Old 02-01-2016, 01:19 AM   #1653
Sherb
Drives: Brz
Sherb is offline   Reply With Quote
Old 02-01-2016, 05:23 PM   #1654
whataboutbob
AutoX-10/10ths every run
295/35R18 NT05 on 18x9.5et45 PF01.
Build thread:Here
The Following 5 Users Say Thank You to whataboutbob For This Useful Post:
MisterSheep (02-01-2016), mitch t (02-29-2016), oldlostcory (02-02-2016), sactownbwoy (02-03-2016), SuperDave (09-09-2016)
Old 02-01-2016, 05:24 PM   #1655
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by sr86 View Post
Anyone tried using Nitto tires NT555r? Hows the great and performance of it?
I have the Nitto Invo's and the quality of them is great. They work as advertised and I do plan on sticking with the brand. My next set will be some of those track tires they sell
whataboutbob (02-01-2016)
Old 02-02-2016, 05:37 AM   #1656
brz11b
Drives: United States
Originally Posted by koukiboss View Post
Been wanting to play in this thread for a while!
18x9.5 et38
265/35/18 Dunlop DZ102
loving this setup, can you tell me what your suspension setup is. I have these same size rpf1's ans I'm trying to find the right coil and lca setup.
brz11b is offline   Reply With Quote
Old 02-02-2016, 06:31 PM   #1657
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Originally Posted by TRDGriffon View Post
255s on my 2016
That's like the perfect drop, wheel specs? spring? coilovers? LCA? camber ratings?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 02-04-2016, 02:24 AM   #1658
Victoria SiR
Let me help you out there:
http://www.ft86club.com/forums/showt...44#post2529344
Victoria SiR is offline   Reply With Quote
Old 02-09-2016, 03:30 PM   #1659
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
its like everyone disregards first post, entire thread, build threads, and just quotes photos with questions that have been answered a million times.
what is the "right" coil setup?
basically any coilover on the market will get you the drop you want. what you should be concerned with is built quality/dampening/spring rate/street ride and not aesthetics. if you don't care about any of the technical info just go with the taiwanese stuff everyone runs because it will get you the look for not a lot and will just make the car stiff.
if you just want a good streetable coilover that "entry level" then get RCE tarmac zero with upgraded spring rates or if thats too much look into ST coilovers. if you have a bit more to play with pick up a set of KW V3, can be found for not THAT much. Will need tophats too.
also depends on if this will be driven all year round and where you live. most cheap stuff goes to shit really fast and will seize.
i would recommend SPC LCA if on a budget and don't care for bling (its what i run) or SPL if you have money to blow and want the best.
Jive Turkey is offline   Reply With Quote
The Following 3 Users Say Thank You to Jive Turkey For This Useful Post:
brz11b (02-10-2016), Leonardo (02-09-2016), MaXimus (03-08-2016)
Old 02-09-2016, 03:34 PM   #1660
Jive Turkey
the tuna, no crust.
Originally Posted by swarb View Post
Anyone remove the rubber trim around the rear fenders? Is it painted under? I am having rubbing issues and not sure if it is the rubber trim or the bumper tab. Possibly both.
are you talking about the seam-sealer on the lip?
you may want to roll your rear fenders if you're rubbing on that. the rear bumper tab will continue to shave down as you rub so you should see what you're rubbing on in there.
Old 02-09-2016, 10:33 PM   #1661
ShootinPutin
Drives: None
Originally Posted by DIM View Post
Finally got some new shoes for it! Enkei RS05RR's wrapped in MSS 265/35.
Are you on springs or coilovers?
ShootinPutin is offline   Reply With Quote
Old 02-10-2016, 08:23 PM   #1662
Jive Turkey
the tuna, no crust.
265 tires up front = coilover....
Old 02-10-2016, 11:29 PM   #1663
2.superslownj
Drives: 2014 Raven FRS
255/35.. Going 265 in spring
2.superslownj is offline   Reply With Quote
The Following 3 Users Say Thank You to 2.superslownj For This Useful Post:
FujiwaraTofu86 (02-16-2017), Jive Turkey (02-21-2016), trigger happy (04-07-2016)
Old 02-14-2016, 02:12 PM   #1664
TRDGriffon
Drives: 2016 Halo FRS
Thanks! Sorry for the late reply but the wheels are 18x9.5 et38, 255/35R18 tires, running coilovers and adjustable lcas. 1.6 degrees of camber up front and 2.8 in the rear.
TRDGriffon is offline   Reply With Quote
The Following User Says Thank You to TRDGriffon For This Useful Post:
SmartedPanda (02-15-2016)
Old 02-14-2016, 02:50 PM   #1665
HachiRo
Drives: 2013 White-Out FRS
Anyone running RS3s on 17x9? I'm wondering if I should go 255 or 245. I like the square tire look, will be doing spirited driving, but I'm definitely too amateur to notice the difference in grip I'm sure. Would it still be a better future investment to go 255?
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 02-21-2016, 03:44 AM   #1666
Jive Turkey
the tuna, no crust.
why so much camber in rear?
both will be square, no you won't be able to tell at all.
here is a 255 rs3 on a 17x9 on a friends STi. I think this is a 40 sidewall.
here is 245/45 rs3 on 17x9 on an s2000 my friend has.
HachiRo (02-21-2016), Hicklinc (02-25-2018), VMRamos (02-21-2016)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
