Old 01-27-2016, 10:38 PM   #15
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by FRSport.com View Post
We have never had any issues bottoming out the stock ohlins/stock springs on our autox/track cars.
Although we run our cars at moderate heights with a slight forward rake.
I'm lowered a little bit less then Ohlins says to set them up, with a slight forward rake as well. To be honest I've not had the chance to do anything even remotely sporting with them on the car, I'm on winter tires and driving on terrible potholed roads.
Seeing that it's so close in length compared to a Bilstein shock eases my concerns quite a bit, I've driven a car on those and never had an issue pushing it hard.
Old 01-28-2016, 02:11 AM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The rears have limited height adjustment. Completely maxing out the lowering of the rears, I did not bottomed out the Ohlins when I owned it over all the miles and tracks I drove.
-alex
Old 01-28-2016, 10:28 AM   #17
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
-alex
Must be nice to have roads that don't suck then
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
Shark_Bait88 (01-28-2016), wparsons (01-28-2016)
Old 01-28-2016, 01:24 PM   #18
mav1178
mav1178's Avatar
I don't know about you, but plenty of freeways in the Los Angeles area suck.
Too much container/truck traffic = horrible, poorly fixed expansion joints on roads.
And some of the bridges end up being launch ramps instead of joints.
-alex
Old 02-02-2016, 12:41 PM   #19
FRSport.com
FRSport.com's Avatar
Drives: Scion FR-S Subaru BRZ
Send a message via AIM to FRSport.com
Update from the owner....
He loves them! Click click click
FRSport.com is offline   Reply With Quote
The Following 5 Users Say Thank You to FRSport.com For This Useful Post:
ajc209 (02-03-2016), DocWalt (02-02-2016), Iceman (02-02-2016), Nessal (02-03-2016), SmartedPanda (02-20-2016)
Old 02-03-2016, 08:01 AM   #20
ajc209
Drives: GT86 Cosworth
Quite soft springs at 70N/mm
Is the damper travel the same?
ajc209 is offline   Reply With Quote
Old 02-03-2016, 01:45 PM   #21
FRSport.com
it is actually 7kg/mm. It is soft but is enough. The damper takes care of alot of it.
And yes, Damper travel is the same. The Bilstein shafts were just shortened to prevent it from hitting the LCA.
Old 02-03-2016, 01:53 PM   #22
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Out of curiosity, do you/can you tweak the DFV at all? I don't even know where I'd begin with that, just curious if it's something that's possible.
Old 02-04-2016, 06:12 AM   #23
ajc209
It has shim stacks you can change to adjust damping range. Few people on here have had their MI20s revalved for > 8kg/mm springs.
The DFV is the same in all the road and track kits, just shimmed differently to suit the application.
Also 70N/mm is 7.14kg/mm i'll get my coat.....
Old 02-04-2016, 09:12 AM   #24
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Sure people have revalved the main valve. I've not heard of anyone tweaking the behavior of the DFV itself though. DFV shown in orange here, main valve in light gray above it:
It appears as though the DFV is going to be directly affected by the main valve and vice versa, but the drawing is not overly clear in that regard.
Old 02-04-2016, 11:07 AM   #25
ajc209
Isnt it the shaft jet path bleed that gets adjusted?
Its low speed damping that you want to be critically damped so you have to increase it with spring rate?
Old 02-04-2016, 11:47 AM   #26
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
When you turn the knobs you're adjusting the bleed. When someone revalves a shock they change the shim stack on the main valve. In this case FRSport changed the shaft to allow directional adjustment of the bleed (rebound/comp) as well as a revalve of the main valve.
I'm just curious if they've made adjustments to the behavior of the DFV to change the response over harsh bumps.
Old 02-09-2016, 08:42 PM   #27
FRSport.com
Here's a curveball,
We have actually removed the DFV system completely.
The valving now compensates to the missing DFV system and makes the ride extremely comfortable.
I took a ride in the customer's car, and Man oh man, it sure is amazing.
I have valved bilsteins on my miata (non adjustable monotube yellows) and it makes mine feel extremely stiff.
The Following User Says Thank You to FRSport.com For This Useful Post:
DocWalt (02-09-2016)
Old 02-14-2016, 03:11 PM   #28
Apex-Apex
Apex-Apex's Avatar
wow, that looks serious
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
FS: MCS C-Street Double Adjustable Shocks with TRD Spring PKG simpleisbest Brakes, Suspension, Chassis 11 08-24-2015 01:41 PM
Ohlins R&T on the street? donoman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 04-30-2015 01:59 PM
Brand New Whiteline Sway bars 20mm adjustable front 16mm adjustable rear deedz Brakes, Suspension, Chassis 11 03-17-2015 03:29 AM
Ohlins group buy aruxe CANADA 1 05-22-2014 03:36 PM
Trailer | Ohlins Install | Interviews With Essex & Ohlins Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 12-24-2013 03:01 PM
