Old 02-21-2016, 11:22 AM   #1667
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Originally Posted by HachiRo View Post
Anyone running RS3s on 17x9? I'm wondering if I should go 255 or 245. I like the square tire look, will be doing spirited driving, but I'm definitely too amateur to notice the difference in grip I'm sure. Would it still be a better future investment to go 255?
For autoX the 245 RS3s were faster on this chassis than 255s on 17x9
We've all moved onto the new Bridgestone RE71r but we are all running 245/40 on 17x9, not 255s.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
HachiRo (02-21-2016)
Old 02-21-2016, 11:23 AM   #1668
BlaineWasHere
Grip>Drift
Drives: FRS
Originally Posted by TRDGriffon View Post
Thanks! Sorry for the late reply but the wheels are 18x9.5 et38, 255/35R18 tires, running coilovers and adjustable lcas. 1.6 degrees of camber up front and 2.8 in the rear.
You should flip the camber front to rear if you actually want your car to handle properly.
I run -3F and -1.8R
The Following 4 Users Say Thank You to BlaineWasHere For This Useful Post:
ATL BRZ (03-08-2016), DustinS (02-25-2016), Hicklinc (02-25-2018), Jive Turkey (02-22-2016)
Old 02-21-2016, 12:30 PM   #1669
cjd
cjd's Avatar
Drives: 2017 BRZ
I still have 255 in the RE71R... Need to take some camber out in the back though, -3.3f/-2.8r, think I may go to -2.3r. Wear in the front seemed pretty good so not sure it's too much, but pondering a change to -3/-2
The Following User Says Thank You to cjd For This Useful Post:
Old 02-21-2016, 01:47 PM   #1670
TRDGriffon
Drives: 2016 Halo FRS
I run -3F and -1.8R
I'm well aware my alignment specs aren't ideal for handling, but the car is just a weekend car at them moment and with just over 1k miles I have no desire to take it to the track any time soon. My main goal was to fit as much wheel/tire as I could without modifying the body. When I can afford some RCE T2s then I will start worrying about having an alignment more geared towards handling. But for now unfortunately form>function.
TRDGriffon is offline   Reply With Quote
Old 02-21-2016, 01:51 PM   #1671
BlaineWasHere
Grip>Drift
Drives: FRS
Have you tried 245 stones??? I'm about to buy a new set for 2016 season and I can fit 255s. I've tried both in RS3 (which 245 was preferred for me personally) but this a new tire.
Old 02-21-2016, 01:52 PM   #1672
BlaineWasHere
Grip>Drift
Drives: FRS
Oh are you not on coils? I didn't catch that. Makes a huge difference in clearance for wide wheels/tires and stock fenders.
Old 02-21-2016, 03:50 PM   #1673
cjd
cjd's Avatar
Drives: 2017 BRZ
I haven't. I found that I was dropping pressures toward the end of the season (confidence finally improving, though surface temps also dropping.) That's contrary to what I've heard others say they did with 255's, but my times were improving quite a bit and I wasn't having issues rolling over the sidewall. Some of that may have been the camber thing. I imagine a lot will change after the camber change.
It should also be noted that I have very different spring rates than many seem to run, so even if I ran 245's and preferred 255's (hasn't happened so I don't know) that may be specific to my setup. Maybe I'll have the opportunity to swap tires with someone else in the class this year, maybe not.
I've heard many describe their preference for the 245 RE71R in the same way the RS3 was described - a bit more responsive feel, especially on transitions.
I admit I'm a little unsure on the matter - while I respect the observations, the fact I found I needed the opposite tire pressure adjustment makes me wonder - either I'm really lost (it's possible I preferred the handling so was more aggressive, but the car was slower overall - or that it really did improve things...) or it's not quite so simple after all.
C
Old 02-21-2016, 06:13 PM   #1674
BlaineWasHere
Grip>Drift
Drives: FRS
C
You were probably going faster because your driver mod was getting better despite whatever you were doing with the pressure.
Old 02-25-2016, 03:36 PM   #1675
Aev
Drives: 2015 Scion FR-S
so from all this ive gathered there is no way im going squeeze a 18x9.5 wheel up front peacefully without coils?
Aev is offline   Reply With Quote
The Following User Says Thank You to Aev For This Useful Post:
texasbound972 (02-25-2016)
Old 02-25-2016, 03:37 PM   #1676
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
True.
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 02-27-2016, 03:33 AM   #1677
TOUGEerrDay
TOUGEerrDay's Avatar
Drives: Argento
[IMG][/IMG]
Tires: Sumitomo HTR Z III 255/35r18
Wheels: WORK Meister S1R 18x9.5 +38
TOUGEerrDay is offline   Reply With Quote
The Following User Says Thank You to TOUGEerrDay For This Useful Post:
gMit (02-29-2016)
Old 02-27-2016, 03:36 PM   #1678
Aev
Alright then I assume a spacer up front on eibach sportlines would be out of the question as well?
Old 02-27-2016, 03:44 PM   #1679
Aev
Originally Posted by texasbound972 View Post
True.
Old 02-27-2016, 04:03 PM   #1680
texasbound972
USMC
I have no idea. I'm sure it's worth a try.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
