#3459 | |
I have a couple friends with the RC1, they have been very impressed with the life. I have ~4.5 HPDE and about 10 autox days, and maybe 2k street miles on my RE71s and they are at half tread. Many people are talking 10-12 HPDE days on the RC1 with out issues. |
#3460 | |
Drives: Fr-s
Anyone running tt-d care to comment? A theoretical from scratch build 205 a7 15 pts Shocks 4pts Free mods including e85 with a custom tune Gutted and ballast up to weight. Sorry to take it a bit off topic though. BTW once I start running tt-d I'll be in a similar boat to you due to my existing mods unless I swap back to stock suspension. Exhaust is a worthless points spend for the frs IMO.
#3461 |
Drives: '13 FR-S Whiteout
Don't forget the Maxxis contingency program! Not the absolute fastest tire, but it is very forgiving and has a long life compared to similar tires.
#3462 | |
Drives: anything you let me
If you're going 225, definitely don't mount them on the 9's. As to swapping sizes, looking over the rules I found this: "7) The following DOT-approved tires and those R-compound tires with a UTQG treadwear rating over 40: BFG Rival S, Bridgestone RE071-R, Maxxis RC-1 (examples: Kumho V700, Kumho V720, Michelin Pilot Sport Cup & MPS Cup 2, Nitto NT01, Pirelli PZero Corsa, Toyo R888, Toyo RA-1, Yokahama A048, etc.) +6" So you're looking at +6 regardless of which tire compound you select, then the sizing would follow this... "10) The following tire sizes will be used as the base tire size for each Base Class for all vehicles regardless of their OEM tire size(s) or their Final Competition Class. All vehicles in a given base class may use this tire size (or smaller) without a points assessment: TTB: 265mm, TTC: 255mm, TTD: 245mm, TTE: 235mm, TTF: 215mm, TTG: 195mm, TTH: 175mm Tire width points assessed or points credited are determined by the difference between the width of the largest tire on the vehicle and the assigned base tire size as follows: Equal to or greater than: 10mm +1, 20mm +4, 30mm +7, 40mm +10, 50mm +13, 60mm +16, 70mm +19, 80mm +22, 90mm +25, 100mm +28, 110mm +31 Equal to or less than: -10mm -1, -20mm -4, -30mm -7, -40mm -10" Which means you wouldn't have a penalty for running 245 RE's in the wet since that is TTD base size but you should actually recoup 4 points when running the RC1's. Depending on what other mods you have you may want to run the 225 RC1's for point allocation alone but be aware if it's a wet day and you were at max points, you'll be over running 245 RE's when you lose the 4pt credit. |
#3463 |
Wow, that seems like a LOT of time on the RC1's! My Z2's were rocks by then even though they had a ton of tread left (5-7/32nds) and most of my time was taking students out or helping them with lead/follow exercises so nowhere near 10/10ths.
#3464 | |
#3465 | |
Drives: Fr-s
For now it makes a pretty good autox/track car.
| The Following User Says Thank You to redlined600 For This Useful Post: | CSG Mike (02-06-2016) |
#3466 | |
Are you tuned on Ecutek? |
#3467 | ||
The RE71R will have more grip, but last much, much less. Also, it will overheat faster on track. Do you want a lot of seat time, or that one magic lap every session? |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Uplink (02-07-2016) |
#3468 |
Perhaps you're tripping a failsafe of some sort built into your tune?
#3469 | |
Drives: WRB BRZ
Mainly because there are two other cars I know of (tuned by separate tuners) that have exactly the same problem at high fuel levels on E85. I believe they are tuned with either brzedit or ecutek. I have no fueling mods at all, am using the stock fuel pump and running an OFT tune. |
#3470 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
Should I be worried about boiling my stock fluid while bedding I'm carbotech XP8's? I have RBF600 coming Tuesday but would like to bed the newly mounted track before changing fluids, since I need to drive to classes and work Monday.
I'm guessing i don't need to worry about it but I want to bed them in as best as I can on the street, so I thought it was worth asking. |
#3471 | |
You talking shocks only, or coilovers for your shocks? |
#3472 | |
The spoiler bugs me a lot since that is 4 Points.
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
