Old 02-09-2016, 05:40 PM   #1
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
Wheels brand to avoid?
Hey everyone, Trying to find out what wheel brand should be avoided, I do see that some Reps wheels are pretty good in quality, so I don't want to cross all of them out. I already search the wheels sticky and section and couldn't find an answer, along with Google. Shopping around for some wheels/tires in the 18" size while trying to get a flush fit with Coils.
So what wheel brand that should be avoided?
Thanks!
xFury is offline   Reply With Quote
Old 02-09-2016, 05:41 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thanks!
Any knockoffs and all ebay brands if you ask me lol.
xFury (02-12-2016)
Old 02-09-2016, 05:43 PM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
The Following User Says Thank You to NyC Zn6 For This Useful Post:
go_a_way1 (02-09-2016)
Old 02-09-2016, 05:44 PM   #4
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I think it depends on your expectations.
If you expect a gravity cast replica wheel to be as durable or as light as the authentic forged wheel that it's copying, then you're going to have a bad time.
That said, I wouldn't bother with replicas, since Enkeis are cheap and durable enough.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
xFury (02-12-2016)
Old 02-09-2016, 05:45 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
make sure to get circular wheels, the triangle/square designs are pretty rough rides
The Following 7 Users Say Thank You to continuecrushing For This Useful Post:
8R6 (02-09-2016), Antuono (02-09-2016), DustinS (02-12-2016), go_a_way1 (02-10-2016), Leonardo (02-09-2016), olsonpg (02-09-2016), xFury (02-12-2016)
Old 02-09-2016, 05:52 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I don't like Focal wheels.
Anything that has been "repaired" I would run away from also. Though used can be the way to go. I have had several sets of good used wheels.
xFury (02-12-2016)
Old 02-09-2016, 06:25 PM   #7
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Just buy rays/enkei/gramlights/ssr, and others I'm forgetting off the top of my head, and call it a day.
Instagram: trevor.parque
xFury (02-12-2016)
Old 02-09-2016, 06:50 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Any brad that is misspelled, probably fake.
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Ultramaroon (02-11-2016), xFury (02-12-2016)
Old 02-09-2016, 06:51 PM   #9
HachiRo
Drives: 2013 White-Out FRS
There's a huge stigma that Reps will crack or break under all circumstances. My buddy who's a vendor for Vordovon sent me pics of Forme 9's that hit a huge dip and they're F***ED UP, but no bending, cracking, or breaks. That being said, you still can't expect durability and quality from all reps and shouldn't get too comfortable on them. XXRs are popular because they're affordable which means more people will buy them, which in turn, means you'll see more negative posts about them, but my coworker runs XXRs on his Stang and he's never had issues. Then again, Ambit Wheels had a huge post on them all over FB about how they broke on some guy's first track run with them (For those wondering, Jonathan Hurley posted the story and it was shared around.)
People are gonna say "Real wheels get damaged too!" well, they get damaged in different ways and under different circumstances. The only things I've seen happen to real wheels are bends and that's due to driving at high speeds/track/drift events and it's a bend, not a crack or break that could be catastrophic (though it isn't to say bends can't be.)
If you're looking for affordable wheels with good quality, definitely look into the above-mentioned brands such as Enkei, Gramlights, and Cosmis even.
Buy used to save a couple of hundred bucks!
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
The Following User Says Thank You to HachiRo For This Useful Post:
xFury (02-12-2016)
Old 02-09-2016, 07:12 PM   #10
Antuono
Drives: 2014 BRZ
I say stay with Steel wheels...They will never fail you and MANY MANY choices in hub caps.
XXR Duaa
Antuono is offline   Reply With Quote
The Following User Says Thank You to Antuono For This Useful Post:
xFury (02-12-2016)
Old 02-10-2016, 09:24 AM   #11
Ashikabi
Ashikabi's Avatar
Reps are fine IF you aren't racing. You will sacrifice community credibility if that's your thing and you will sacrifice strength and weight. They won't spontaneously explode and if you happen to break one you're only out a couple hundred bucks. For DD they work fine as there are many thousands of cheap wheels on the road today and we aren't hearing about the genocide Rota and XXR wheels caused. If you are doing any racing at all... buy good wheels, research any brand you find interesting. Enkei is a great start. Kosei makes a couple really light ones in good quality but I don't think they make 18s
The Following User Says Thank You to Ashikabi For This Useful Post:
xFury (02-12-2016)
Old 02-10-2016, 01:06 PM   #12
kch
Senior Misanthrope
kch's Avatar
A guy in our group tracks on Rota Titans and they seem to be holding up to his abuse. But Rota is a separate class of reps, in my opinion.
Old 02-11-2016, 03:06 AM   #13
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
There are tons of wheels out there. If you don't want to downgrade your stocks, look for pressure cast / tilt cast flow formed rim manufacturing process, or forged if you can afford it. Tirerack allows you to filter for this, so it's pretty easy. But they don't carry every mfg. the cheapest is gravity cast, they literally pour liquid metal in a mold and call it a day. Try to find wheels under 20 lbs, since that is the weight of the stock ones.
Have you ever watched how they make ninja swords? They keep folding the metal upon itself and hammering away. It makes it much stronger.
mike_ekim1024 is offline   Reply With Quote
The Following User Says Thank You to mike_ekim1024 For This Useful Post:
xFury (02-12-2016)
Old 02-11-2016, 06:16 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
Yes, forged are strongest. Yes, MAT formed cast are stronger then gravity cast .. but it's not all there is to it. Price also can make important 'property' of wheel. For example Kosei K4R given their low weight and simple casting process might be not that strong and easy to damage .. but at $199 for wheel you can buy 3-4 sets of four of them for price of forged set and replace if broken many times over.
Cole (02-11-2016)
Dealerships to AVOID in the SE Dave-ROR Southeast 62 05-14-2022 12:03 PM
What sites do you avoid if you are %$@*! merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 6 07-05-2013 12:55 PM
For those in NC avoid this red FRS Zgrinch Southeast 2 05-19-2012 03:30 PM
