Old 02-10-2016, 01:14 PM   #1597
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Joaco View Post
How are you liking those GT3 brake ducts?
Have you noticed a difference on pad wear between the inside and outside?
They work ok for short runs but anything longer than a few laps they are not sufficient. Thankfully Velox Motorsports has an innovative brake cooling kit coming out soon that I will be installing. It will use the factory BRZ fog light housings (which I already have installed) and hoses via a blow molded pancake pipe to sneak around the outside of the wheel well liners and onward directly to the rotors via a backing plate. Shortest possible route for cool air.
Old 02-10-2016, 03:41 PM   #1598
ATL BRZ
ATL BRZ's Avatar
Never been so excited to cut holes in something. Just received my Velox Motorsports modular hood vent kit with rain guards! These are gorgeous!
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (02-10-2016), DustinS (02-15-2016), MaximeT (02-10-2016), VerusEric (02-10-2016)
Old 02-10-2016, 03:56 PM   #1599
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I talked to you on the book of faces about this. I'm VERY interested to see your install. If the GT3 ducts don't do enough for me (and why would they? they don't work for you with your BBK) I'll be doing the same, but with stock brakes for now.
Also, do you happen to have that pic of your car with glowing disks in higher res than on facebook? I need a new wallpaper
Old 02-10-2016, 04:47 PM   #1600
ATL BRZ
ATL BRZ's Avatar
Velox already posted all these on the book of faces but I'll toss em up for ya.
I gotchu: http://i.imgur.com/Zy6oJYd.jpg
Just don't tell anyone that it's (poorly) photoshopped
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (02-10-2016), Takumi788 (02-12-2016)
Old 02-10-2016, 05:43 PM   #1601
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Haha, thanks. I hadn't seen the pics Eric posted of the ducting, just the intake and hub side mount. Good stuff!
The Following User Says Thank You to DocWalt For This Useful Post:
ATL BRZ (02-10-2016)
Old 02-12-2016, 09:17 AM   #1602
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Cannot wait for those brake ducts!
I noticed you are a HPDE instructor so you probably have some knowledge on this matter. I see you run the stock seats with a 4 point harness and hans. Is this an accepted practice for HPDE?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
ATL BRZ (02-12-2016)
Old 02-12-2016, 09:24 AM   #1603
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
x2
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 02-12-2016, 09:24 AM   #1604
ATL BRZ
ATL BRZ's Avatar
Yes it's been approved by like 5 different local track club tech inspections as well as the owners of both Discovery Parts and HMS Motorsports. I also use a HANS device which has been tested and approved by Schroth for compatibility and use with the Profi II ASM harnesses. I highly recommend using both if you're also running the stock seats. Don't forget a harness bar that puts the shoulder straps at the correct angle (at almost level or slightly lower than your shoulders, Schroth specifies this in the install manual) to hold you down in your seat in an impact.
LOLS2K (02-12-2016), Takumi788 (02-12-2016)
Old 02-15-2016, 12:22 AM   #1605
secret.squirrel
secret.squirrel's Avatar
Drives: GT86
When you deleted the washer fluid tank, did you replace it with something elsewhere to do the same funtion? If so, what? Much love for this car, the build thread has already made me put in a couple of orders to FT86speedfactory for bits to take home with me....
secret.squirrel is offline   Reply With Quote
Old 02-15-2016, 12:33 AM   #1606
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Somehow I doubt it...he doesn't have side windows, heat, music, or 3rd brake light. I'm guessing windshield washer reservoir/pump/wiring/tubing would be right out the window. If he had one.
Source: Went on a drive through the mountains with him today in 20 degree (F) weather. His girl rode shotgun. Most hardcore shit I've seen in a long time. Sickest car in the group.
killboy is offline   Reply With Quote
Old 02-15-2016, 09:25 AM   #1607
ATL BRZ
ATL BRZ's Avatar
No, deleted it completely but left the wiring and lines. Windex and a microfiber get the job done just fine.
You've got me confused with @Reaper
The Following User Says Thank You to ATL BRZ For This Useful Post:
killboy (02-15-2016)
Old 02-15-2016, 09:35 AM   #1608
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
@killboy not my girl. Just an old friend who wanted to ride in a real racecar instead of the spray painted v6 mustang drift car her ex husband "drift raced". Whatever that means...
The Following 2 Users Say Thank You to Reaper For This Useful Post:
DustinS (02-15-2016), killboy (02-15-2016)
Old 02-15-2016, 10:28 AM   #1609
Takumi788
JHerbert Racing
Takumi788's Avatar
I did the same thing when I deleted mine. I never used it anyway. 3 years of ownership I had a little more than 3/4 full of the factory washer fluid.
Old 02-15-2016, 11:59 AM   #1610
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
I drained mine the first chance I got. Will eventually remove it totally, but wanted to hold off popping the bumper until other parts start going in!
GTHachiRoku is offline   Reply With Quote
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
