| Engine Swaps Discussion of engine swaps. |
#15 | |
Proud of BOXER
Drives: Subaru Boxer
Ah, sponsorship deal. That explains it.
| The Following User Says Thank You to Clipdat For This Useful Post: | JS + BRZ (07-23-2015) |
#16 |
Drives: 14 Subaru BRZ Limited WRB
Awesome car but those wheels gotta go
#17 |
Drives: 2015 brz
Nice, keep them coming
#18 |
Drives: FRS Silver LS1 swapped.
Having owned a 2012 Boss and now a FRS can't imagine how awesome this combination might be.....pulling plugs though has got to be a bitch.....
#19 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
On a related note, I'm having issues sourcing lots of 1UZ stuff, and I saw the coyote first fire video several weeks ago, idea wheels have been turning. Noting that they apparently did a cut-and-weld hack job on the oil pan.... Why not just use a Canton front-sump? Wonder if they had to relocate the MT82 shifter or if it just lined right up? It's really easy to relocate as is, and the stock remote linkage is begging for reinforcement anyway... The way the article is describing the shifter feel it sounds like they may have dropped the MGW unit on...
There are many ways to displace.
-Spartarus Last edited by Spartarus; 07-24-2015 at 06:15 PM. |
#20 |
MGW is a good fix, wasn't to impressed with the Chinese getrag and the feel....the MGW made a difference for me. Brain farted on plugs.
#21 | |
...Just add nauseum
We all do that haha. Pity so few people tore apart that MT-82 transmission, there were only a few really small things wrong with it; it didn't deserve the bad rep it had. It needed a more solid linkage - Blowfish and MGW race spec did that just fine. With some really minor internal upgrades it would hold all the power shifts and abuse you could throw at it. Stamped shift forks needed re-welding, and all the plastic shift pads and shift stops needed replaced with brass ones. After that, it's better than any transmission I've ever driven... The synchros are good for any RPM you can throw at them.
-Spartarus |
#22 |
Drives: GS F-sport | LS F-Sport
This car is an amazing piece of work. Got to check it out over the summer and its super impressive!
![]() ![]() I hope to do an expose on it next year. |
| The Following User Says Thank You to mike@vossen For This Useful Post: | NyC Zn6 (12-07-2015) |
#23 |
Drives: 2015 Halo FR-S
Having been a former owner of a Coyote V8 powered Mustang I can get behind this, however I wonder if the increased weight over an LS series engine would be worth it. Also, the chinese Getregs are known to be pretty unreliable so your cheap 6 speed option would be out.
#24 |
Stig's dark passenger
54/46 weight balance
LMAO |
| The Following User Says Thank You to D K For This Useful Post: | DAEMANO (02-10-2016) |
#25 |
Time Traveller
#26 |
Sarcastic SOB
Cool car when competing for highest numbers. And, low key looking to boot.
In reality, probably a barely manageable time bomb if you hit the accelerator slightly too much. Would be fun to drive with extreme care.
| The Following User Says Thank You to wbradley For This Useful Post: | DAEMANO (02-10-2016) |
#27 | |
Drives: blue - Cosworth SC stage 3.0
its coming http://www.autocar.co.uk/car-news/ne...carbon-process |
#28 | |
Drives: RAVEN
Quote from build article: "Understand that Tasukon was forced to dumb down the throttle nearly 20 percent at speeds slower than 30 mph just to retain some semblance of grip and drivability" As to the wheels, I bet they picked something that looked similar to stock wheels. This thing was meant to fly under the radar. The good news is that many such swaps now carry over the electronic gas pedal. Many a big power swap has ended up with twitchy low speed throttle response due to the mechanical linkage design that might have been less than ideal. And while it would be sacrilegious to most of this crowd, I would have built it with an auto-tragic gearbox, cause when you have that much surplus power, why shift your own? Plus the clutch ended up sucking in this case, as do most high performance clutches. Would love to go for a drive and see how it compares to a V8 Miata. Last edited by NOHOME; 02-10-2016 at 05:20 PM. |
| RightFootDown-Video: Stock Scion FRS versus Turbo Scion FRS, Street Comparison | kanundrum | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 06-09-2015 12:47 PM |
| Scion Ride and Drive- Good Info Inside, straight from Scion District Managers! | clevrname | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 06-16-2012 08:39 AM |
| Scion FR-S Behind the Scenes with Scion VP Jack Hollis scion | UriarteMD | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 19 | 06-14-2011 07:13 PM |
