Old 02-12-2016, 04:19 AM   #1
customfab87
customfab87's Avatar
Drives: 2014 FR-S 6MT
SOLD: Sprintex/Innovate Twin Screw Non-Intercooled Supercharger
*SOLD*
Sprintex/Innovate Twin Screw Non-Intercooled (5.2 PSI) Supercharger. Includes all the components (Belt, hoses, brackets, etc) for install. No fuel tuning provided. I just tuned using an OFT with RomRaider.
This supercharger really impressed me on how much torque it produced down low. Made 232whp at only 5 psi on E85, but the impressive thing was that it produced a flat 175lb/ft of torque. Probably the best F/I solution for a daily driver, as there is no lag in power. It's also very easy to install. Should take a person with average mechanical skills one afternoon to complete.
I have used the supercharger for about a year. The kit is in mostly good condition. However I let the oil run a little low once, so now it's making some noise on decel around 3k rpm. It still makes great boost, just a little noisy. When we took the blower off the manifold and opened up the back cover, we saw no rotor coating or housing wear. (See photo of the rotors below) The front bearing had no play or discoloration. Therefore it looks to be a great candidate for a future rebuild. I just don't have time to play with cars anymore. Otherwise I would have eventually sent this in to be rebuilt myself.
John Bond charges approximately $700 for a rebuild and actually replaces the bearings, seals, and oil with better quality components than what Sprintex used.
http://jonbondperformance.com/index....roducts_id=190
Asking $1,700 obo
customfab87 is offline   Reply With Quote
Old 02-17-2016, 11:45 PM   #2
customfab87
Added more photos. Everything is included. The rotors are in great shape, as you can see from the photos.
Old 02-18-2016, 02:14 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
supercharger whine, low boost, easy to install, safe for non-built motor.
Pickup a delicious tuning flex fuel unit+tune and enjoy more power too.
I'm very happy with my sprintex/innovate kit on my own car
The Following User Says Thank You to continuecrushing For This Useful Post:
raven1231 (02-24-2016)
Old 02-18-2016, 04:35 PM   #4
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Can you use the non intercooler kit safely on pump fuel? What if e85 isn't available?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 02-18-2016, 07:57 PM   #5
continuecrushing
pump fuel will work great! With the correct tune of course
Old 02-19-2016, 11:10 AM   #6
brybot
Drives: 13 DGM BRZ 6MT
How much concern should the noise and "candidate for future rebuild" cause? Does it need to be rebuilt before install to avoid unnecessary wear?
This is something I would be very interested in if it weren't for that piece of information... and if you wanted to ship it.
brybot is offline   Reply With Quote
Old 02-19-2016, 06:08 PM   #7
customfab87
It's a chirping sound, which indicates slight bearing wear. It's not a problem until there's so much play that the rotors start touching the housings, which is not the case here. You can pretty much start out with Shiv's tune for the ESC as a baseline. Just choose either the gas or E85 map.
Old 02-20-2016, 05:08 AM   #8
kev60625
Drives: 2013 WRB Subaru BRZ
Willing to ship at all?
kev60625 is offline   Reply With Quote
Old 02-22-2016, 05:17 PM   #9
brybot
PM'ded
Old 02-24-2016, 11:38 PM   #10
HAWAIICALIVEGAZ
HAWAIICALIVEGAZ's Avatar
Drives: HONDA, TOYOTA
Where are you located
Sent from my SM-N900V using Tapatalk
HAWAIICALIVEGAZ is offline   Reply With Quote
SOLD:(DELETE) Innovate Twin screw supercharger STAGE II bFran11 Engine, Exhaust, Bolt-Ons 21 05-27-2015 01:26 PM
Sprintex Innovate Twin Screw supercharger Intercooled kit Bluetail Engine, Exhaust, Bolt-Ons 23 05-20-2015 04:41 PM
FS: Sprintex (Innovate) supercharger (non-intercooled) dpgfunk Engine, Exhaust, Bolt-Ons 10 05-02-2015 07:01 AM
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 01:49 AM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 10:14 PM
