Old 02-04-2016, 04:55 PM   #281
Dream20b
Y u do dis?
I beat a v6 mustang in my grandmother's RX350 0-80. They're slow as hell
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 02-04-2016, 07:22 PM   #282
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by FT86RGV View Post
Good and Bad Day!
So I finally got in my new Hoosiers DOT Drag Radials V. 2 (pretty much slicks) in 245/45/17. Mounted them on some cheap 17 x 8 rims. Took them to the track last night and they are absolutely amazing.
Mods are: Sprintex 210 intercooled kit - 69 mm pulley, airaid intake, flex-fuel tuned by delicioustuning. Revworks headers, invidia overpipe, front pipe, and Q300 catback.
Before the hoosiers I had a hard time launching the car. pretty much had to launch below 3k rpm to hook with the street tires I had on before (265/35/18 pss). Was hitting 12.9xx - 13.1xx.
I decided to launch at 4k rpm with the hoosiers. 1st run - 12.653 @ 108.97 / 60' 1.920.
They hooked so well there was no spin and the car still bogged down
2nd run: 4.5k rpm - 12.678 @ 110.30 / 60' 1.864. Same issue as 1st run.
3rd run: 5k rpm launch. I am #33 right side.
Car felt very quick out of the hole. Was amazing. nearly hit 7s in the 1/8. Had just a tad of wheel spin but tires hooked after a few feet and I flew.
The bad:
Was about to call it a day and wait but decided one more. why not?
4th run: 5.5k rpm launch - dnf. As soon as I dumped the clutch really loud pop out back. Car sat in place and didn't go anywhere. had to be pushed off to the side.
First thought was driveshaft or differential. Ended up being driver side cv axle. I completely snapped it. broke at the hub end. You know what they say. Gotta pay to play. Will be ordering Driveshaft Shop 600 hp rated axles. hopefully can get them in next week and installed by next weekend. @FRS Justin @Dream20b
BEAST MODE ACTIVATED!!!!! Now what clutch you running?
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
hmong337 (04-25-2016)
Old 02-05-2016, 12:24 AM   #283
FT86RGV
You're not going to believe it. Stock clutch. I have no idea how it has out survived my axles. It still grabs just as hard as when I purchased the car nearly 4 years ago. I thought that was going to go first but I guess not.
Honestly I don't plan to upgrade the clutch. I've maxed out this kit and I don't really want to go the 335 route. My next goal is to drop an ls3 in once vorshlag comes out with their swap kit. The axles will be needed so I don't mind putting them now, although I'll probably have to swap the entire rear end later since I doubt the differential will hold up to the abuse of a 400whp/400wtq V8.
FT86RGV is offline   Reply With Quote
Old 02-05-2016, 01:42 AM   #284
FRS Justin
That diff is tough as nails I can't kill it and I tried you just need to upgrade it. Talk to Mark at Spencer Fab in NH he can hook you up and explain the upgrade. As far as the clutch goes you are losing some time because even if you can't feel it slip it is I guarantee it. If you decide to upgrade ACT has a nice one that's reasonable.
710whp
Old 02-18-2016, 12:16 AM   #285
seito23
Drives: Corn Juice junkie
I had fun tonight, never been to a track, ever. Went with some friends for the road course which was being privately rented so I took a shot the drag strip.
My only mod is a delicous E85 tune.
I ran 14.332 to 14.566 pretty consistently with an ET of 96-100.4 mph
I kept spinning first and second pretty terribly. Good news is I am down to the tread bars, bye,bye prius tires.
All in all its a blast and if you've never been, go.
seito23 is offline   Reply With Quote
The Following 4 Users Say Thank You to seito23 For This Useful Post:
Dream20b (03-12-2016), FRS Justin (02-18-2016), Lynxis (02-29-2016), Mike Brz (02-27-2016)
Old 04-24-2016, 01:58 AM   #286
Hyperblue302
Hyperblue302's Avatar
Drives: 2016 BRZ, 94 Integra GSR
I'll add one tonight, mods, drop in, plm header, oft e85 tune, Prius tires, 3500 on the clock. Weather low to mid 70's high humidity slight fog out, slight cross wind. Damn I gotta work on that launch. I'm car 46.
Hyperblue302 is offline   Reply With Quote
The Following User Says Thank You to Hyperblue302 For This Useful Post:
FRS Justin (09-16-2016)
Old 04-25-2016, 04:57 PM   #287
LBC Por Siempre
LBC Por Siempre's Avatar
Drives: 2008 Toyota Prius, 2012 911 Turbo
I'm still waiting on getting my Annual Peer Review Bonus to get either one of the new GT86s! It will go through the entire makeover for track days and the Occasional drag day. It's just I want a clear view of what I will do to the GT86 before I move forward after purchase. For sure a concerted effort of forced induction and to still make the car commfortable on the street's like the 991 Turbo.
