#29 | |
Drives: GTS 86
Sent from my HTC_0P6B using Tapatalk |
#30 |
Drives: 2013 Asphalt FRS
1st and 2nd
With TX2K a little over a month away I'm prepping the trailer with common parts ect just in case.
Question has anyone ever broken 1st or 2nd gear in a manual trans. I plan to be leaving the line under 15 psi of boost and am starting to wonder what to expect from this trans with slicks on the rear... Should I put 1 or 2 extra trans in the trailer for this weekend of fun.. Your thoughts please, and thank you P.S. I never heard of a 1st or 2nd gear failure so if you have had one please let me know... thanks again
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#31 |
Y u do dis?
Sub'd.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#32 |
Under what kind of conditions are you shearing gears?
Obviously, with enough torque, you can straight up shear the gears at any temperature and condition (assuming the tires hook up), but we've not yet determined the "middle ground" where the transmission will fail if it gets hot, but will be okay if it stays cool. Is this at the track where the transmission is getting really hot, or on the street/dyno? Have you guys used a transmission cooler, or observed transmission temperatures when the failures occured? |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | FRS Justin (02-02-2016), Sleepless (02-01-2016) |
#33 |
Drives: 2014 GT86
Hmm, interesting. Indeed, who knows if it's just mechanical design weakness or in combination of overheating. As for 4th gear being narrower/thinner, it seems logical to me in design, as originally it was not meant for boosted engine, and there should be less torque then in lower gears, hence engineers may had been just up to choice of over-engineering and making much wider/stronger (with possibly increasing mechanical power loss) or adding just enough.
| The Following User Says Thank You to churchx For This Useful Post: | FRS Justin (02-02-2016) |
#34 | |
Hot Lava 6MT
Drives: Hot Lava FR-S
I believe most of the stress from a launch like that will be on the clutch. |
| The Following User Says Thank You to crazyfrenchbiker For This Useful Post: | FRS Justin (02-02-2016) |
#35 |
Drives: Full race 4cyl boxer
Here's one posted by @Dipstik-sportech
One of the guys I race against in vintage swears by trans coolers. He said he had been through 5 trannys before he put a cooler on and needs to rebuild them far less frequently now. Different car of course, but very similar trans internals. I wish that stock tranny designers would incorporate some internals that would double as the fluid pump if you just open two ports. |
#36 | |||
Drives: BRZ, STI, GT350R, Supra, 987.2
Transmission? ~$400-$1000 from what I've seen. Our gearset is significantly more but with increased strength comes an increase in material, labor, and time.
It's unlikely a heat issue as some of these are killed on the street less than half an hour into a drive, others on the track. Most steel holds up well to heat and a little ductility would actually help in this case. The stock gears are extremely hard, but extremely brittle. This is great for a long life at stock power, but ultimately the demise for higher horsepower and abuse that comes with increased loads. You actually want a bit of give so that the gears don't just shear off and they can absorb the loads. Quote:
I have spoken with Phil at Element Tuning and he has ran a cooler. He said it ultimately helped a bit but he still killed transmission after transmission. Personally, I see a trans cooler potentially helping shifting engagement, but as far as gear strength, I don't see it yet. Granted, I do not claim to know everything. Thank you very much for the submission! |
#37 |
Drives: 2014 GT86
If one redesigns for strength gears and for their installation gearbox needs to be cracked open anyway, imho it's worth to get two birds with one stone and during design process incorporate also different ratios, eg. like in close ratio gear sets ..
#38 |
Drives: 2014 Raven FR-S monogram
Hello all. Quick post. I have a 2014 FR-S monogram. I recently had my last free service of 60,000 miles. Currently have about 59,976 miles on her. I complained about a whine on my transmission when my clutch isn't engage, loose TRD short throw shifter, etc. So long story short...... Throw out bearing is shot. 1st,2nd,3rd,4th gears are bad! And another issue with gearing. And the TRD short throw screw was backed off about 2 turns. My car is completely bone stock! Other than TRD accessories ( air intake, sway bars, short throw, lowering springs, exhaust, and TRD 18" rims with Michelin pilot super sport ) they said my clutch was in good shape! But I went ahead and ordered TRD clutch since it's all broken down. Is this wear normal? And another side question...... Should I get aluminum drive shaft? Or keep it stock. Thanks in advance
| The Following User Says Thank You to Speeeddemon99 For This Useful Post: | FRS Justin (02-03-2016) |
#39 | |
That Guy
Drives: 2013 asphalt FRS MT
| The Following 5 Users Say Thank You to Calum For This Useful Post: | Drakiv (02-04-2016), killboy (02-03-2016), Spartarus (02-12-2016), Speeeddemon99 (02-03-2016), Ultramaroon (02-03-2016) |
#40 |
Do you have pics of the bad gears? How did you drive this car mostly? Did you change trans fluid or run stock? Any info is appreciated
| The Following User Says Thank You to FRS Justin For This Useful Post: | Speeeddemon99 (02-03-2016) |
#41 |
Actually yes I have a few pictures of the gears that the tech at Toyota was kind enough to text to me. I'll try to get them posted
| The Following 2 Users Say Thank You to Speeeddemon99 For This Useful Post: | FRS Justin (02-03-2016), VerusEric (02-11-2016) |
#42 | |
| The Following 2 Users Say Thank You to FRS Justin For This Useful Post: | Speeeddemon99 (02-04-2016), VerusEric (02-11-2016) |
| Automatic Transmission (AT) Information and Upgrade Thread | wlfpck | Engine, Exhaust, Transmission | 95 | 06-01-2021 10:40 PM |
| Be all End all 6MT transmission fluid thread | 504 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 27 | 08-03-2015 12:43 PM |
| Another New Transmission Thread! | jort88 | Issues | Warranty | Recalls / TSB | 2 | 07-07-2014 12:25 PM |
| Carnage for the RC guys. | Hardrock4445 | Off-Topic Lounge [WARNING: NO POLITICS] | 23 | 01-16-2013 06:51 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
