Old 02-03-2016, 05:06 PM   #421
celek
Resident Gear Head
celek's Avatar
Well still working off things on the To Do list. I finally decided on a Tuner and Flex fuel system to finish up the build. I am Going with Moto East. I spoke with them on the Phone today about mid summer tuning. So I need to finish up this engine.
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
sato (02-04-2016)
Old 02-08-2016, 12:52 PM   #422
celek
Resident Gear Head
celek's Avatar
While waiting to build up funds for Valve train I spent a little on some R&D for a new Oil Pan Baffle. More parts inbound but I have the main template made. Need to create the walls for trapping around the pickup as well.
radroach (02-08-2016)
Old 02-08-2016, 02:11 PM   #423
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Originally Posted by celek View Post
2 possibilities you mentioned 1 with linkage rods going both ways.
The other option is a custom made electronic controller with either 2 or 4 motors that can be balanced. Using OE ECU signal in and 2-4 outs which can be tuned and balanced.
Common linkage, single actuator.
Balance them individually on a flow bench.
Run a hybrid alpha-N tune.
Use a vacuum block, and use MAP for idle control, and nothing else.
Install an IAT sensor.
Keep it simple.
The key to driveability on ITB's is keeping it simple. You will need to tweak your tuning for major changes in temp and pressure.
I have no doubt that ECUTEK can make alpha-N work.
Forget hybrid controllers, multiple motors, etc. I have never seen an ITB setup that didn't use a common linkage... Strike that, I've seen a v8 with 1 motor per bank.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
celek (02-09-2016)
Old 02-08-2016, 11:38 PM   #424
burdickjp
Drives: 2013 ultramarine Scion FR-S
Run a plenum and keep the maf.
Sent from my SM-G900M using Tapatalk
burdickjp is offline   Reply With Quote
The Following User Says Thank You to burdickjp For This Useful Post:
celek (02-09-2016)
Old 02-09-2016, 04:18 PM   #425
wizzo
Drives: 2014 Toyota 86
I second this idea
wizzo is offline   Reply With Quote
Old 02-10-2016, 11:40 PM   #426
celek
Resident Gear Head
celek's Avatar
Waiting on parts ETA tomorrow
A little work with a contour gauge I had laying around.
Old 02-11-2016, 02:55 PM   #427
celek
Resident Gear Head
celek's Avatar
It is official,
The 2nd most expensive part of the build purchased.
In 304dur @ 13.00mm lift
Ex 292dur @ 12.55mm lift
For comparison Stock numbers
In 255dur @ 11.00mm lift
Ex 252dur @ 11.00mm lift
The Following 3 Users Say Thank You to celek For This Useful Post:
cyde01 (02-12-2016), Doozer (02-17-2016), FRS Justin (02-20-2016)
Old 02-11-2016, 03:09 PM   #428
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Sweeeet!
Piper cams?
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 02-11-2016, 06:04 PM   #429
Traktor
Drives: Subaru BRZ Limited
Will be interesting to see how she idles. Or not.
More importantly, will you be the one who finally figures out how to make NA power above 7400rpm?!?
I can't wait to see the results.
Traktor is offline   Reply With Quote
The Following 4 Users Say Thank You to Traktor For This Useful Post:
airjonny (02-11-2016), celek (02-11-2016), Dream20b (02-11-2016), Hyper4mance2k (02-17-2016)
Old 02-11-2016, 08:15 PM   #430
celek
Resident Gear Head
celek's Avatar
Idle is like a warranty I am good at ruining them both. Neighbors definitely not going to be happy
The Following 2 Users Say Thank You to celek For This Useful Post:
DustinS (02-17-2016), Traktor (02-11-2016)
Old 02-11-2016, 08:19 PM   #431
celek
Resident Gear Head
celek's Avatar
A little present in the mail. I can't find my damn calipers.... It will be off to the laser CNC monday for final pieces to be made. Then welded together
#becosworthit
civicdrivr (02-20-2016), DocWalt (02-11-2016), Trust86 (02-11-2016)
Old 02-11-2016, 09:49 PM   #432
stevo585
Drives: White 2014 BRZ
It is official,
Damn thats like vtec cams.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
CSG Mike (02-16-2016)
Old 02-16-2016, 09:25 AM   #433
celek
Resident Gear Head
celek's Avatar
Well baffle setup sent off too the laser cutter. Maybe done by this weekend it will be back, but I am headed to the Great Lakes Racing Expo.
If you are near Cincinnati come visit the show is free, Also bringing along the Short block for display.
https://www.facebook.com/events/1619534554962832/
Old 02-16-2016, 11:03 PM   #434
Turdinator
Señor Member
Turdinator's Avatar
Those are some big cams, I am looking forward to see how well they go and how well the AVCS copes with them. @celek how much adjustment you will have left with these cam specs?
1974 TA22 Celica
2013 86 GT
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 06:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 10:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 08:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 10:48 AM
