Drives: 13 FRS
Car will not starts at all
So for whatever reason my 13 frs won't start. I have two key fobs and both have new batteries and I'm able to turn the car into aux mode but won't turn over at all. The light is on in the dash showing the alarm is on even though the alarm is off (pressing the unlock on the fob) checked every fuse and they're all good to go. Lights, dome lights and all dash lights turn on just fine and battery is new too. I was on a deployment and didn't drive the car everyday so my dad would drive it once a week and car ran just fine but now it won't even do a damn thing. It's FI and Ive had no problems with the car whatsoever. Very frustrating and want to get to the bottom of this. Oh and the fob does unlock and lock the car.
#2 | |
Do you know what the voltage is on the car's battery is? When's the last time your father started it?
#3 |
Drives: 13 FRS
He started it last week and took the battery to autozone and it was fine
#4 |
Drives: FT86
clutch switch or park/neural switch may be faulty
#5 |
Drives: 13 FRS
Is that a costly fix? I know the clutch switch is under the dash, was looking at it earlier but don't know where the park neutral switch is at
#6 | |
hey you, yeah you <3
Drives: 2014 37J FR-S
FI as in fuel injection or forced induction? Do you hear a metallic click from the starter when turning the key? The stock pos Panasonic is krap. With just a .03 mine wouldn't start. Everything else worked 100% fine.
#7 |
#8 |
Drives: 13 FRS
Car won't even click over when I turn the key but the starter and alternator are new so o I know that isn't the issue is and it forced induction. Has a FBM stage 1
#9 |
Drives: 13 FRS
#10 |
Get meter and check voltage. Make sure power is good, then fuses.
#11 |
Drives: 13 FRS
#12 | |
http://www.aa1car.com/library/battery_runs_down.htm Also, make sure the battery connections are clean and tight. humfrz |
#13 |
#14 | |
Drives: 13 FRS
| Car only starts when primary 02 is unplugged | j0hnnybk01 | Issues | Warranty | Recalls / TSB | 22 | 08-28-2017 11:13 AM |
| Random tip - cold starts | Dammod | AFRICA | 34 | 09-22-2015 01:38 AM |
| jerky starts | goshem | BRZ First-Gen (2012+) — General Topics | 14 | 01-19-2014 11:21 PM |
| Jerky / shaky starts | Itssrayyxd | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 06-17-2013 01:27 PM |
| Issue: Cold starts | jesseps | CANADA | 7 | 11-24-2012 11:26 AM |
