19 PM   #7
DAEMANO
Time Traveller
I think @WRB5titch is running a similar fit (maybe et22ish though). It works, but will poke, and be a little stretched (just a little depending on the tire tread width). If you drop your car about 1.2" and run a minimumim of -1.25ish degress of camber in the front, it'll look good (wide but in a good way). Careful around the curbs too.
Old 02-25-2016, 12:21 PM   #8
MG86
ending up going with something else thanks for all the feed back
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 12:41 PM
Can anyone confirm that this is okay? gjca410 BRZ First-Gen (2012+) — General Topics 8 08-27-2014 02:41 PM
just to confirm..about 15inch wheels thebus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-07-2014 04:32 PM
Confirm Tranny Oil Mac1235 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-31-2012 02:37 PM
Anyone confirm the price with their dealer yet? rcubid Scion FR-S / Toyota 86 GT86 General Forum 3 04-27-2012 04:52 PM
