#295 |
Drives: frs
Anyone tried double oil cooler? Like RX8
#296 |
Drives: GT86 Cosworth
Another Cosworth SC owner to add to the list:
BRZUK http://www.ft86club.com/forums/showthread.php?t=91641 |
| The Following User Says Thank You to ajc209 For This Useful Post: | weederr33 (02-02-2016) |
#297 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Added them to our long proud list!
#298 |
There's a few more on the UK forum but I dont think they have profiles on this club.
#299 | |
Drives: MY13 SWP BRZ Cosworth 2.3
As for the alloy sandwich, my boost gauge is running off that. It does not seem to make any difference to my readings whether installed or not, as that was my first thought as well.( I'll pull it off again just to double check and be sure) Yesterday was 37C with 98 percent humidity and today is shaping up to be about the same. Giving the front exchanger a mist with a spray bottle will make the temps drop rapidly, so everything appears normal. I live on the Gold Coast, and we are in the height of Summer here, so I think it may just be a case of climate ? Last edited by muckypuppy; 02-02-2016 at 06:58 PM. |
#300 |
Drives: blue - Cosworth SC stage 3.0
thanks for the information
thats pretty hot and humid so its good to hear the kit is still holding up well with 12 degrees over ambient in these conditions? |
#301 |
Yep, seems fine. I took it to my tuner who not only specialise in supercharger installations but are a big name in Australian Motorsport and they said is normal. I pulled the spacer today and still ran 12C over ambient (34C) just taking it easy. I do have the Perrin cooler up front so that may be a factor as well, but I think the proper solution to my intake temps is most likely going to be venting the bonnet for heat extraction. Seriously considering the Trackspec vents.
#302 |
I'd agree that some bonnet vents on the leading edge would help considerably
only thing to consider is any rain running through a vent and onto electrics as while most auto electrics are splash proof they're not water tight |
| The Following 3 Users Say Thank You to Matt@Cosworth For This Useful Post: |
#303 |
Drives: Subaru BRZ
#304 |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Are there flex points in that exhaust? Usually when it keeps cracking like that, it's because the engine is moving like normal during accel/decel, but there is not enough flexibility in the exhaust to accommodate that movement, and it end up cracking.
I think the coating flaking off is pretty normal for the really hot spots on the exhaust, and it's just a layer that flakes away. The rest should stay and function somewhat. This is why I prefer wraps though.
#305 |
Considering it's supposed to have a total of 4 layers of coating, I think you'll be fine. Besides, it would flake anyway after a few thousand miles or plenty of hard driving.
#306 |
Jerry
I've forwarded these images to Nameless and I'm awaiting their feedback |
#307 |
Drives: Subaru BRZ
#308 |
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6041 | 11-28-2025 09:08 AM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 02:12 PM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 02:18 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 03:33 PM |
| Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 12:26 PM |
