Old 01-14-2016, 08:53 PM   #1933
e1_griego
e1_griego's Avatar
Drives: Many
http://www.ft86club.com/forums/showthread.php?t=100044
e1_griego is online now   Reply With Quote
Old 02-05-2016, 01:09 PM   #1934
Devil 86
Devil 86's Avatar
Drives: Ultramarine FR-S
Are splitters and diffusers permitted in this class?
Devil 86 is offline   Reply With Quote
Old 02-05-2016, 01:20 PM   #1935
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Nope.
You can use a lip from a Blue series on a BRZ or a TRD lip on the FRS
2superblus is offline   Reply With Quote
Old 02-05-2016, 01:24 PM   #1936
sanbaifo
Apex Premeditator
Drives: ZC6-C5AE-C7Z51-E36
Even in $M you can't use a diffuser; only a front splitter.
sanbaifo is offline   Reply With Quote
Old 02-07-2016, 05:15 PM   #1937
cab33
Drives: Fast
This may have been asked before, but what is the ballpark cost to take a stock FRS and make it a competitive STX car?
cab33 is offline   Reply With Quote
Old 02-07-2016, 05:37 PM   #1938
FastWhite
Drives: Subaru BRZ Limited M/T
Oh HELL, loaded question. Cheap to national champ. Personnel experience is to do the EVO school, both phases, $500.
Tires. The RE71R to start with. A dedicated set otherwise you could be buying another set within a year. They don't wear that well???? Sways f/r ~$400, springs/coilovers ~$400-12000. The list goes on. Check out Counter space garage, evasive MotorSport, RCE, Ft86 Speed factory, circuit MotorSport.
If you buy used $4-7K should do it.
It CAN get pricey. Just keep your budget in check and stick to it.
FastWhite is offline   Reply With Quote
Old 02-07-2016, 06:26 PM   #1939
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If you're definitely going to do it, trudge through the rest of the thread, on the cheap $4k can get you locally competitive, it seems like it doesn't take a significant amount to run competitive at nationals with people placing well with <$2k coilovers (which imo is the big X factor in this build, heard some people do well with Fortune Auto/ Feals but I bet there are people up there on >$4k Teins, JRZs or custom Ohlins) and all the key components not needing to be the best of the best. Not sure how much the top guys have into their cars, their builds are not very public but I imagine you could swing at them for about a $6k if you're intelligent about setting up a car and can drive well, and of course all the money in the world won't automatically hand you a trophy.
Must haves:
9" wide wheels & 245 tires in a competitive compound: $1k-$2k+
Header & tune: $1k-$2k+
Suspension; coilovers, camber plates, rear lcas, $2k-$12k+
Good alignment and Brake pads and fluid and then odds and ends to taste (sways, intake exhaust, bushings, weight reduction, etc.) And that's pretty much the recipe.
ineedyourdiddly
Old 02-08-2016, 08:33 AM   #1940
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
One of the best parts about owning an impractical car is that a LOT of people buy them, mod them, realize they're impractical and then promptly part-out.
Everything I bought for my car I bought used with the exception of the Helix mirrors lol
I have a very basic STX build; KWv3, 17x9 Varrstoens, 245/40 RE-11, Perrin front sway, TRD rear sway, CAI, cat-back and OFT tune...all in I'm at about $4k. I'm usually top 1/3 locally, probably would be bottom 1/3 at a ProSolo.
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 02-11-2016, 02:02 PM   #1941
e1_griego
e1_griego's Avatar
Drives: Many
I bought pretty much everything new.
It's best not to add it up lol.
I just picked up a set of those Kosei K6R on closeout, too, so I don't have to put thousands of street miles on the re71s.
Old 02-11-2016, 03:17 PM   #1942
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
I bought a set of used 17x7 RPF1s last summer. They came with half worn 235x40 R17 ZIIs. My plan was to try my hand at an autocross event in the stock class. I never got around to it but about a month ago I got a good deal on a set of KW V3 coils I couldn't say no to... That'll bump me up to STX... how bad do I need wheels and tires? 7 inches is undersized in this class and I'll probably get weird characteristics from the 235 tires squeezed on to the little rims.
ハチロク is offline   Reply With Quote
Old 02-11-2016, 03:37 PM   #1943
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Depending on local competition you might be okay, but generally 17x9 w/ 245s is what's needed for a truly competitive STX car. Since you were planning to run CS, I'm assuming you don't have a header and tune either, which will also be a significant disadvantage in STX. Again, might be okay locally but not at any national events.
That being said, I'm going to be doing autox in STX with 17x8s running 225/45 ZII* (because that's going to be my track setup). I have a header, but it isn't installed yet as I'm still figuring out/piecing together what I want for the rest of my exhaust before installing/tuning. I might be alright in Chicago region, but I know that I'll be out-gunned if I venture up to any Milwaukee events (or any of those guys head down here). lol
Just go out and have fun, and try to work on driver mod. If you can trade up your 17x7s to some 17x8s or 17x9s, that might not be a bad idea. But if you aren't really gunning for top spots I wouldn't worry about it too much.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 02-12-2016, 07:10 AM   #1944
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
I'd say go as you are and see what you need to do. This sport is fun even if you don't win.
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 02-12-2016, 02:56 PM   #1945
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
IF you are modding up to STX and want to be competitive you have to go all in. That means making all the mods that are allowable and common. Otherwise you will be left behind. It gets expensive, but the car runs and handles so much better.
MTCRX is offline   Reply With Quote
Old 02-12-2016, 03:01 PM   #1946
jbailey8748
Do the STX cars usually run rear sway bars
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
