Old 02-04-2016, 09:56 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Toyota Axes Scion - Change Splash screen logo
Well, I hate scion now! Haha!
Is there a way to change the startup screen (splash screen) of the Scion FRS head unit on 2014+ model. I have the 2015 stock head unit.
Basically I just want to remove the Scion splash screen to Toyota
Offtop: What about the steering wheel, just overlay with a toyota badge ?
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 02-04-2016, 10:49 PM   #2
funwheeldrive
Be honest, did you even try searching?
The Following 3 Users Say Thank You to funwheeldrive For This Useful Post:
JohnJuan (03-31-2016), MisterSheep (02-05-2016), _sams86_ (07-26-2017)
Old 02-04-2016, 11:19 PM   #3
Mikeez
Engineering Student
Since you ask, lol. I did, found nothing for the FRS only the brz.
Old 02-04-2016, 11:34 PM   #4
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
The thought popped into my head to try and change the splash screen too. Doesn't look like there's anything on changing the splash screen on the FR-S.
Old 02-05-2016, 03:55 PM   #5
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Plus 1 billion................
And you might of found this....... http://www.ft86club.com/forums/showt...radio+settings
IceFyre13th is offline   Reply With Quote
The Following User Says Thank You to IceFyre13th For This Useful Post:
go_a_way1 (02-05-2016)
Old 02-05-2016, 04:02 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
In before lock
Old 02-05-2016, 04:08 PM   #7
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Actually I'm kind of interested as well
Instagram: trevor.parque
KR-S (02-06-2016)
Old 02-05-2016, 04:13 PM   #8
DAEMANO
Time Traveller
1. Print this...
2. Cut it out with scissors. Be careful with the outlines.
3. Now using your hands, tape over front of your factory Scion head unit (stereo).
4. Remove when needed.
The Following 7 Users Say Thank You to DAEMANO For This Useful Post:
Blu-by-U (03-26-2016), go_a_way1 (02-05-2016), GT86_PRAGUE (04-12-2016), KR-S (02-06-2016), lbroskee (02-05-2016), MisterSheep (02-05-2016), wbradley (02-06-2016)
Old 02-05-2016, 04:14 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
TDRL or w/e the hell it is/means:
YOU CANT
so get over it and if it bothers you so much buy an aftermarket unit.
/thread
Old 02-05-2016, 04:15 PM   #10
MisterSheep
Killed Scion
YOU CANT
/thread
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
go_a_way1 (02-06-2016), KR-S (02-06-2016)
Old 02-05-2016, 05:27 PM   #11
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
YOU CANT
/thread
TL;DR
too long didn't read
lbroskee is offline   Reply With Quote
The Following User Says Thank You to lbroskee For This Useful Post:
Old 02-05-2016, 05:28 PM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Originally Posted by lbroskee View Post
TL;DR
LMAO thanks I never figured that one out and didn't want to google it. Was way more fun learning this way
Old 02-06-2016, 05:16 PM   #13
Lorico
Drives: 2015 FRS
YOU CANT
/thread
its possible, i actually have seen a corolla with a custom screen (they obviously have the same unit) I can't remember where i found this but i copied and pasted it to my icloud, but i changed my headunit. Glad I saved it. SO here goes
Here's how to change the startup image on the entune nav:
Load a usb device, such as a flash drive with the image of your choice. The images file name, including the file extension, can be up to 32 characters. Name the image without spaces or strange characters. When saving the images to a USB, name the folder that the startup image is saved to “StartupImage” and name the folder that the screen off image is saved to “DisplayOffImage”. If these folder names are not used, the navigation system cannot download the images. (The folder names are case sensitive.)
The images file extension is JPG or JPEG. Image files of 10MB or less can be saved.
Up to 3 images can be downloaded. Plug the flash drive into your car usb port.
On the entune nav system:
Press the “SETUP” button
Touch “General” on the “Setup” screen.
Touch “Customize Startup Image”
Touch “Transfer”
Touch “Yes”
You can also delete and switch between screens.
You should now see your new startup screen flash by when the entune system is started each time.
This forum is really starting to suck with the the un helpful replies, sure i can be unhelpful too at times, but those are to people with really stupid questions.
Lorico is offline   Reply With Quote
The Following 13 Users Say Thank You to Lorico For This Useful Post:
D_Thissen (02-06-2016), FRSBRZGT86FAN (03-05-2016), gatorbushmen (02-09-2016), go_a_way1 (02-06-2016), GT86_PRAGUE (04-12-2016), HyperTech (02-20-2016), KR-S (02-06-2016), Lonewolf (02-06-2016), Mikeez (02-09-2016), S84kam (02-06-2016), saj (04-06-2016), Scourge (07-14-2017)
Old 02-06-2016, 05:27 PM   #14
S84kam
S84kam's Avatar
Drives: FBRZS
I changed my head units logo as well. But I went to the dealer and they did something similar to what lorico said.
Do you guys assume the scion symbol magically appeared when the vehicle rolled out of the production plant? Obviously someone added it there. Therefore it CAN be changed
As of late. There have been the same douche bags replying. Answering as quick as possible without the slightest bit of help. With the usual answer "have you searched yet" in hopes to receive their "thanks"
S84kam is offline   Reply With Quote
headunit splash screen. encity5 Electronics | Audio | NAV | Infotainment 21 08-11-2017 03:00 PM
How to remove SCION silk screen logo from Headunit Danklvr DIY (Do-It-Yourself) Guides 78 05-29-2016 07:09 PM
Scion stock HU change boot up logo Lorico Electronics | Audio | NAV | Infotainment 2 10-16-2015 02:49 PM
Custom splash screen with OFT? CaptainSlow Software Tuning 0 02-15-2014 08:30 AM
T7019A HELP boot screen or splash screen change Trap63 Electronics | Audio | NAV | Infotainment 2 06-09-2013 05:04 PM
