#85 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Yes, same here maybe 2-3 times in over a year. I've also had my volume knob stop working. In both cases, using a paper clip in the tiny reset hole in the front to restart the unit fixed the issue.
One thing that annoys me is I need to press the buttons on the front (ie GPS) twice before it will do anything after I first boot up. From then on the first press works. |
#86 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#87 |
Drives: 2023 WRB BRZ (MT)
any idea if this would save you time on adapters and repining?
http://www.carjoying.com/joying-harn...ess-cable.html |
#88 |
No, it just basically disconnects +12 constant as far as I can tell. I have music on an SD and that is unaffected as well as all of my settings.
#89 |
Drives: GT86 trd
Hi All
I have just sold my dashlinq4 as i could not get it to connect with my Defi smart bluetooth adaptor. How has everyone found bluetooth connectivity on these, is it happy to connect to 3rd party devices OK? Cheers Neil |
#91 |
@B-R-Z
So to hook up the antenna adapter, I just tap the blue wire into the blue wire that gets repinned? And the 3 blank wires on the harness, do I just ignore them (back/amp/brake)? Couldn't find info on this part |
#92 |
Are we talking about only the antenna adapter? If so, I think you only need to use what allows you to connect the antenna to the radio. Then you must connect the wire for the antenna booster (coming from car harness) to amp turn on wire on radio. Its been a while since I installed this so I'm not 100%.
| The Following User Says Thank You to B-R-Z For This Useful Post: | lbroskee (02-07-2016) |
#93 |
any1 have trouble with the radio bezel fitting? theres a trim around the face that sits further back but its forward enough that my bezel doesn't clip on
#94 |
#95 | |
also any way to get my iPod to work with this thing? the built in app just crashes (radio quality it total crap so need my tunes) |
#96 | |
Ditch iPod, get a 32 GB microsd for $10 and load your library on it. |
#97 | |
hmm, ya im def on the right holes then. any apps to display track info like an iPod? from videos I've seen the built in one displays literally just the file name "song.mp3" |
#98 |
No, it displays tag info when playing, but you select the song by filename, IIRC. This is with the stock music player though. Find one on android that does exactly what you want and use that.
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
| Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. | junglizste | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-08-2015 11:55 AM |
| Ca-Fi Dashlinq4 Android head unit universal Toyota | phanguy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-19-2014 11:57 AM |
| FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 05:05 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
