Old 02-09-2016, 12:24 AM   #1
illmatic_frs
illmatic_frs's Avatar
Drives: n/a
Customizing the torque curve using ROM Raider
Hi all,
New to tuning. Got my OFT+OFH. Running Stg 2 91 Oct. Have used ROM Raider to change LC and try out the exhaust pops. Pleased so far but..
I'd like really to change the characteristics of the low end.
In particular I'd like to keep the car docile from 800-2200rpm then produce a 'jump' in power delivery from 2200-2600rpm (where the nice torque starts). Then from 2600-redline, run the as-is OTS program.
Just want to see if this can be done, and entertain myself a few days til I try something else
Any suggestions on what tables I'd like to 'flatten' in ROM Raider to produce this effect? Is it just Base Timing B? Or a bunch of others?
Appreciate any insights, suggestions or training links so I can learn RR and DIY...
Cheers
illmatic_frs is offline   Reply With Quote
Old 02-09-2016, 12:29 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by illmatic_frs View Post
Hi all,
Cheers
So you want to detune the lower RPM's to make less power so that you "feel" like your going fast once you hit 2600rpm?
Old 02-09-2016, 03:36 AM   #3
steve99
Drives: FT86
you would probably have to change the throttle charasteristics look at the drive by wire throttle tables dbw, its quite complex, i have it but its possible use goodle to search this site for throttle mapping chamges or dbw tables ect
illmatic_frs (02-09-2016)
Old 02-09-2016, 04:27 AM   #4
illmatic_frs
Drives: n/a
Yup. Boost but without boost
Sounds absurd but hey.
Sent from my HTC One M9 using Tapatalk
The Following User Says Thank You to illmatic_frs For This Useful Post:
go_a_way1 (02-09-2016)
Old 02-09-2016, 04:33 AM   #5
illmatic_frs
Drives: n/a
I got the idea today while driving in light snow. I started off a stop sign and there was partial traction. Then the tires grabbed and I had a nice push into my seatback. It was just around 2400 rpm. It actually felt just like the moment when you lag and then boost kicks in. So yea that's where the inspiration came from.
Old 02-09-2016, 04:38 AM   #6
swarb
The torque dip at about 3800rpm is bad enough, you want to create another one? Dual stage v-tek?
I read somewhere that the stock car is made purposely with the torque dip because at low rpm=better mpg and at a track at high rpm, you would never go below 4k.
My guess would be play with the timing and take some advanced timing out.
Oh and trying to get that pull at low rpm and with a small displacement motor... don't expect much.
The Following User Says Thank You to swarb For This Useful Post:
Old 02-09-2016, 04:51 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
swarb: i wouldn't be so sure about torque dip being intentional, rather imho it's unplanned sideeffect of stock header design, as many aftermarket headers, especially UEL ones or Ace's EL fix that dip, without worsening mileage at low rpm.
Old 02-09-2016, 02:36 PM   #8
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
pull timing, your mpg in daily driving will suffer though
B T is offline   Reply With Quote
Old 02-15-2016, 02:12 AM   #9
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
This, plus some dialed back Base Timing B could do it
Hi all,
Cheers
You can get that effect with the right AVCS and Ignition Advance timing. I'm usually trying to get rid of this effect, rather than trying to cause it. I usually end up just flogging it when it runs like that, because it's just depressing to try accelerating gradually when it has no power. The main reason I can't put up with it running like that is mileage though. It just sucks gas when it's flogged. Take a look at this table. It would run like you want it to.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
illmatic_frs (02-15-2016)
Customizing BRZ Navigation Start Up Screen GrimmSpeed DIY (Do-It-Yourself) Guides 318 01-25-2021 12:26 AM
The FRS torque curve smbrm Scion FR-S / Toyota 86 GT86 General Forum 29 06-30-2016 05:10 PM
Help w/ OFT and Rom Raider Cooperdh Northwest 5 09-20-2015 06:21 PM
Customizing Start Up Screen on the BRZ ShibaYuki CANADA 9 06-28-2014 03:01 AM
Ideal street torque curve Bischoff Forced Induction 29 05-03-2014 11:53 AM
