Old 02-08-2016, 03:40 PM   #1
PRKR8NGR
Drives: Oceanic FR-S
Are these DOT approved?
I have looked everywhere and I don't know if these are DOT approved?
[ame="http://www.amazon.com/Replacement-Housing-Streak-Signal-Subaru/dp/B00XRBVZOE/ref=sr_1_8?ie=UTF8&qid=1454963083&sr=8-8&keywords=scion+frs+tail+light"]Amazon.com: Replacement Black Housing Brake Streak Signal LED Tail Light Unit Scion Frs/Subaru Brz: Automotive[/ame]
Also a little confused on what DOT approved lights needs to have?
I read some taillights have to have a reflect red portion and also have to be seen from a certain distance, is this correct?
Thanks,
PRKR8NGR
PRKR8NGR is offline   Reply With Quote
Old 02-08-2016, 03:44 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thanks,
PRKR8NGR
Highly doubt it.
Edit: DOT needs a side marker bulb and red brake lights and red/amber signals ect. I don't remember all the rules. The plastic also has to be a special plastic and if it is DOT approved they stamp the lens so during inspections its easy to identify if thats what your worried about. I had a friend who imported a stagea and they would not pass it because the headlights and taillights did not have to DOT stamp even though they were OEM
Family Approved FRS Parappa Member's Car Journals 141 05-23-2022 07:36 PM
Spec D Tails DOT Approved? Mmmankey Cosmetic Modification (Interior/Exterior/Lighting) 10 01-26-2016 08:03 AM
The 86 is rally approved and you can be too at $94K Fastbrew BRZ First-Gen (2012+) — General Topics 6 10-05-2015 09:32 AM
Pre-approved, but should I wait? MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 26 01-21-2013 03:22 AM
Mechanic Approved ashtray BRZ First-Gen (2012+) — General Topics 10 06-15-2012 04:53 PM
