Old 02-01-2016, 04:09 PM   #29
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Well I just called roadside again and they are sending me a new tow from a different company right now so hopefully I can get it to the dealer in time so they can hear the noise.
MarkR171 is offline   Reply With Quote
The Following User Says Thank You to MarkR171 For This Useful Post:
rosol16 (02-01-2016)
Old 02-01-2016, 04:14 PM   #30
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
This is true... if oil is in operational temp or bearing spun horribly.
Anyways, on-topic.
If you think bearing is spun, do not, again DO NOT restart it again. For spun bearing, it won't bring up CEL. A lot ppl make a mistake by restarting the engine and make it worse. When bearing is spun and restarting the engine can cause valves to bend or worse, bend the piston rods.
and then... TOTALED!!!!
fumanchu1 is offline   Reply With Quote
The Following 2 Users Say Thank You to fumanchu1 For This Useful Post:
go_a_way1 (02-01-2016), raven1231 (02-04-2016)
Old 02-01-2016, 04:14 PM   #31
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
in before totaled??
MisterSheep (02-01-2016)
Old 02-01-2016, 04:15 PM   #32
MarkR171
MarkR171's Avatar
Drives: '05 Elise
I was waiting for that, lol
Sent from my SAMSUNG-SM-G890A using Tapatalk
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 02-01-2016, 04:17 PM   #33
-Phil
Drives: Rb25 neo brz
Regardless of it being covered under warranty or not, You're still out a car you just bought for a month or so which shouldn't happen
-Phil is offline   Reply With Quote
The Following 4 Users Say Thank You to -Phil For This Useful Post:
go_a_way1 (02-01-2016), MisterSheep (02-01-2016), raven1231 (02-04-2016), tinma (02-02-2016)
Old 02-01-2016, 04:18 PM   #34
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Meh, knock engine specially that low mileage is under warranty, not even gonna bother saying that.
This isn't fb group page lol
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
go_a_way1 (02-01-2016), raven1231 (02-04-2016), tinma (02-02-2016)
Old 02-01-2016, 04:24 PM   #35
fumanchu1
ICHI... I SAID TOTALED
OP tell your dealer I said totaled... he'll understand and give you a new one. I'm that influential.
in all seriousness though, hope the engine/car is ok
The Following User Says Thank You to fumanchu1 For This Useful Post:
Old 02-01-2016, 04:38 PM   #36
ichitaka05
Site Moderator
ichitaka05's Avatar
In this forum only Tada-san is only influential enough lol
& yes, he do lurk this forum. Not sure if he have an account.
ajc209 (02-02-2016), go_a_way1 (02-01-2016), Teseo (02-02-2016)
Old 02-01-2016, 05:28 PM   #37
2013GTRNate
2013GTRNate's Avatar
To the OP, I am so sorry about your engine. I hope that they get you back on the road again soon.
It is just the reality with cars; a small percentage will have issues regardless of manufacturer. I have been Turbo'd on the stock internals for 8,000 miles and have no issues so it isn't normal from my perspective.
I hope that they resolve your situation soon so that you can get back on the road.
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
The Following User Says Thank You to 2013GTRNate For This Useful Post:
MarkR171 (02-01-2016)
Old 02-01-2016, 05:29 PM   #38
MarkR171
MarkR171's Avatar
Drives: '05 Elise
I'm not letting it get me discouraged. I like the car and as long as everything is fixed under warranty I'm not going to be upset about it. I have another car to drive in the meantime.
The car is at the dealer now so it's just a waiting game now.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
ichitaka05 (02-01-2016)
Old 02-01-2016, 05:55 PM   #39
mad_sb
Drives: 2013 Asphalt FR-S
So, my thought is that the over filled oil is the culprit... assuming it is over filled enough for the crank to whip it into a foam, eventually reducing lubrication leading to the wear that causes the knock. Not sure though if the oil will de-foam after sitting for 45 minutes or so...
You did say 3/4" over the full mark right? Get photo proof it is over filled that much before you even think about draining the oil. And also make sure no one other than the dealer starts the engine again... don't want to give them any reason to blame you for the damage.
Old 02-01-2016, 06:15 PM   #40
MarkR171
MarkR171's Avatar
Drives: '05 Elise
I mentioned the overfill to the dealer (not the same one that did the oil change,) and showed them a picture of the dipstick.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 02-02-2016, 06:01 AM   #41
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Hope the best!
Old 02-02-2016, 06:42 AM   #42
FRS Justin
Drives: 2013 Asphalt FRS
Whips oil into foam then the oil pump gears cant pump the oil sounds plausible. Just hope they don't drain it and say there you go its good... The damage is done to the entire motor then not just bearings......I would love to send in a oil sample for analysis to see how much bearing and metal material is floating around in it. I don't know if only a quart would do that, I do know the oil level is higher than the pan when properly filled though.
good luck, stick to your guns on a engine replacement
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
how much psi can the stock motor hold? xUhMeyziing Forced Induction 56 10-13-2017 06:43 AM
Would you take your $ spent and a stock motor, over your FI setup? Timmy_Jones Forced Induction 25 05-21-2015 01:21 PM
STOCK MOTOR 3k Anthony7515 Engine, Exhaust, Bolt-Ons 16 11-25-2014 03:48 PM
Stock Motor Cross Want-To-Buy Requests 2 08-01-2014 06:47 PM