Since I'm going under 11.00 seconds with the Porsche they are forcing me to get a Helmet and HANS device for my quarter mile runs. I don't mind, but I buy all my "Fun" cars with a Fire Extinguishers. I have already used it twice on the streets when someone's car has caught fire due to springing a Power Steering (1st time) fluid leak and then about a year later a Power Brake Fluid leak (2nd time!). On each occasion the person driving their Car KNEW of the leak and just kept on driving it!!! Lucky for them the fire's weren't that big by the time I saw them and pulled over. These Extinguishers don't hold much but they do the job for a single car "Automotive" fire.
First Idiom of everybody driving a car is Don't Drive with a Power Fluid Leak, your car will eventually catch on fire - just give `Er enough time!
LBC Por Siempre is offline   Reply With Quote
Old 04-25-2016, 07:56 PM   #288
LBC Por Siempre
I have run a 2.2 to 2.1 on stock tires.. The tip of the day is let some air out of them. I have went down to 15psi to get them to hook. Needless to say they will not act like a drag radial but they will get you to a 2.2 to a 2.1. Just be sure to air them up before you leave the track!!!!!!
15psi LOLFR. With a bit of water you can get the wheels to break traction that low. But man, there isn't enough meat on the sidewall and power (Just Yet) to make the rear wheel's come up full balls on Top Fuel dragster Spinning.
What are the dragster's running these days on the GT86 and the pioneering FWD JDM Civics, GSRs etc... 14, 15 inch slicks?
Old 04-25-2016, 08:47 PM   #289
FRS Justin
I have tried 15 psi and got the results I posted. No guess work all of it has been done.
Here's my N/A run on 15 inch wheels
[ame="https://www.youtube.com/watch?v=WzLqo6-VYR8"]13 47 frs - YouTube[/ame]
I don't have a decent turbo run on video as I am still sorting it out...
710whp
Old 05-18-2016, 08:53 PM   #290
ysu
Drives: Toyota 86 GTS Auto
(Australian, Toyota 86 GTS auto)
Not sure if stock automatic times have been posted, I thought it might interest some.
I did a 16.002 quarter mile, when I have started from ~2000 rpm (brake & throttle).
Simply jumping on the throttle netted fairly consistent times around 16.35.
Edit: the only work to the car is a camber bolt & wheel alignment; max camber (1.3) on the front, 0 toe all around.
ysu is offline   Reply With Quote
The Following User Says Thank You to ysu For This Useful Post:
FRS Justin (07-21-2016)
Old 05-23-2016, 08:39 AM   #291
greg.bowring
Drives:
1/4 Mile times
Going to do a run this Friday (rain pending) should be nice and cold, I have full EL Borg Warner turbo kit and flywheel heavy clutch and hopefully upgrading ecutek to racerom tomorrow. Rolling on 10" xd9s with 235/40 federals that have some tread. Any thoughts on if I should bother with launch control? Car has about 260rwhp
greg.bowring is offline   Reply With Quote
Old 05-28-2016, 11:25 AM   #292
s0sl0w
Proud of Boxer
How worried should I be about breaking stock axles with Hoosier A7's at a 5.4k launch. Grimmspeed intake and OFT 93 octane Grimmspeed tune?
s0sl0w is offline   Reply With Quote
Old 06-08-2016, 10:39 AM   #293
dallenj
Drives: Grey FR-S
[ame="https://www.youtube.com/watch?v=wriZjtgjKZQ"]Nitrous FR S vs Mustang GT - YouTube[/ame]
13.4 On a 1/4 mile. Full exhaust and a 50 shot of nitrous
dallenj is offline   Reply With Quote
Old 09-07-2016, 09:58 PM   #294
Corradooo
Corradooo's Avatar
Drives: Storm trooper FRS
Went to Sonoma for my first time 2 weeks ago, never drag races before in anything, on street tires I was able to run a 13.371 that's with a bad launch and a missed shift at the end into 5th, I def left a lot on the table and I think I can easily get into the 12's with a bit more practice
Corradooo is offline   Reply With Quote
The Following User Says Thank You to Corradooo For This Useful Post:
FRS Justin (09-29-2016)
Scion's free 2 year/25K mile maintenance plan? whtchocla7e Scion FR-S / Toyota 86 GT86 General Forum 25 06-06-2012 03:26 PM
La Times reviews BRZ Sport-Tech BRZ First-Gen (2012+) — General Topics 7 05-18-2012 11:11 AM
He lives his life 1 quarter mile at a time ucla bruin Other Vehicles & General Automotive Discussions 8 12-21-2011 07:04 PM
$95 Track day at Willow Springs- Horse Thief Mile-Oct 16th Louie Southern California 1 10-11-2011 12:31 AM
$85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal Louie Southern California 2 03-20-2011 05:17 AM
