Old 06-11-2012, 04:35 PM   #1
FRiSson
Drives: FR-S MT
Synchros problem?
I have about 1,100 miles on my MT FR-S. I've noticed that the first and second gear synchros are a bit "crunchy". It is hard to shift into those gears smoothly, there is a little bit of push back and a feeling and sound of pushing metal pieces. It's not grinding at all, and the clutch is fully depressed. What it seems like is synchros that are not as smoothly meshed as they could be. Anyone else having this issue?
FRiSson is offline   Reply With Quote
Old 06-11-2012, 04:37 PM   #2
HunterGreene
Hail Magnet
HunterGreene's Avatar
Just to make the suggestion, get it taken care of under warranty immediately. While I don't have my FR-S yet, I can tell you that a "crunchy" sound like you are describing is indeed something wrong with the synchros
Old 06-11-2012, 04:40 PM   #3
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Are you shifting it into first before the car is completely stopped? What is your past experience with manuel transmissions?
chulooz is offline   Reply With Quote
Old 06-11-2012, 04:43 PM   #4
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
mine has only about 60 miles on it. I have noticed that 1st gear has some resistance when down shifting before completely stopped, but I wouldn't consider it a crunch at all.
Are your issues on upshifts or downshifts?
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 06-11-2012, 04:45 PM   #5
Zach
Drives: 13 FR-S Black MT
I have about 800 miles and experience similar, I'm willing to bet this is normal and just a part of its normal operation, much like the chatter some are experiencing down low in the rpm.
Zach is offline   Reply With Quote
Old 06-11-2012, 04:49 PM   #6
chulooz
Registered you sir
chulooz's Avatar
Don't, Do not, shift into first before the vehicle is completely stopped.
I hope this car doesnt start coming off as a shit bucket because of mistreatment, whether unknowingly or not.
Old 06-11-2012, 04:54 PM   #7
HunterGreene
Hail Magnet
One is an engine noise because of the DI system, the other is transmission. I have had synchros go on me before, and it sounds very similar to what happened to me--crunchy noises mean that the synchros are wearing abnormally.
Matt, listen to this guy, he is correct:
Agreed, chulooz
Old 06-11-2012, 05:08 PM   #8
FRiSson
Drives: FR-S MT
Just a couple of notes, I have been using manual shift cars for thirty years and never had a transmission that required service, or had to replace a clutch (even after 155,000 original miles). So, my shift style is not to blame. The problem is inconsistent, but appears to be getting worse, so I will be bringing it to the attention of the dealer. The issue appears when getting into first for the initial start up and then into second gear. Example: heavy traffic, I slow down a bit while in second, then switch into neutral, I put the car back into second, at about 22 mph, but it takes a fair amount of push and noise to get it back into gear. The overall feeling of getting into gear at this point is not smooth at all. The feeling is similar to well-worn synchros on an old transmission. What I wanted to know is if other people are experiencing this.
Old 06-11-2012, 05:14 PM   #9
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Just a couple of notes, I have been using manual shift cars for thirty years and never had a transmission that required service, or had to replace a clutch (even after 155,000 original miles). So, my shift style is not to blame. The problem is inconsistent, but appears to be getting worse, so I will be bringing it to the attention of the dealer. What I wanted to know is if other people are experiencing this.
Good idea... I would let dealer take care of it.
On the side note, when are you trying to shift into 2nd or 1st that makes those problems?
Old 06-11-2012, 05:20 PM   #10
Matt Andrews
Drives: race cars
Thanks for the heads up.
I've only done it when slow rolling before a stoplight. But I will admit on a tight road course or auto cross in the future I probably would have shifted into first with a heel / toe throttle blip. (i think - I honestly haven't paid too much attention to 1st gear gearing) What is special about this transmission that prevents you from doing this?
Old 06-11-2012, 05:25 PM   #11
ichitaka05
Site Moderator
ichitaka05's Avatar
Gear ratio is major one I think. FRS/BRZ gears are really short, so gotta watch out
Old 06-11-2012, 05:32 PM   #12
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
From another post, I was informed that the first two gears used a triple cone design for the synchros. This makes them feel a little notchy at times, namely when going into first at a stop, but that does not indicate a problem with them. Now if you hear the heart-wrenching gear grind noise when shifting, that's a different matter.
And yes, never use first gear unless you are stopped completely. Since the gears are somewhat close, you can easily ride second gear from 5mph. If you are below that, you can stop completely and then do a first gear shift. I've found second gear to go really, really low which I like because I'm used to that on the Si.
For sport driving, it's up to you but I'd keep the abuse while DDing to as minimal as possible!
eriktherod is offline   Reply With Quote
Old 06-11-2012, 05:39 PM   #13
motofan
Drives: 10 VW GTI
I have experience with some other cars for the past 10 years that it can be hard to shift into 1st gear. But not for the 10 GTI. You can try heel and toe or just bring the rev up when you down shift to low gears. Can be helpful.
motofan is offline   Reply With Quote
Old 06-11-2012, 05:41 PM   #14
Matt Andrews
Drives: race cars
ok. you guys are talking about sticking into 1st without a rev match.
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
A problem with new rules in SCCA/NASA regarding FIA seats CyberFormula Other Vehicles & General Automotive Discussions 3 11-09-2011 09:13 AM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 12:49 PM
