Old 02-12-2016, 07:59 PM   #1
FRSure
Drives: Toyota
Winjet Projector Problem
So I have recently ordered some winjet headlight..
I have this weird beam pattern that I can't figure out what's causing it.
I have tried removing the bulb, and putting it back in. Didn't work.
This is the passenger side.
As you can see there is a laser beam like light.
FRSure is offline   Reply With Quote
Old 02-12-2016, 08:23 PM   #2
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
It looks like a bulb seating issue, perhaps a crooked bulb.
Did the Winjet headlights come with their own bulbs? Or did you have to reuse your factory headlight bulbs? If you had to reuse your factory headlight bulbs, they might not be the correct bulb type for the Winjet headlights.
However, since you only have the issue with one headlight, one thing you can try is switch bulbs with the other side, and if the problem persists, I'd say it's a defective projector/headlight.
Si_Chris is offline   Reply With Quote
The Following User Says Thank You to Si_Chris For This Useful Post:
Cole (02-12-2016)
Old 02-12-2016, 08:25 PM   #3
FRSure
Drives: Toyota
I'm using the bulb that came with the winjet headlight. At first I had HID Installed on it but the HID bulb did not work so I took it out and reordered HID kit.
Then I put back in the H7 halogen bulb that came with it..
I have no idea what is causing that to happen
Old 02-12-2016, 08:28 PM   #4
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
defected item?
FR-Sky is offline   Reply With Quote
Old 02-12-2016, 08:33 PM   #5
Si_Chris
Definitely try swapping the passenger bulb to driver side and vice versa. Compare the two bulbs when they are out to make sure they are identical. If you have the same problem still, I'd say it's a defective projector.
Old 02-12-2016, 08:48 PM   #6
FRSure
Drives: Toyota
Gonna do that first thing tomorrow morning. They are identical H7 bulb. Question is .. If the bulb is faulty, it is still the projector projecting the light ..
This is confusing
Old 02-12-2016, 09:03 PM   #7
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
its probably the bulb position? just play with it a bit
Old 02-12-2016, 09:42 PM   #8
Ashikabi
Ashikabi's Avatar
Maybe the lens on the projector is crooked?
Old 02-12-2016, 09:54 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Looks alot like an upside down bulb issue, the little tab on the top of the bulb sits in the direction of the H7 hinge. Also it should be all the way in it's very easy for a wire to get caught between the prongs and bulb or vice versa and effect the seating of the bulb.
Old 02-12-2016, 09:55 PM   #10
FRSure
Drives: Toyota
Gonna put in a HID bulb tomorrow or swap another H7 bulb tomorrow.. If that doesn't work.. I don't know what to do
If the lens s crooked wouldn't it just aim somewhere else?
I don't think the bulb is upside down.. I tried reversing it , but it wouldn't lock in.
Old 02-12-2016, 09:58 PM   #11
FRSBRZGT86FAN
This is confusing
What? No, if you swap the bulbs and the problem moves to the other side then you know its the bulbs otherwise it's the projector simple.
Also shameless plug the diode dynamics or morimoto HID kits fit perfect at 5000k or 5500k in these headlights they may be expensive but are totally worth it.
Old 02-12-2016, 10:01 PM   #12
FRSBRZGT86FAN
It's easier to do correctly on a table with the headlights off the car
[ame="https://www.youtube.com/watch?v=khbLOrzAvA8"]Scion FR-S Winjet JDM Replica Headlight - HID Install Video - YouTube[/ame]
Old 02-12-2016, 10:02 PM   #13
xcooperx
Drives: FR-S 2015
Did you try to adjust the headlight already? That little screw u see at the back of the unit, also dont use the bulb that came from the unit, mine only lasted a month, so i decided to change it with hid
xcooperx is offline   Reply With Quote
Old 02-13-2016, 10:11 AM   #14
FRSure
Drives: Toyota
I swapped it out for a HID bulb and another H7 halogen bulb , and I still have the laser beam problem.. What's next ?
*** Winjet Projector Headlights & LED Taillights - IN STOCK @ Sonic Motor *** Sonic Motor Exterior Parts - Lighting 500 07-29-2016 02:15 PM
For Sale: WinJet FR-S chrome Projector Headlights (JDM LOOK) Best Price $150 taylorz Exterior Parts (Aero, Lighting, Etc.) 17 02-25-2016 07:24 PM
Cosmetic Non-projector Headlamps? & Opinion on Winjet, others SR5 Cosmetic Modification (Interior/Exterior/Lighting) 15 04-11-2015 03:08 PM
FS: NEW Scion FRS FR-S Winjet Projector Headlights Black w/ 6k HID, DRL Mod & Relay! STS-V Exterior Parts (Aero, Lighting, Etc.) 2 04-22-2014 07:34 AM
