Drives: 2013 Subaru BRZ Sport-Tech
Delete
Delete
#2 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
correct me if I am wrong but I am sure they use a proper gasket not silicon like that. I am on the dealers side here. + you should have noticed fluid all over your driveway if it leaked enough to cause damage. Sorry man, looks like its time to get a 4.67 FD hahaha!
#3 | |
I Love custom Turbo kits
Drives: Limited BRZ
The dealer who you bought it from may have had no idea the diff was ever modified. It's an unfortunate situation, but the dealers don't seem to be at fault.
| The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
#4 |
Killed Scion
Drives: 2013 FR-S Whiteout
I hate to hear this is happening to you and I hope for the best
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#5 | |
![]() Too bad your first post had to be bad news...... ![]() Since you bought the car used and any warranty work has been declined by the dealer and the manufacturer, I'm ah feared you are on your own. I would suggest that you take it to a reputable auto shop and have the differential opened up and examined. (oh, BTW, does it have any fluid left in it .. ??) The redneck solution would be to clean all the grease/oil off the differential and surrounding area, tighten all the bolts/nuts around the casing, fill it with fluid, drive it for a while then check for leaks. If it still leaks or still makes noise, you are most likely looking at buying a new differential (worst case). I hope you get it fixed. Keep us posted. humfrz |
#6 |
Drives: 2023 BRZ
That sucks. But I agree with the others. Chances are the original owner screwed it up. The dealer you bought it from should have noticed the leak IF they did any kind of inspection. Regardless, it's on you at this point. I don't see how this is Subaru's fault. Bummer.
Lesson learned: have a pre-purchase inspection done by an independent specialist before ever buying a used car. |
#7 | |
The Fail Boat
Drives: CWP S.B.
Sounds like dealer screwed you.... you can try arguing with them.... ![]() But I would say it's time for 4.4 or 4.7 final drive swap... You will smell @ the new found power. (or 5.1 if you don't drive on highway..xD)
| The Following User Says Thank You to chaoskaze For This Useful Post: | go_a_way1 (02-03-2016) |
#8 |
Not Bаnned Anymore
I am planning on going 4.88 and if I didn't need a useable core he could have had mine lol. I am tempted to go with a 5.1 but I do driver on the highway a bit hahaha. Choices :/
#9 |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#10 | |
Not Bаnned Anymore
| The Following User Says Thank You to go_a_way1 For This Useful Post: | stevesnj (02-03-2016) |
#11 |
I forgot they use Monopoly money up there eh
| The Following 2 Users Say Thank You to stevesnj For This Useful Post: | brandonblt2 (02-05-2016), go_a_way1 (02-03-2016) |
#12 |
Not Bаnned Anymore
Lol that and because oil is so low now we compare things to the price of a barrel of mapple syrup. Good news is the bacon economy is still alright
#13 | |
#14 |
Drives: BRZ DGM Limited
Didn't the used care dealer give you at least a 6 month warrantee? If not, I can understand why Subaru will not cover it since it looks like it was tampered with.
| NH: 2013 Subaru BRZ ISC Suspension Marketing Vehicle | ISC Suspension | Cars for Sale/Trade | 9 | 12-14-2015 02:27 PM |
| $31,000 FRS....12,000Km... | Mr.Impreza | CANADA | 21 | 05-31-2015 09:55 PM |
| FS: Stock Rims and Tires <5,000KM (418) | mech | Canada Classifieds | 0 | 09-28-2013 11:55 AM |
| Catalytic converter warranty denial by Subaru. 100% Stock engine! | CSG Mike | Issues | Warranty | Recalls / TSB | 152 | 09-03-2013 02:31 PM |
| First video of Subaru 086a test vehicle from the Nurburgring + interior spy pic | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 22 | 11-21-2009 03:20 AM |
